Add a driver for the I2C TPM from Infineon.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Signed-off-by: Rong Chang <rongchang@chromium.org>
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
It was noticed that when `make distclean' is run, the make process
terminates with error reporting something like:
rm: cannot remove '/tmp/foobar/': Is a directory
make: *** [clobber] Error 1
The problem is that the list of files targeted for removal includes a
directory in case CONFIG_SPL_TARGET is not set.
The fix has been tested as follows:
Ran several times the following sequence of commands:
CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- make O=/tmp/foobar smdk5250_config
CROSS_COMPILE=/usr/bin/arm-linux-gnueabi- make O=/tmp/foobar distclean
it did not cause an error, it used to before this change.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Add TI814X EVM board directory, config file, and MAINTAINERS
entry. Enable build.
Signed-off-by: Matt Porter <mporter@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
[trini: Adapt to recent omap_hsmmc requirements, Matt re-tested]
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This allows reading of files from the host filesystem in sandbox.
These lines are dealt with in the x86 Makefile and link script, so punt
them.
Acked-by: Gabe Black <gabeblack@chromium.org>
When calling 'make u-boot.imx' the build were failing as it were
expecting the full path for the file; this regression has been
included by commit 71a988a (imximage.cfg: run files through C
preprocessor).
The direct references for u-boot.imx were replaced by $(obj) as
config.mk handles the proper setting of it making it set to $(OBJTREE)
when required.
The build has been test using:
- ./MAKEALL -s mx5 -s mx6
- make u-boot.imx
- make O=/tmp/build
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
The '#' used as comments in the files cause the preprocessor
trouble, so change to /* */.
The mkimage command which uses this preprocessor output
was moved to arch/arm/imx-common/Makefile
.gitignore was updated to ignore .cfgtmp files.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
For i.MX23 we need to pass imx23 as elftosb param.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds basic Tegra30 (T30) build support - no specific
board is targeted.
Signed-off-by: Tom Warren <twarren@nvidia.com>
On clobber, do a cleanup even for SPL build else, we'd have
MLO.byteswap remaining for certain platforms like am33xx SPL builds
Signed-off-by: Nishanth Menon <nm@ti.com>
This commit merges branches from samsung, imx and tegra
meant to fix merge issues between u-boot/master and
u-boot-arm/master, as well as a few manual merge fixes.
This was already used by some SPL targets, and allows the pad amount to
be specified by board config headers rather than only in makefile
fragments.
Also supply a pad-to of zero if the variable is undefined. It works
without this, but this avoids relying on undocumented behavior.
README
arch/arm/cpu/armv7/exynos/clock.c
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
README
include/configs/woodburn_common.h
board/woodburn/woodburn.c
These boards still use the old old PMIC framework, so they
do not merge properly after the power framework was merged into
mainline.
Fix all conflicts and update woodburn to use Power Framework.
Use the printf command to convert the number in any valid format into
the expected decimal format. The resulting errors should be printed to
stderr.
This new make target "u-boot-img.bin" consists of the U-Boot
SPL image with the real, full-blown U-Boot image directly
attached to it. The full-blown U-Boot image has the mkimage
header included, with its load-address and entry-point.
This will be used by the upcoming a3m071 MPC5200 board port.
This patch enabled boards using the SPL framework to set
an entry point in the U-Boot mkimage image "u-boot.img".
Until now the entry point in the header has been set to 0.
By setting CONFIG_SYS_UBOOT_START in the board header, boards
can override this default location.
The elftosb tool is now called with -d switch, which produces debug
output to the stdout. The debug output is completely useless for
regular operation, so silence it.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
When running from coreboot we don't want this code.
This version works by ifdef-ing out all of the code that would go
into those sections and all the code that refers to it. The sections are
then empty, and the linker will either leave them empty for the loader
to ignore or remove them entirely.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
This was introduced by commit 244615197469dd6fe75ae082f38424b97c79aeaf, but it
fails in a minimal SPL build where the only thing in arch/powerpc/lib is
cache.c, which apparently doesn't generate any fixup records.
The problem is reported to occur with GCC 3.x, so insist on GCC 4.0 or newer.
Patterned after checkthumb as suggested by Tom Rini.
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Tom Rini <trini@ti.com>
v2: test gcc version instead of testing nothing
Currently the SPL target is specified in a CPU-specific makefile
fragment. While some targets may need something more complicated than a
simple target name, targets which don't need this shouldn't have to provide a makefile fragment just for this.
v2: Removed default target as it's been pointed out to me how existing platforms
cause the SPL to be built.
Samsung's S3C24XX SoCs need this in order to generate a binary image
with a padded SPL concatenated with U-Boot.
Signed-off-by: José Miguel Gonçalves <jose.goncalves@inov.pt>
[scottwood@freescale.com: fixed prereq of u-boot.ubl]
v2: Removed spl/ prefix from u-boot.ubl prerequisite.
Existing U-Boot musb driver has no support for the new gadget framework
and also seems to have other limitations. As gadget framework is ported
from Linux it seems pretty natural to port musb gadget driver as well.
This driver supports both host and peripheral modes.
This is not a replacement for current musb driver (at least now) as
there are still some consumers of the old UDC interface.
No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be
defined.
Virtual root hub device is not implemented.
Known problems: with no devices connected usb_lowlevel_start() fails.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
This patch adds driver for I2S interface specific to samsung.
Signed-off-by: R. Chandrasekar <rcsekar@samsung.com>
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997
power management device.
Special file - fg_battery_cell_params.h with cells characteristics
added.
The FG device will work with redesigned PMIC framework.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Trats battery is now treated in the same way as other power related
devices. This approach allows for more unified handling of all devices
responsible for power management.
The PMIC framework has been moved to its more natural place
./drivers/power from ./drivers/misc directory.
When using SUBLEVEL for the -rc? tag, this results in an ugly version
string like "2013.01.-rc1" - let's use EXTRAVERSION instead to get the
simple "2013.01-rc1"
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load},
and transparently handle either file-system. This scheme could easily be
extended to other filesystem types; I only didn't do it for zfs because
I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code
too.
The rules to generate u-boot-{no,}dtb-tegra.bin were almost identical.
Combine them into a single paremeterized rule. This will allow the next
patch to edit a single rule, rather than being cut/paste twice.
SX1 does not build properly by itself, is not built
as part of MAKEALL arm or MAKEALL -a arm, and is only
present in Makefile, not boards.cfg. As it also has no
entry in MAINTAINERS, it is orphan and non-functional.
Remove it.
