path: root/Makefile
2011-10-06tegra3: Add Tegra SOC library to T30 alsoSimon Glass
This common library is used by both Tegra2 and Tegra3 seriesl SOCs. BUG=chromium-os:21033 TEST=build and boot on seaboard Change-Id: I3c43dbb24c341abe9865b5113898bf07eea16aeb Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/8694
2011-09-09tegra: Move tegra2 files into tegra-commonSimon Glass
This code is required for Tegra30 also, so we move it into a common directory. BUG=chromium-os:19004 TEST=build and boot on Seaboard Change-Id: I9af13892861f54c0d7da6d4f9ee0715bc5ab6357 Reviewed-on: http://gerrit.chromium.org/gerrit/7124 Reviewed-by: Yen Lin <yelin@nvidia.com> Reviewed-by: Tom Warren <twarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-29Automatically build the device tree if DEV_TREE_SEPARATE is setGabe Black
Part 3 of 3 of a change to make u-boot build the device tree instead of a separate ebuild. This change makes the u-boot "all" target build the separate device tree if DEV_TREE_SEPARATE is set. This use of DEV_TREE_SEPARATE is consistent with the one other use in the u-boot build system. It's at least expedient and perhaps necessary to build the device tree this way since it's difficult to know the value of $(obj) when invoking make. TEST=Built and booted on x86-alex, ran vboot_twostop. BUG=chrome-os-partner:5664 Change-Id: Icdcda86421e6f3cde59439b2be001ff522d6a6e9 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/6460 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-08-29CHROMIUM: remove earlier prototype codesChe-Liang Chiou
The removed codes are belong to an earlier prototype of integrating vboot wrapper API, which is not compiled/used anymore. Besieds, the prototype has a known vulnerability of buffer overflow when reading key blocks. So there is no many referential value for keeping the prototype codes in the codebase. And keeping the prototype also adds costs to new patches, which have to changes two implementations. All in all, I think it is time we retire this prototype. This patch also fixes coreboot build failure due to the removal. BUG=chromium-os:16542 TEST=emerge-{x86-alex,tegra2_aebl} chromeos-u-boot Change-Id: Ib6be9457f2dbc2daa3213c3d9c80bcdc56c520c4 Reviewed-on: http://gerrit.chromium.org/gerrit/5874 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Che-Liang Chiou <clchiou@chromium.org>
2011-08-29Fix non-ChromeOS builds.Vadim Bendebury
Recent changes broke the build for seaboard. It turns out that the build stops when attempting to compile the files in the ChromeOS specific libraries which are not even used in non-ChromeOS targets. The fix is to exclude these libraries from non-ChromeOS builds. BUG=chrome-os-partner:5369 TEST=manual . run the following commands while in chroot in the u-boot/files directory: emerge-tegra2_kaen chromeos-u-boot emerge-x86-alex chromeos-u-boot make -j16 ARCH=arm CROSS_COMPILE=armv7a-cros-linux-gnueabi- O=/tmp/sb distclean make -j16 ARCH=arm CROSS_COMPILE=armv7a-cros-linux-gnueabi- O=/tmp/sb seaboard_config make -j16 ARCH=arm CROSS_COMPILE=armv7a-cros-linux-gnueabi- O=/tmp/sb all . observe all of the commands succeed. Change-Id: I6a96105e9d403f57d3058818c24b36fadf013ec6 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/5598 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com> Reviewed-by: Tom Warren <twarren@nvidia.com>
2011-08-29CHROMIUM: move VbExNvStorageRead/Write to board-specific directoryChe-Liang Chiou
As ARM accesses non-volatile storage from eMMC and x86 from CMOS, the accessor functions that export to vboot_reference are really not board-independent and so should be put at a board-dependent module. BUG=none TEST=make Change-Id: Idbd4d70372770597aa8897524ee6a1ffe173bfea Reviewed-on: http://gerrit.chromium.org/gerrit/4646 Tested-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
