Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
- Add support for Innokom board
- Don't complain if "install" fails
- README cleanup (remove duplicated lines)
- Update PXA header files
* Add documentation for existing POST code (doc/README.POST)
* Patch by Laudney Ren, 15 Jan 2003:
Fix handling of redundand environment in "tools/envcrc.c"
* Patch by Detlev Zundel, 28 Feb 2003:
Add bedbug support for 824x systems
* Add support for 16 MB flash configuration of TRAB board
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
(patch by Jón Benediktsson, 11 Dec 2002)
to log on the console, too (like in Linux); get rid of "logstart"
Fixes for x86 port (mostly strings issues)
* Patch by Ken Chou, 18 Nov 2002:
Fix for natsemi NIC cards (DP83815)
* Patch by Pierre Aubert, 19 Nov 2002:
fix a bug for the MII configuration, and some warnings
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
- use watchdog to reset PXA250 systems
- added progress callbacks to (some of the) ARM code
- update for Cogent CSB226 board
* Add support for FPS860 board
