path: root/Makefile
2020-04-13Merge branch 'next'Tom Rini
Pull in changes that have been pending in our 'next' branch. This includes: - A large number of CI improvements including moving to gcc-9.2 for all platforms. - amlogic, xilinx, stm32, TI SoC updates - USB and i2c subsystem updtaes - Re-sync Kbuild/etc logic with v4.19 of the Linux kernel. - RSA key handling improvements
2020-04-13Prepare v2020.04Tom Rini
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-04-07Merge tag 'xilinx-for-v2020.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.07 common: - Align ENV_FAT_INTERFACE - Fix MAC address source print log - Improve based autodetection code xilinx: - Enable netconsole Microblaze: - Setup default ENV_OFFSET/ENV_SECT_SIZE Zynq: - Multiple DT updates/fixes - Use DEVICE_TREE environment variable for DTB selection - Switch to single zynq configuration - Enable NOR flash via DM - Minor SPL print removal - Enable i2c mux driver ZynqMP: - Print multiboot register - Enable cache commands in mini mtest - Multiple DT updates/fixes - Fix firmware probing when driver is not enabled - Specify 3rd backup RAM boot mode in SPL - Add SPL support for zcu102 v1.1 and zcu111 revA - Redesign debug uart enabling and psu_init delay - Enable full u-boot run from EL3 - Enable u-boot.itb generation without ATF with U-Boot in EL3 Versal: - Enable distro default - Enable others SPI flashes - Enable systems without DDR Drivers: - Gem: - Flush memory after freeing - Handle mdio bus separately - Watchdog: - Get rid of unused global data pointer - Enable window watchdog timer - Serial: - Change reinitialization logic in zynq serial driver Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-06Prepare v2020.04-rc5Tom Rini
2020-04-06Makefile: Add environment variable DEVICE_TREE to headerMichal Simek
Users have option to overwrite default device tree (CONFIG_DEFAULT_DEVICE_TREE) via environment variable DEVICE_TREE. Feature has been added long time ago by commit 74de8c9a1672 ("dts/Makefile: Build the user specified dts") for a little bit different reason. But this variable can be also used for different purpose like choosing proper configuration from FIT image in SPL. And this is the functionality I would like to use on Xilinx Zynq devices that current u-boot.img can be composed in the same way based on OF_LIST and different configuration is taken based on platform specific SPL. SPL requires low level ps7_init_gpl configuration that's why different boards require different SPL with fixed board_fit_config_name_match(). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-03arch: Add explicit linker script for u-boot-elfMichal Simek
Commit f4dc714aaa2d ("arm64: Turn u-boot.bin back into an ELF file after relocate-rela") introduce REMAKE_ELF option to recreate u-boot.elf from u-boot -> u-boot.bin + DT -> u-boot.elf. The best is to ilustrate it from make V=1 output cat u-boot-nodtb.bin dts/dt.dtb > u-boot-dtb.bin cp u-boot-dtb.bin u-boot.bin aarch64-linux-gnu-objcopy -I binary -B aarch64 -O elf64-littleaarch64 u-boot.bin u-boot-elf.o aarch64-linux-gnu-ld.bfd u-boot-elf.o -o u-boot.elf --defsym="_start"=0x8000000 -Ttext=0x8000000 Last command has no explicit linker script passed that's why toolchain internal linker script is used. In Binutils 2.32 case it contains SIZEOF_HEADERS symbol which has changed behavior by commit https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=64029e93683a266c38d19789e780f3748bd6a188 which result in situation that program headers has changed from (xilinx_zynqmp_mini_defconfig) Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flags Align LOAD 0x0000000000010000 0x00000000fffc0000 0x00000000fffc0000 0x0000000000018918 0x0000000000018918 RW 0x10000 to Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flags Align LOAD 0x0000000000000000 0x00000000fffb0000 0x00000000fffb0000 0x0000000000028918 0x0000000000028918 RW 0x10000 Xilinx tools like XSDB or Bootgen are using program headers for loading ELF to the right location and by above binutils change ELF is loaded to incorrect location. The patch is explicitly use u-boot-elf.lds (just cat now) for u-boot.elf recreation which is called when REMAKE_ELF is setup. By purpose u-boot-elf.lds doesn't contain OUTPUT_FORMAT/OUTPUT_ARCH to be able to use by all archs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-By: Álvaro Fernández Rojas <noltari@gmail.com>
2020-03-31Merge branch 'next' of git://git.denx.de/u-boot-usb into nextTom Rini
2020-03-30Prepare v2020.04-rc4Tom Rini
2020-03-16kconfig / kbuild: re-sync with Linux 4.18Tom Rini
Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig: re-sync with Linux 4.17-rc4"). A very small number of changes upstream since our sync with v4.17-rc4 that exist in the v4.18 release have already been applied here and have been omitted from the list in this commit (and are readily available in our own git history). The imported Linux commits are: [From prior to v4.17-rc4] 39a33ff80a25 kbuild: remove cc-option-align db547ef19064 Kbuild: don't add obj tree in additional includes b999596b963a Kbuild: don't add ../../ to include path [From v4.17 to v4.18] b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files 74656b682902 kbuild: disable new dtc graph and unit-address warnings 74d931716151 genksyms: remove symbol prefix support e6ecfb45072c kbuild: do not display CHK for filechk 0b669a5076fd kconfig: refactor Qt package checks for building qconf b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf 1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf 694c49a7c01c kconfig: drop localization support 96f60dfa5819 trace: Use -mcount-record for dynamic ftrace bb222ceeb327 kconfig: remove string expansion in file_lookup() 96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse() 5b31a9746756 kconfig: remove sym_expand_string_value() 137c0118a900 kconfig: make default prompt of mainmenu less specific e298f3b49def kconfig: add built-in function support 2fd5b09c201e kconfig: add 'shell' built-in function 9de071536c87 kconfig: begin PARAM state only when seeing a command keyword 9ced3bddec08 kconfig: support user-defined function and recursively expanded variable 1175c02506ff kconfig: support simply expanded variable ed2a22f277c6 kconfig: support append assignment operator 82bc8bd82e5c kconfig: expand lefthand side of assignment statement 1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables 915f64901eb3 kconfig: error out if a recursive variable references itself 2bece88f89fa kconfig: test: add Kconfig macro language tests 21c54b774744 kconfig: show compiler version text in the top comment 59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice 145167650b96 kbuild: add endianness flag to CHEKCFLAGS 1f2f01b122d7 kbuild: add machine size to CHECKFLAGS d6a0c8a1326b kconfig: Add testconfig into make help output bb6d83dde191 kbuild: Move last word of nconfig help to the previous line 8593080c0fcf kconfig: fix localmodconfig ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol() 73d1c580f92b kconfig: loop boundary condition fix 48f6e3cf5bc6 kbuild: do not drop -I without parameter bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is 6916162c7308 kbuild: remove duplicated comments about PHONY Cc: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-03-13Makefile: doesn't need check stack size when dtb is not builtAKASHI Takahiro
The commit 5fed97af20da ("Makefile: ensure DTB doesn't overflow into initial stack") adds an extra check for stack size in BSS if CONFIG_SYS_INIT_SP_BSS_OFFSET is enabled. This check, however, doesn't make sense under the configuration where control dtb won't be built in and it should be void in such cases. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Fixes: 5fed97af20da ("Makefile: ensure DTB doesn't overflow into initial stack") Reviewed-by: Stephen Warren <swarren@nvidia.com>
2020-03-06Makefile: fix processing of default environment fileSamuel Mescoff
Allow the default environment file to contain long lines split into multiples lines. Leading white spaces can be added for readability as well. Signed-off-by: Samuel Mescoff <samuel@mescoff.fr> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-02-26Prepare v2020.04-rc3Tom Rini
2020-02-12Prepare v2020.04-rc2Tom Rini
2020-02-01Merge tag 'u-boot-rockchip-20200130' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Support redundant boot for rk3399 - Support binman for rockchip platform - Update ram driver and add ddr4 support for rk3328
2020-01-30Makefile: Fix the location of the migration fileFabio Estevam
Since commit e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to reST") MIGRATION.txt has been converted to migration.rst, so update the Makefile references accordingly. Fixes: e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to reST") Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-01-30rockchip: Add Single boot image (with binman, pad_cat)Jagan Teki
