The wrong dependency fails the building of colibri_vf.
Fix the dependency of u-boot-nand.imx.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
NAND modules (Colibri Vybrid, iMX7, iMX6ULL) require the images with
1024 prepending bytes.
Add the u-boot-nand.imx target which enables with CONFIG_IMX_NAND
option.
Related-to: TEI-775
When CONFIG_USE_DEFAULT_ENV_FILE=y and the file
CONFIG_DEFAULT_ENV_FILE is empty (or at least doesn't contain any
non-comment, non-empty lines), we end up feeding nothing into xxd,
which in turn then outputs nothing. Then blindly appending ", 0x00"
means that we end up trying to compile (roughly)
const char defaultenv[] = { , 0x00 }
which is of course broken.
To fix that, change the frobbing of the text file so that we always
end up printing an extra empty line (which gets turned into that extra
nul byte we need) - that corresponds better to the binary format
consisting of a series of key=val nul terminated strings, terminated
by an empty string.
(cherry-picked from https://patchwork.ozlabs.org/project/uboot/patch/20210422074418.1573153-1-rasmus.villemoes@prevas.dk/)
Reported-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
On rockchip platforms, SPI boot image creation is not
straightforward like MMC boot image creation where former
requires to specify tpl, spl in multimage format in mkimage,
and later simply do a concatenate mkimaged-tpl with spl.
On this note, let drop rkspi image type creation via kbuild
and let inform via rockchip.rst
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
File 'defconfig' is a build artifact of 'make savedefconfig'.
Remove it when cleaning.
Have this symbol follow the pattern of all other such symbols.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
This code dates back to 2006, commit 483a0cf804df ("Fixes for gcc 3.4
based m68k toolchain,").
GCC 3.4 is so old. We do not support it.
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Coreboot runs in 32-bit mode and cannot run a 64-bit U-Boot. To get around
this we can build a combined image with 32-bit SPL and 64-bit U-Boot. Add
a build rule and binman definition for this.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Move Python tools to use absolute paths
Minor buildman fixes for new features
Make libfdt code more similar to upsteam
- Assorted bugfixes.
- Documentation improvements including support for https://u-boot.readthedocs.io/
Copy the .its source file selected by CONFIG_SPL_FIT_SOURCE
in builddir and in a file named "u-boot.its".
This patch avoid compilation issue when CONFIG_SPL_FIT_SOURCE is used
and KBUILD_OUTPUT is defined, in buildman for example.
Tested-by: Marek Vasut <marex@denx.de>
This patch adds support for generating LZMA compressed u-boot image.
The compressed image can be used for SPL to reduce the size of the u-boot
binary.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Running all the unit tests takes a while and is not useful when you are
just modifying the tools. Add an option to run only the tools tests.
b42841b7bb62 kbuild: Get rid of KBUILD_STR
2aedcd098a94 kbuild: suppress annoying "... is up to date." message
9c8fa9bc08f6 kbuild: fix if_change and friends to consider argument order
ebf003f0cfb3 kbuild: Consolidate header generation from ASM offset information
2982c953570b kbuild: remove redundant $(wildcard ...) for cmd_files calculation
8a78756eb545 kbuild: create object directories simpler and faster
4d4b5c2e3b6e treewide: remove explicit rules for *offsets.s
01d509a48b46 kbuild: remove unimportant comments from ./Kbuild
Compiling on ARMv7-M fails when trying to address the CPSR register which
is not available on this architecture.
Atomic functions refer to the CPSR register if compiled with
arch/arm/include/asm/proc-armv/system.h. On ARMv7-M we should hence
use arch/arm/thumb1/include/asm/proc-armv/system.h instead.
Cf. https://stackoverflow.com/questions/61097841/error-selected-processor-does-not-support-requested-special-purpose-register
Reported-by: Sicris Rey Embay <sicris.embay@gmail.com>
Pull in changes that have been pending in our 'next' branch. This
includes:
- A large number of CI improvements including moving to gcc-9.2 for all
platforms.
- amlogic, xilinx, stm32, TI SoC updates
- USB and i2c subsystem updtaes
- Re-sync Kbuild/etc logic with v4.19 of the Linux kernel.