2011-08-29No longer build build a separate device tree as part of u-boot.Doug Anderson
This changes DEV_TREE_SEPARATE so that it just means that u-boot should expect the dev tree to be separate, not that it should build it. We're already building separate device trees as part of the FDT build, and we're already using those device trees instead of this one. BUG=chromium-os:17191 TEST=Ran emerge-${BOARD} chromeos-u-boot chromeos-bootimage Flashed u-boot onto the board w/ cros_write_firmware Change-Id: I948e96b2b2b15255c5b0a6244c7bbc1972e139c3 Reviewed-on: http://gerrit.chromium.org/gerrit/4267 Tested-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Anton Staaf <robotboy@chromium.org>
2011-08-29Add a CBFS driver and commands to u-boot.Gabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. BUG=chrome-os-partner:3910 TEST=Built and booted on an Alex. Initialized with and without specifying the end of the ROM, and with a bad end of ROM. Ran the commands before CBFS was initialized. Ran cbfsinfo and saw reasonable output. Ran cbfsls and saw output that matched what was printed when the CBFS was put together by the coreboot ebuild. Used cbfsload to load a test text file into memory and verified that it was the correct size and had the correct contents. Ran with a max size and saw the file was truncated in memory. Change-Id: I64d06d49633cef3cffac1d571519eae38c7d267f Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: http://gerrit.chromium.org/gerrit/4167 Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-08-29fdt: Clean out old dtb files from output treeSimon Glass
This change 'make clobber' to remove all device tree binary files either at the build root or in subdirectories. BUG=chromium-os:11623 TEST=make ... clobber and observe that files are removed Change-Id: I603a382963bd8c2219a1361d4571ae1de559e788 Reviewed-on: http://gerrit.chromium.org/gerrit/3252 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29CHROMIUM: Port firmware_storage related APIs from lib/chromeos to lib/vboot.Tom Wai-Hong Tam
Directly copy firmware_storage related files from /lib/chromeos to /lib/vboot and the include file from /include/chromeos to /include/vboot and change the interfaces to proper vboot_wrapper ones. Related tests will go to another CLs. BUG=chromium-os:16543 TEST=compile without error Change-Id: I8f101149fdc6e5d17d8c63b930b239746f39a376 Reviewed-on: http://gerrit.chromium.org/gerrit/2938 Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Tested-by: Tom Wai-Hong Tam <waihong@chromium.org>
2011-08-29Fix embedded device tree buildSimon Glass
This was unfortunately broken by the external device tree building, and the fault was not noticed until now. BUG=chromium-os:11623 TEST=build with CONFIG_OF_EMBED defined; see that build succeeds and boots on Seaboard Change-Id: Iedc950577b63ffda5c4d8334662151836f33dd29 Reviewed-on: http://gerrit.chromium.org/gerrit/3262 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29CHROMIUM: Implement utility APIs provided by u-boot and exported to ↵Tom Wai-Hong Tam
vboot_reference. We put the new vboot wrapper export API to /lib/vbexport directory to separate the original APIs which in /lib/chromeos directory. A u-boot prompt testing tool, vbexport_test, is added for the API unit tests. This CL is dependent on http://gerrit.chromium.org/gerrit/#change,2195 BUG=chromium-os:16543 TEST=build chromeos_seaboard_vboot_config, flash it to seaboard, and run: Tegra2 # vbexport_test debug Preforming the debug output tests... Expect: K 75 Hello! It's "Chrome OS". Actual: K 75 Hello! It's "Chrome OS". Expect: -22222 0xa932 Actual: -22222 0xa932 Expect: 44444 0xad9c Actual: 44444 0xad9c Expect: -1111111111 0xbdc5ca39 Actual: -1111111111 0xbdc5ca39 Expect: 2222222222 0x84746b8e