All rockchip platforms support TPL or SPL-based bootloader in mainline with U-Boot proper as final stage. For each stage we need to burn the image on to flash with respective offsets. This patch creates a single boot image component using - binman, for arm32 rockchip platforms - pad_cat, for arm64 rockchip platforms. This would help users to get rid of burning different boot stage images. The new image called 'u-boot-rockchip.bin' which can burn into flash like: ₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64 This would support all rockchip platforms, except rk3128 since it doesn't support for SPL yet. Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com> Cc: Wadim Egorov <w.egorov@phytec.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30Makefile: rockchip: Support SPL-alone mkimageJagan Teki
Add SPL-alone mkimage tooling support via Makefile for few platforms or boards used in rockchip family. With this users would get rid of explicitly creating mkimage tool for rockchip rksd or rkspi boot modes. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30Makefile: rockchip: Suffix platform type with tpl nameJagan Teki
Most of the platforms uses the platform type on their boot stage image naming conventions in makefile like, u-boot-x86-start16-tpl.bin - x86 start16 TPL bin u-boot-spl-mtk.bin - Mediatek SPL bin This would help to understand the users to what that particular image belongs to? and less confused. On that note, suffix platform type rockchip for existing u-boot-tpl.img so now it become u-boot-tpl-rockchip.bin Also, bin is more conventional way to include it on tools like binman, pad_cat etc in future patches. Note: usage of platform type doesn't follow consistent order as of now. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30Makefile: Add rockchip image typeJagan Teki
Add rockchip image type support. right now the image type marked with rksd, So create image type variable with required image type like rksd or rkspi. Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-28Prepare v2020.04-rc1Tom Rini
2020-01-23Makefile: Let mrproper remove flash.bin and flash.logFabio Estevam
In order to generate a bootable U-Boot binary for i.MX8QXP MEK we need to run: $ make imx8qxp_mek_defconfig $ make flash.bin The resultant flash.bin and flash.log are not removed after running 'make mrproper'. Include these files into the CLEAN_FILES list entry so that they can be properly deleted after 'make mrproper'. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-01-17common: Drop CONFIG_HAS_POSTSimon Glass
This only exists to control whether the post/ directory is build. It is just as easy to check this in the Makefile. Remove CONFIG_HAS_POST and use an ifdef in the Makefile instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-10gcc-9: silence 'address-of-packed-member' warningAndy Shevchenko
GCC 9.x starts complaining about potential misalignment of the pointer to the array (in this case alignment=2) in the packed (alignment=1) structures. Repeating Linus' Torvalds commit 6f303d60534c in the Linux kernel. Original commit message: We already did this for clang, but now gcc has that warning too. Yes, yes, the address may be unaligned. And that's kind of the point. This in particular hides the warnings like drivers/usb/gadget/composite.c:545:23: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member] 545 | collect_langs(sp, s->wData); drivers/usb/gadget/composite.c:550:24: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member] 550 | collect_langs(sp, s->wData); drivers/usb/gadget/composite.c:555:25: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member] 555 | collect_langs(sp, s->wData); Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2020-01-08Makefile: Fix CONFIG_SYS_UBOOT_START default valuePatrice Chotard
This patches restores boot on boards which rely on CONFIG_SYS_UBOOT_START equal to CONFIG_SYS_TEXT_BASE when using SPL Fixes: d3e97b53c1f2 ("spl: fix entry_point equal to load_addr") Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-07dts: Add support for adding DT overlays in u-boot.imgJean-Jacques Hiblot
If u-boot.img is a FIT image, CONFIG_OF_OVERLAY_LIST can be used to add DT overlays to u-boot.img. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-06Prepare v2020.01Tom Rini
2019-12-16Prepare v2020.01-rc5Tom Rini
2019-12-06Makefile: Ensure tools directory exists in output prior to useTom Rini
With the change to make tools/version.h a file we need to make sure that the output directory exists first otherwise we will get a build failure. Reported-by: Peter Robinson <pbrobinson@gmail.com> Tested-by: Peter Robinson <pbrobinson@gmail.com> Fixes: 4d90f6cd9813 ("tools: Avoid creating symbolic links for tools/version.h") Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-06Makefile: add build script for asn1 parsersAKASHI Takahiro