- RSA key handling improvements
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact
on files outside of this scope.
Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig /
kbuild: re-sync with Linux 4.18").
In this particular re-sync in order to keep clang support working a
number of related changes needed to be pulled in that had been missed
previously. Not all of these changes we easily traceable and so have
been omitted from the list below.
The imported Linux commits are:
[From prior to v4.18]
9f3f1fd29976 kbuild: Add __cc-option macro
d7f14c66c273 kbuild: Enable Large File Support for hostprogs
6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*'
24403874316a Shared library support
86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang
0294e6f4a000 kbuild: simplify ld-option implementation
[From v4.18 to v4.19]
96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS
10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS
b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS
8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS
f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line
4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config
693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE
f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags)
2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F)
c931d34ea085 arm64: build with baremetal linker target instead of Linux when available
5accd7f3360e kconfig: handle format string before calling conf_message_callback()
a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c
0608182ad542 kconfig: split out useful helpers in confdata.c
adc18acf42a1 kconfig: remove unneeded directory generation from local*config
79123b1389cc kconfig: create directories needed for syncconfig by itself
16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count
d6c6ab93e17f kbuild: remove deprecated host-progs variable
56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol
c151272d1687 kconfig: remove unused sym_get_env_prop() function
1880861226c1 kconfig: remove P_ENV property type
e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile
4bf6a9af0e91 kconfig: add build-only configurator targets
f1575595d156 kconfig: error out when seeing recursive dependency
5e8c5299d315 kconfig: report recursive dependency involving 'imply'
f498926c47aa kconfig: improve the recursive dependency report
98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build
9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig
87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl
d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS
217c3e019675 disable stringop truncation warnings for now
bc8d2e20a3eb kconfig: remove a spurious self-assignment
fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config
5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments
Note that this adds new cleanup work to do in that we should adapt the
shared library support we have to what is now upstream.
Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.07
common:
- Align ENV_FAT_INTERFACE
- Fix MAC address source print log
- Improve based autodetection code
xilinx:
- Enable netconsole
Microblaze:
- Setup default ENV_OFFSET/ENV_SECT_SIZE
Zynq:
- Multiple DT updates/fixes
- Use DEVICE_TREE environment variable for DTB selection
- Switch to single zynq configuration
- Enable NOR flash via DM
- Minor SPL print removal
- Enable i2c mux driver
ZynqMP:
- Print multiboot register
- Enable cache commands in mini mtest
- Fix firmware probing when driver is not enabled
- Specify 3rd backup RAM boot mode in SPL
- Add SPL support for zcu102 v1.1 and zcu111 revA
- Redesign debug uart enabling and psu_init delay
- Enable full u-boot run from EL3
- Enable u-boot.itb generation without ATF with U-Boot in EL3
Versal:
- Enable distro default
- Enable others SPI flashes
- Enable systems without DDR
Drivers:
- Gem:
- Flush memory after freeing
- Handle mdio bus separately
- Watchdog:
- Get rid of unused global data pointer
- Enable window watchdog timer
- Serial:
- Change reinitialization logic in zynq serial driver
Users have option to overwrite default device tree
(CONFIG_DEFAULT_DEVICE_TREE) via environment variable DEVICE_TREE.
Feature has been added long time ago by commit 74de8c9a1672
("dts/Makefile: Build the user specified dts") for a little bit different
reason.
But this variable can be also used for different purpose like choosing
proper configuration from FIT image in SPL.
And this is the functionality I would like to use on Xilinx Zynq devices
that current u-boot.img can be composed in the same way based on OF_LIST
and different configuration is taken based on platform specific SPL.
SPL requires low level ps7_init_gpl configuration that's why different
boards require different SPL with fixed board_fit_config_name_match().
Commit f4dc714aaa2d ("arm64: Turn u-boot.bin back into an ELF file after
relocate-rela")
introduce REMAKE_ELF option to recreate u-boot.elf from u-boot ->
u-boot.bin + DT -> u-boot.elf.