Actual: 2222222222 0x84746b8e Expect: -8888888888888888888 0x84a452a6a1dc71c8 Actual: -8888888888888888888 0x84a452a6a1dc71c8 Expect: 11111111111111111111 0x9a3298afb5ac71c7 Actual: 11111111111111111111 0x9a3298afb5ac71c7 Tegra2 # vbexport_test malloc Preforming the malloc/free tests... Trying to malloc a memory block for 1 bytes... - SUCCESS Trying to malloc a memory block for 2 bytes... - SUCCESS Trying to malloc a memory block for 4 bytes... - SUCCESS Trying to malloc a memory block for 8 bytes... - SUCCESS Trying to malloc a memory block for 32 bytes... - SUCCESS Trying to malloc a memory block for 1024 bytes... - SUCCESS Trying to malloc a memory block for 4096 bytes... - SUCCESS Trying to malloc a memory block for 32768 bytes... - SUCCESS Trying to malloc a memory block for 1048576 bytes... - SUCCESS Trying to malloc a memory block for 12345 bytes... - SUCCESS Trying to malloc a memory block for 13579 bytes... - SUCCESS Tegra2 # vbexport_test sleep Preforming the sleep tests... System is going to sleep for 10 ms... From tick 20158963 to 20168065 (delta: 9102) - SUCCESS System is going to sleep for 50 ms... From tick 20345437 to 20395038 (delta: 49601) - SUCCESS System is going to sleep for 100 ms... From tick 20572586 to 20672087 (delta: 99501) - SUCCESS System is going to sleep for 500 ms... From tick 20849623 to 21349024 (delta: 499401) - SUCCESS System is going to sleep for 1000 ms... From tick 21526751 to 22526052 (delta: 999301) - SUCCESS Tegra2 # vbexport_test longsleep Preforming the long sleep tests... System is going to sleep for 5000 ms... From tick 71318054 to 76318055 (delta: 5000001) - SUCCESS System is going to sleep for 10000 ms... From tick 76495950 to 86495051 (delta: 9999101) - SUCCESS System is going to sleep for 50000 ms... From tick 86672951 to 136672052 (delta: 49999101) - SUCCESS Tegra2 # vbexport_test beep Preforming the beep tests... System is going to sleep for 500 ms... Beep! From tick 11288504 to 11788451 (delta: 499947) - SUCCESS Change-Id: Ia192c1f152fa75f7d587d8a87eb22a1cf0a505c3 Reviewed-on: http://gerrit.chromium.org/gerrit/2656 Tested-by: Tom Wai-Hong Tam <waihong@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Randall Spangler <rspangler@chromium.org>
2011-08-29fdt: Add DEV_TREE_SEPARATE to provide an fdt separate from imageSimon Glass
This adds support for an FDT to be concatenated to the u-boot-bin binary. This is located at run-time by U-Boot. BUG=chromium-os:11623 TEST=Either emerge with http://gerrit.chromium.org/gerrit/2961 or build manually: make ... DEV_TREE_SEPARATE=true and check that u-boot.dtb is built. Change-Id: I7c8b1315d721bc957ef3fd07f167d86345868036 Reviewed-on: http://gerrit.chromium.org/gerrit/2962 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-29CHROMIUM: export compiler flagsChe-Liang Chiou
We export compiler flags because vboot_reference (or any library built outside u-boot) has to be built with the same compiler flags with u-boot so that the library and u-boot will have compatible ABI, etc. BUG=chromium-os:16508 TEST=manual make ARCH=arm \ CROSS_COMPILE=armv7a-cros-linux-gnueabi- \ USE_PRIVATE_LIBGCC=yes \ VBOOT=/build/tegra2_seaboard/usr \ {seaboard_config,u-boot-cflags.mk} Content of u-boot-cflags.mk ------------------------------------------------------------ CC = armv7a-cros-linux-gnueabi-gcc CFLAGS = -g -Os -fno-common -ffixed-r8 -msoft-float -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/armv7a-cros-linux-gnueabi/4.4.3/gcc/armv7a-cros-linux-gnueabi/4.4.3/include -pipe -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Werror -Wall -Wstrict-prototypes -fno-stack-protector ------------------------------------------------------------ Change-Id: If1bede099849af73e1770ef662601c2b619a215b Reviewed-on: http://gerrit.chromium.org/gerrit/2935 Tested-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2011-08-29Modify u-boot code to allow building coreboot payload.Vadim Bendebury