This rule will be used to build x509 and pkcs7 parsers. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-04mtd: Makefile: deep cleanupMiquel Raynal
Move MTD-related lines out of the root Makefile. Put them in their respective directories. Enclose some of these new lines to skip them when building the SPL. MTD core files and some MTD device drivers are compiled in a mtd.o object and included in the final object only if MTD support is required (there are two different symbols for that, one for U-Boot and one for the SPL). Now that all defconfigs have been fixed, we can stop the logic where enabling a command selects the core files to compile. This logic is broken since selecting a symbol with a 'depends on' will not enforce this secondary dependency. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2019-12-03cosmetic: Fix spelling and whitespace errorsThomas Hebb
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
2019-12-03Makefile: add Rockchip idbloader.img to CLEAN_FILESThomas Hebb
This file is generated in the root during Rockchip builds and so should be cleaned up. Signed-off-by: Thomas Hebb <tommyhebb@gmail.com> Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
2019-12-03Makefile: consolidate hardcoded lists of files to cleanThomas Hebb
Currently, we have two places where we list files that should always be cleaned if they exist. One, the CLEAN_FILES variable, is from the Linux build system and is the proper place to list files. The other, a set of extra arguments passed in the xargs template used to remove files with certain extensions, was introduced by 8f06f0cee3d3 ("Makefile: clean image.map") and is clearly wrong: by extending the xargs template, we attempt to remove the files once for each batch of arguments that xargs produces and we reduce the number of files from stdin that xargs can include in each of its rm commands. To fix this, put all hardcoded files into CLEAN_FILES. Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
2019-12-03Makefile: don't try to construct CLEAN_FILES based on configThomas Hebb
All of the clean targets (clean, dist-clean, mrproper) are run without loading a configuration. That means that any conditional modification of CLEAN_FILES will either always apply or never apply and so shouldn't be in a conditional in the first place. Since CLEAN_FILES is allowed to list nonexistent files, just add everything to it unconditionally to fix the issue. Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
2019-12-02Prepare v2020.01-rc4Tom Rini
2019-11-25ARM: socfpga: Introduce u-boot-with-nand-spl.sfp targetMarek Vasut
The NAND devices with 128 kiB erase blocks require extra 64 kiB padding between each SPL image. Generate U-Boot image with such a padding using this new target. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-11-18Prepare v2020.01-rc3Tom Rini
2019-11-17Merge tag 'dm-pull-14nov19' of git://git.denx.de/u-boot-dmTom Rini
Add OP-TEE test swuit Fix patman cc_file output Minor sandbox/pinctrl changes
2019-11-14tests: add OP-TEE test suiteHeiko Stuebner
OP-TEE can get supplied with a devicetree and will then insert its firmware node and reserved-memory sections into it. As this devicetree often is not the one supplied to a later loaded kernel, a previous commit added functionality to transfer these nodes onto that new devicetree. To make sure this functionality stays intact, also add a test for the transfer functionality. Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-11-12efi_loader: support building UEFI binaries on sandboxHeinrich Schuchardt
On the sandbox the UEFI binaries must match the host architectures. Adjust the Makefiles. Provide the PE/COFF header and relocation files. Allow building helloworld.efi on the sandbox. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-11-11Prepare v2020.01-rc2Tom Rini
2019-11-07usb: Add Cadence USB3 host and gadget driverVignesh Raghavendra
Add support for USB3 host and gadget driver. This is a direct sync of Linux kernel Cadence USB stack that from v5.4-rc1 release. Driver has been modified so that it compiles without errors against U-Boot code base. Features not required for U-Boot such as scatter-gather DMA and OTG interrupt handling has been dropped. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> [jjhiblot@ti.com: Add PHY support] Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2019-11-06Makefile: fix dependency for imx targetsHeiko Schocher
