A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Now that the boards.cfg file supports options to mkconfig, we can move
the bf527-ezkit-v2 target out of the Makefile and into boards.cfg.
Move the sh4 target boards out of the Makefile and into boards.cfg.
And fix sh4 of MAKEALL.
Move the sh3 target boards out of the Makefile and into boards.cfg.
And fix sh3 of MAKEALL.
Move the rsk7203 target out of the Makefile and into boards.cfg.
And fix sh2 of MAKEALL.
Boards often have a reserved size limit on the flash where they're stored.
Sometimes during upgrades or config changes, those limits are exceeded,
but no one notices until they try to upgrade and the limit screws things
up. Either not enough of U-Boot is written to flash (and so the reboot
fails), or too much is written (and so things after it get clobbered).
So allow boards to declare a size limit (in bytes) and have the build
system check it while building.
NOTE: The modification in Makefile will be superseded by a pending patch!
128MB NOR module support.
Define __io to get harddrive working.
Fix saving of environment into OneNAND.
Boot from harddrive when possible.
Add missing MAINTAINERS entry.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
"make clean" after builds of MatrixVision boards would leave stale
files around:
board/matrix_vision/mvblm7/bootscript.img
board/matrix_vision/mvsmr/bootscript.img
Fix this.
Originally the Makefile defines CONFIG_ADS5121_REV2 when configuring
for board mpc5121ads_rev2. The config in include/configs/mpc5121ads.h
expects a define CONFIG_MPC5121ADS_REV2 for this.
Therefore there are two defines used but only 1 is defined.
This patch renames references to CONFIG_ADS5121_REV2 to CONFIG_MPC5121ADS_REV2
to have one common define.
This patch fixes faulty mem size detection caused by wrong config in
Signed-off-by: Mark Vels <mark.vels@team-embedded.nl>
include/ppc4xx.h
Most tool subdirs do not rely on a configured tree, so move those targets
out of the config checks and unify them in the process.
Also add an easylogo target so people can easily build that.
Also add these new tool targets to the 'tools-all' target.
The helpful shortcut for doing a board config + make was dropped recently
as it conflicted with some new build code. However, the reason for using
pattern targets originally was to avoid managing a duplicate list of
boards. Since we now have one centralized place for a list of boards (the
new boards.cfg), we don't need a pattern target -- we can generate the
exact list of boards on the fly. So do just that.
When cleaning things up, the top level gitignore file ignores all things
that end with ".depend", but the clean target only deletes files that are
named exactly ".depend". Keep these in sync by having the clean target
punt all files that match the pattern that gitignore is using.
Acked-by: Detlev Zundel <dzu@denx.de>
Coding style cleanup.
This patch adds basic support for s5pc210.
s5p-common will be used by all of s5p SoCs.
convert the board to the new soc architecture
update default config
i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c
Signed-off-by: Eric Bénard <eric@eukrea.com>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Enabled SPD
Enabled DDR2
Enabled hwconfig
Signed-off-by: York Sun <yorksun@freescale.com>
This patch adds support for the Voipac PXA270 board. The support includes:
- Ethernet
- USB
- MMC
- NOR Booting
- OneNAND Booting
- LCD
- HDD
Acked-by: Scott Wood <scottwood@freescale.com>
The u-boot.lds CPP unification missed the Blackfin-specific clean target.
It is no longer needed, so punt it.
This patch adds minimum support for OMAP4. Code which can be shared
between OMAP3 and OMAP4 is placed in arch/arm/cpu/armv7/omap-common
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Update CHANGELOG
SH fails building on the target.
This supports this.
Ensure that date is called only with LC_ALL=C locale set to make dates
locale neutral thus preventing lurking of non-ASCII characters into
U-Boot binary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Changed LANG= into LC_ALL= as suggested by Mike Frysinger <vapier@gentoo.org>
Makefile
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Instead of adding explicit build rules for each and every board to the
top level Makefile (which makes it grow and grow), we now provide a
simple default rule and extend the "mkconfig" script to read board
configurations from a plain text file (table), "boards.cfg".
For simple boards it is now sufficient to add a single line of text to
the "boards.cfg" file, no changes to the top level Makefile are needed
any more.
To make the table better readable, change the notation for unused
fields from "NULL" into "-".
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Many boards don't need any special handling in the Makefile. Try and
provide as generic make rules for these as possible. There are still
many areas where this does not work out really well, but the changes
show the direction we should take, and point out which boards or
architectures need further cleanup.
Instead of stripping the "_config" part from the make target names in
each call of the "mkconfig" script let this script strip the string.
This prepares the ground for forther simplification of the top level
Makefile.