Two tweaks are required: - prevent the preprocessor from complaining when processing variadic macros - use the bfd linker instead of GOLD BUG=chrome-os-partner:3895 TEST=manual: while in chroot in u-boot-next/files directory run the following commands: rm -rf /tmp/c-u-boot make -j16 ARCH=i386 CROSS_COMPILE=i686-pc-linux-gnu- coreboot-x86_config O=/tmp/c-u-boot make -j16 ARCH=i386 CROSS_COMPILE=i686-pc-linux-gnu- all O=/tmp/c-u-boot observe the build succeed. Change-Id: I028afd9bb7269db8b16730a065dd64d83e5a158a Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: http://gerrit.chromium.org/gerrit/2425 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-08-24fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. BUG=chromium-os:11623 TEST=build and boot U-Boot on Seaboard Change-Id: I024d01079a44395e122a8b53e3901ba9a007dc5a Reviewed-on: http://gerrit.chromium.org/gerrit/621 Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-24This is the preliminary v05 TPM driver from Infineon. With a wrapper layer ↵Rong Chang
added to auto detect v03 and v05 chips. This is a version that just work. Cleanup will start after the initial push. BUG=chromium-os:10497 TEST=Manual Build 1. build a compatible lib first emerge-tegra2_seaboard vboot_reference-firmware 2. use MAKEALL script to check all cfg CROSS_COMPILE=armv7a-cros-linux-gnueabi- VBOOT=/build/tegra2_seaboard/usr ./MAKEALL chromeos 3. check result. 25 passed, no warning, no error u-boot command 1. build a compatible version USE-debug VBOOT_DEBUG=1 emerge-tegra2_seaboard -av vboot_reference-firmware chromeos-u-boot-next 2. flash it using proper tools [board specific] 3. reset system and boot into command prompt 4. test with cros_tpm_test command sets: cros_tpm_test enable cros_tpm_test fast_enable cros_tpm_test startup cros_tpm_test timing Review URL: http://codereview.chromium.org/6683023 Change-Id: I37b73dc90399533594c841b016a194ff21ab889a
2011-08-24Factor out verified boot required hardware interfaceChe-Liang Chiou
BUG=none TEST=emerge-tegra2_seaboard chromeos-u-boot-next Review URL: http://codereview.chromium.org/6543034 Change-Id: I88dfd38aedd81281415ecb8156181a6cc4d46495
2011-08-24Fix integration bugs (u-boot side)Che-Liang Chiou
This CL includes an empty tlcl_stub implementation. BUG=chromium-os:8621 TEST=Run 'VBOOT_DEBUG=1 make all' successfully See CL=4266002 for vboot side changes. Review URL: http://codereview.chromium.org/4429002 Change-Id: I0898af02697bd4e755d57d467283c2d3818ea36c
2011-08-24Move lib_generic/chromeos/ to lib/chromeos/Che-Liang Chiou
lib_generic/ is renamed to lib/ in newer version u-boot. Change-Id: I07ed1eb650c83db1533ac24209b4129db7068c08 BUG=None TEST=Run 'VBOOT_DEBUG=1 make all' successfully Review URL: http://codereview.chromium.org/4410003
2011-08-24Implement boot device r/w functions for vbootChe-Liang Chiou
BUG=None TEST=Manual Test procedure: 1. Compile with VBOOT_DEBUG flag on successfully 2. Run u-boot on dev board as follows: (Assume you have mmc device on dev board) CrOS> mmc init CrOS> cros bootdev set mmc 1 CrOS> cros bootdev (info of mmc1) CrOS> read mmc 1 0x20000000 1 2 CrOS> md.b 0x20000000 (mmc1 content) CrOS> cros bootdev read 0x20001000 1 2 CrOS> md.b 0x20001000 (mmc1 content) CrOS> cmp.b 0x20000000 0x20001000 0x400 (compare the blocks, should be identical) Review URL: http://codereview.chromium.org/4001006 Change-Id: I339f9fb63862993f8b9ced80d4c27d6bef0c1bc6
2011-08-24Add VBOOT to top-level MakefileChe-Liang Chiou
This CL adds argument "VBOOT" to top-level Makefile and config.mk that points to a verify boot implementation. Change-Id: Ib468cc7a6a7c3ce3db56b90d73c6022ac30fa046 BUG=none TEST=Run "make all" successfully Review URL: http://codereview.chromium.org/3515011
