Cc: Timur Tabi <timur@freescale.com>
If USE_PRIVATE_LIBGCC is set the yes building fails with a missing
libgcc.a As we use partial linking now it is libgcc.o now.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
include/configs/km_arm.h
For ARM systems, before ELF relocation was introduced,
CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the
U-Boot image from whereever it was loaded to it's link address
(CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation
was performed at all, it was just a memcpy().
With ELF relocation, this does not work like that any more, and
related boards need to be fixed anyway. So don't keep this relict any
longer.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective
board config files, all Marvell kirkwood board have just a single and
common entry in their config.mk files:
KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg
Replace the only reference to KWD_CONFIG in the top level Makefile by
an equivalent setting, and remove all kirkwood config.mk files.
Signed-off-by: Wolfgang Denk <wd at denx.de>
Cc: Prafulla Wadaskar <prafulla at marvell.com>
Cc: Siddarth Gore <gores at marvell.com>
Cc: Simon Kagstrom <simon.kagstrom at netinsight.net>
Cc: Heiko Schocher <hs at denx.de>
Cc: Eric Cooper <ecc at cmu.edu>
Acked-by: Wolfgang Denk <wd at denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Building of NAND based boards failed sometimes (especially on MP
systems) because of incorrect / missing dependencies.
A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Now that the boards.cfg file supports options to mkconfig, we can move
the bf527-ezkit-v2 target out of the Makefile and into boards.cfg.
Move the sh4 target boards out of the Makefile and into boards.cfg.
And fix sh4 of MAKEALL.
Move the sh3 target boards out of the Makefile and into boards.cfg.
And fix sh3 of MAKEALL.
Move the rsk7203 target out of the Makefile and into boards.cfg.
And fix sh2 of MAKEALL.
Boards often have a reserved size limit on the flash where they're stored.
Sometimes during upgrades or config changes, those limits are exceeded,
but no one notices until they try to upgrade and the limit screws things
up. Either not enough of U-Boot is written to flash (and so the reboot
fails), or too much is written (and so things after it get clobbered).
So allow boards to declare a size limit (in bytes) and have the build
system check it while building.
NOTE: The modification in Makefile will be superseded by a pending patch!
128MB NOR module support.
Define __io to get harddrive working.
Fix saving of environment into OneNAND.
Boot from harddrive when possible.
Add missing MAINTAINERS entry.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
"make clean" after builds of MatrixVision boards would leave stale
files around:
board/matrix_vision/mvblm7/bootscript.img
board/matrix_vision/mvsmr/bootscript.img
Fix this.
Originally the Makefile defines CONFIG_ADS5121_REV2 when configuring
for board mpc5121ads_rev2. The config in include/configs/mpc5121ads.h
expects a define CONFIG_MPC5121ADS_REV2 for this.
Therefore there are two defines used but only 1 is defined.
This patch renames references to CONFIG_ADS5121_REV2 to CONFIG_MPC5121ADS_REV2
to have one common define.
This patch fixes faulty mem size detection caused by wrong config in
Signed-off-by: Mark Vels <mark.vels@team-embedded.nl>
include/ppc4xx.h
Most tool subdirs do not rely on a configured tree, so move those targets
out of the config checks and unify them in the process.
Also add an easylogo target so people can easily build that.
Also add these new tool targets to the 'tools-all' target.
The helpful shortcut for doing a board config + make was dropped recently
as it conflicted with some new build code. However, the reason for using
pattern targets originally was to avoid managing a duplicate list of
boards. Since we now have one centralized place for a list of boards (the
new boards.cfg), we don't need a pattern target -- we can generate the
exact list of boards on the fly. So do just that.
When cleaning things up, the top level gitignore file ignores all things
that end with ".depend", but the clean target only deletes files that are
named exactly ".depend". Keep these in sync by having the clean target
punt all files that match the pattern that gitignore is using.
Acked-by: Detlev Zundel <dzu@denx.de>
Coding style cleanup.
This patch adds basic support for s5pc210.
s5p-common will be used by all of s5p SoCs.
convert the board to the new soc architecture
update default config
i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c
Signed-off-by: Eric Bénard <eric@eukrea.com>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Enabled SPD
Enabled DDR2
Enabled hwconfig
Signed-off-by: York Sun <yorksun@freescale.com>
This patch adds support for the Voipac PXA270 board. The support includes:
- Ethernet
- USB
- MMC
- NOR Booting
- OneNAND Booting
- LCD
- HDD
Acked-by: Scott Wood <scottwood@freescale.com>
The u-boot.lds CPP unification missed the Blackfin-specific clean target.
It is no longer needed, so punt it.
This patch adds minimum support for OMAP4. Code which can be shared
between OMAP3 and OMAP4 is placed in arch/arm/cpu/armv7/omap-common
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Update CHANGELOG
SH fails building on the target.
This supports this.
Ensure that date is called only with LC_ALL=C locale set to make dates
locale neutral thus preventing lurking of non-ASCII characters into
U-Boot binary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Changed LANG= into LC_ALL= as suggested by Mike Frysinger <vapier@gentoo.org>
Makefile