The best is to ilustrate it from make V=1 output
cat u-boot-nodtb.bin dts/dt.dtb > u-boot-dtb.bin
cp u-boot-dtb.bin u-boot.bin
aarch64-linux-gnu-objcopy -I binary -B aarch64 -O elf64-littleaarch64 u-boot.bin u-boot-elf.o
aarch64-linux-gnu-ld.bfd u-boot-elf.o -o u-boot.elf --defsym="_start"=0x8000000 -Ttext=0x8000000
Last command has no explicit linker script passed that's why toolchain
internal linker script is used.
In Binutils 2.32 case it contains SIZEOF_HEADERS symbol which has changed
behavior by commit
https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=64029e93683a266c38d19789e780f3748bd6a188
which result in situation that program headers has changed from
(xilinx_zynqmp_mini_defconfig)
Program Headers:
Type Offset VirtAddr PhysAddr
FileSiz MemSiz Flags Align
LOAD 0x0000000000010000 0x00000000fffc0000 0x00000000fffc0000
0x0000000000018918 0x0000000000018918 RW 0x10000
to
Program Headers:
LOAD 0x0000000000000000 0x00000000fffb0000 0x00000000fffb0000
0x0000000000028918 0x0000000000028918 RW 0x10000
Xilinx tools like XSDB or Bootgen are using program headers for loading ELF
to the right location and by above binutils change ELF is loaded to
incorrect location.
The patch is explicitly use u-boot-elf.lds (just cat now) for u-boot.elf
recreation which is called when REMAKE_ELF is setup.
By purpose u-boot-elf.lds doesn't contain OUTPUT_FORMAT/OUTPUT_ARCH to be
able to use by all archs.
Tested-By: Álvaro Fernández Rojas <noltari@gmail.com>
Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact
Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig:
re-sync with Linux 4.17-rc4").
A very small number of changes upstream since our sync with v4.17-rc4
that exist in the v4.18 release have already been applied here and have
been omitted from the list in this commit (and are readily available in
our own git history).
[From prior to v4.17-rc4]
39a33ff80a25 kbuild: remove cc-option-align
db547ef19064 Kbuild: don't add obj tree in additional includes
b999596b963a Kbuild: don't add ../../ to include path
[From v4.17 to v4.18]
b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files
74656b682902 kbuild: disable new dtc graph and unit-address warnings
74d931716151 genksyms: remove symbol prefix support
e6ecfb45072c kbuild: do not display CHK for filechk
0b669a5076fd kconfig: refactor Qt package checks for building qconf
b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf
1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf
694c49a7c01c kconfig: drop localization support
96f60dfa5819 trace: Use -mcount-record for dynamic ftrace
bb222ceeb327 kconfig: remove string expansion in file_lookup()
96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse()
5b31a9746756 kconfig: remove sym_expand_string_value()
137c0118a900 kconfig: make default prompt of mainmenu less specific
e298f3b49def kconfig: add built-in function support
2fd5b09c201e kconfig: add 'shell' built-in function
9de071536c87 kconfig: begin PARAM state only when seeing a command keyword
9ced3bddec08 kconfig: support user-defined function and recursively expanded variable
1175c02506ff kconfig: support simply expanded variable
ed2a22f277c6 kconfig: support append assignment operator
82bc8bd82e5c kconfig: expand lefthand side of assignment statement
1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions
a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables
915f64901eb3 kconfig: error out if a recursive variable references itself
2bece88f89fa kconfig: test: add Kconfig macro language tests
21c54b774744 kconfig: show compiler version text in the top comment
59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice
145167650b96 kbuild: add endianness flag to CHEKCFLAGS
1f2f01b122d7 kbuild: add machine size to CHECKFLAGS
d6a0c8a1326b kconfig: Add testconfig into make help output
bb6d83dde191 kbuild: Move last word of nconfig help to the previous line
8593080c0fcf kconfig: fix localmodconfig
ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount
b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree
ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol()
73d1c580f92b kconfig: loop boundary condition fix
48f6e3cf5bc6 kbuild: do not drop -I without parameter
bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is
6916162c7308 kbuild: remove duplicated comments about PHONY
Cc: Masahiro Yamada <masahiroy@kernel.org>
The commit 5fed97af20da ("Makefile: ensure DTB doesn't overflow into
initial stack") adds an extra check for stack size in BSS if
CONFIG_SYS_INIT_SP_BSS_OFFSET is enabled.