2011-06-27Prepare v2011.06v2011.06Wolfgang Denk
2011-06-25usb: convert to partial linkingMike Frysinger
Looks like this was missed during the conversion to partial linking. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22Makefile: move $(VERSION_FILE) rule out of ifeq configuredIlya Yanok
mkimage relies on autogenerated version so we need to move $(VERSION_FILE) rule out of ifeq and make tools rule depend on it to be able to run 'make tools' from the unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22config.mk: move LDSCRIPT processing to the top-level MakefileIlya Yanok
LDSCRIPT is used only from the top-level Makefile and only when the system is configured so we can move LDSCRIPT and CONFIG_SYS_LDSCRIPT related logic into the top level Makefile and under configured condition to avoid errors when building tools from unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-22Prepare v2011.06-rc3v2011.06-rc3Wolfgang Denk
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-02Prepare v2011.06-rc2v2011.06-rc2Wolfgang Denk
2011-05-26ARMV7: MMC SPL Boot support for SMDKV310 boardChander Kashyap
Added MMC SPL boot support for SMDKV310. This framework design is based on nand_spl support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-19Prepare v2011.06-rc1v2011.06-rc1Wolfgang Denk
2011-05-12examples: add smc911x_eeprom to clean targetMike Frysinger
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-27nhk8815: move config targets from Makefile to boards.cfgAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2011-04-27cpuat91: fix board supportEric Benard
- fix board support following relocation changes - switch to boards.cfg - disable i2c to keep size under 128kiB (1 sector) Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-04-27Makefile: change rule to build IMX imageStefano Babic
config.mk in board directory is obsolete and should be removed. The patch allows to get rid of own config.mk adding the imximage.cfg file to the options in the boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12mkimage: add "-V" option to print version informationWolfgang Denk
2011-04-01Fix NAND_SPL and ONENAND_IPL in MakefileHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-03-31Prepare v2011.03v2011.03Wolfgang Denk
2011-03-27Prepare vv2011.03-rc2Wolfgang Denk
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-07MIPS: Move VCT boards to boards.cfgShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com> Acked-by: Stefan Roese <sr@denx.de>
2011-02-05MIPS: Move Inca-IP targets to boards.cfgShinya Kuribayashi
At the same time, fix up CPU_CLOCK_RATE to have the CONFIG_ prefix to work with boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-05MIPS: Move Qemu MIPS target to boards.cfgShinya Kuribayashi
CONFIG_QEMU_MIPS is already provided by <configs/qemu-mips.h>, so we don't generate it using the options fields in boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-05MIPS: Move Alchemy Au1x00 based boards to boards.cfgShinya Kuribayashi
CONFIG_GTH2 is already provided by <configs/gth2.h>, so we don't generate it using the options fields in boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-02Prepare v2011.03-rc1v2011.03-rc1Wolfgang Denk
2011-02-02Print compiler and linker version with the version commandAlexander Holler
After years of unsuccessful research I've finally shamelessly stolen other peoples intellectual properties to present the all-new and world-changing updated version command: - U-Boot>> version U-Boot 2010.12-00014-g7435056-dirty (Jan 18 2011 - 23:19:38) MyBoard gcc (GCC) 0.42 (Distro foobar) GNU ld (GNU Binutils) 0.314159265 - May the toolchain bugs rest in peace. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