imx targets are defined in arch/arm/mach-imx/Makefile. Some of them are dependent on targets defined in main Makefile. For the Makefile in arch/arm/mach-imx this targets must be finished before the imx targets are build, if not you get for example the error: make -f /home/hs/abb/mainlining/u-boot/scripts/Makefile.build obj=arch/arm/mach-imx u-boot-dtb.imx make[2]: *** No rule to make target 'u-boot-fit-dtb.bin', needed by 'u-boot-dtb.imx'. Stop. make[1]: *** [/home/hs/abb/mainlining/u-boot/Makefile:1123: u-boot-dtb.imx] Error 2 make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory '/work/hs/compile/u-boot/aristainetos2_defconfig' make: *** [Makefile:148: sub-make] Error 2 compile failed In above case of CONFIG_MULTI_DTB_FIT is defined, the u-boot-dtb.imx is dependent on the u-boot-fit-dtb.bin which may is not build yet ... I could reproduce this error on a travis build also if I build an out-of-tree build on a local machine with a build directory on a "slow" slow storage device. If building the same source target with a build dir on a fast storage device, the build works. I found no solution to tell the arch/arm/mach-imx/Makefile to find the targets in main Makefile, if there is a way this would be the better fix. I solved it by adding a IMX_DEPS var, which holds a list of main u-boot targets, which must be finished, before calling imx targets and fixed the build for imx targets which enabled CONFIG_MULTI_DTB_FIT. I think it is just luck, that imx targets with CONFIG_OF_SEPARATE enabled build, because the u-boot-dtb.imx target depends on u-boot-dtb.bin which gets build early enough before starting with u-boot-dtb.imx. May this targets should be fixed too. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-03spl: Add a size check for TPLSimon Glass
We have the ability to enforce a maximum size for SPL but not yet for TPL. Add a new option for this. Document the size check macro while we are here. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-30Makefile: Fix printing problem in size_check on overflowTom Rini
When we have an excess size growth, fix the "limit" printf call to pass in just the limit variable rather than the string bytes to the format character. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-10-30Prepare v2020.01-rc1Tom Rini
2019-10-29arm: mvebu: Avoid generating kwbimage.cfg in the source treeBin Meng
At present some boards generate kwbimage.cfg in the source tree during the build. This breaks buildman testing on some systems where the source tree is read-only. Update makefile rules to generate it in the build tree instead. Note some other boards have the kwbimage.cfg file written in advance, hence we need check if the file exists in the build tree first, otherwise we fall back to one in the source tree. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-10-28tools: Avoid creating symbolic links for tools/version.hBin Meng
When building U-Boot host tools for Windows from Microsoft Azure Pipelines, the following errors were seen: HOSTCC tools/mkenvimage.o In file included from tools/mkenvimage.c:25: ./tools/version.h:1:1: error: expected identifier or ‘(’ before ‘.’ token 1 | ../include/version.h | ^ tools/mkenvimage.c: In function ‘main’: tools/mkenvimage.c:117:4: warning: implicit declaration of function ‘usage’ [-Wimplicit-function-declaration] 117 | usage(prg); | ^~~~~ tools/mkenvimage.c:120:35: error: ‘PLAIN_VERSION’ undeclared (first use in this function) 120 | printf("%s version %s\n", prg, PLAIN_VERSION); | ^~~~~~~~~~~~~ tools/mkenvimage.c:120:35: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [scripts/Makefile.host:114: tools/mkenvimage.o] Error 1 It turns out tools/version.h is a symbolic link and with Windows default settings it is unsupported hence the actual content of tools/version.h is not what file include/version.h has, but the the linked file path, which breaks the build. To fix this, remove the symbolic links for tools/version.h. Instead we perform a copy from include/version.h during the build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-16Merge tag 'dm-pull-15oct19' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-dm binman enhancements: - Dropping some test Elf files and building them from source instead - Refactoring of x86 16-bit entries - Support for SPL symbols within sections - Handle the 'notes' sections and hidden symbols in recent binutils - Improved error reporting with a tool fails libfdt and documentation fixes vboot required-key test driver model power-domain controls patman Message-Id enhancement