This check, however, doesn't make sense under the configuration where
control dtb won't be built in and it should be void in such cases.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Fixes: 5fed97af20da ("Makefile: ensure DTB doesn't overflow into initial stack")
Allow the default environment file to contain long lines split into
multiples lines.
Leading white spaces can be added for readability as well.
Signed-off-by: Samuel Mescoff <samuel@mescoff.fr>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Support redundant boot for rk3399
- Support binman for rockchip platform
- Update ram driver and add ddr4 support for rk3328
Since commit e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to
reST") MIGRATION.txt has been converted to migration.rst, so update
the Makefile references accordingly.
Fixes: e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to reST")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
All rockchip platforms support TPL or SPL-based bootloader
in mainline with U-Boot proper as final stage. For each
stage we need to burn the image on to flash with respective
offsets.
This patch creates a single boot image component using
- binman, for arm32 rockchip platforms
- pad_cat, for arm64 rockchip platforms.
This would help users to get rid of burning different
boot stage images.
The new image called 'u-boot-rockchip.bin'
which can burn into flash like:
₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64
This would support all rockchip platforms, except rk3128
since it doesn't support for SPL yet.
Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Cc: Wadim Egorov <w.egorov@phytec.de>
Add SPL-alone mkimage tooling support via Makefile for
few platforms or boards used in rockchip family.
With this users would get rid of explicitly creating
mkimage tool for rockchip rksd or rkspi boot modes.
Most of the platforms uses the platform type on their boot
stage image naming conventions in makefile like,
u-boot-x86-start16-tpl.bin - x86 start16 TPL bin
u-boot-spl-mtk.bin - Mediatek SPL bin
This would help to understand the users to what that
particular image belongs to? and less confused.
On that note, suffix platform type rockchip for existing
u-boot-tpl.img so now it become u-boot-tpl-rockchip.bin
Also, bin is more conventional way to include it on tools
like binman, pad_cat etc in future patches.
Note: usage of platform type doesn't follow consistent order
as of now.
Add rockchip image type support. right now the image
type marked with rksd, So create image type variable
with required image type like rksd or rkspi.
In order to generate a bootable U-Boot binary for i.MX8QXP MEK
we need to run:
$ make imx8qxp_mek_defconfig
$ make flash.bin
The resultant flash.bin and flash.log are not removed after
running 'make mrproper'.
Include these files into the CLEAN_FILES list entry so that
they can be properly deleted after 'make mrproper'.
This only exists to control whether the post/ directory is build. It is
just as easy to check this in the Makefile. Remove CONFIG_HAS_POST and use
an ifdef in the Makefile instead.
GCC 9.x starts complaining about potential misalignment of the pointer to
the array (in this case alignment=2) in the packed (alignment=1) structures.
Repeating Linus' Torvalds commit 6f303d60534c in the Linux kernel.
Original commit message:
We already did this for clang, but now gcc has that warning too.
Yes, yes, the address may be unaligned. And that's kind of the point.
This in particular hides the warnings like
drivers/usb/gadget/composite.c:545:23: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
545 | collect_langs(sp, s->wData);
drivers/usb/gadget/composite.c:550:24: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
550 | collect_langs(sp, s->wData);
drivers/usb/gadget/composite.c:555:25: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
555 | collect_langs(sp, s->wData);
This patches restores boot on boards which rely on
CONFIG_SYS_UBOOT_START equal to CONFIG_SYS_TEXT_BASE when using SPL
Fixes: d3e97b53c1f2 ("spl: fix entry_point equal to load_addr")
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
If u-boot.img is a FIT image, CONFIG_OF_OVERLAY_LIST can be used to add
DT overlays to u-boot.img.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
With the change to make tools/version.h a file we need to make sure that
the output directory exists first otherwise we will get a build failure.
Reported-by: Peter Robinson <pbrobinson@gmail.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Fixes: 4d90f6cd9813 ("tools: Avoid creating symbolic links for tools/version.h")
