add android config file;
support booti fastboot command and etc.
Signed-off-by: Lin Fuzhen <fuzhen.lin@freescale.com>
Add mfg configs for mx6dl sabresd and mx6solo sabreauto.
Signed-off-by: Terry Lv <r65388@freescale.com>
add android config to this board.
only basic boot support.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
The serial of patches adds the initial support for mx6dl
sabra sd board:
- DDR3 400MHz@64bit, 1G, 256M*4
- SD/MMC basic operations
- Add PIN/IOMUX support for mmx6dl sabresd.
- Ethernet is ok for 100/1000Mbps.
- OTP fuse
Signed-off-by: Fugang Duan <B38611@freescale.com>
The serial of patches adds the initial support for mx6solo
sabra auto board:
- DDR3 400MHz@32bit
- SPI-NOR basic operations
- OTP fuse
- clock command
- Anatop regulator command
- splash screen support by enabling "CONFIG_SPLASH_SCREEN"
Because i.mx6solo share the same ARD board with i.mx6dq,
the same board file is shared between i.mx6dq and i.mx6solo.
CONFIG_MX6DL configuration is used to distinguish the difference.
This patch is used to add mx6solo sabreauto configuration support.
Signed-off-by: Lily Zhang <r58066@freescale.com>
Add MFG tool support for i.MX6DQ ARD board
Apply script "Mx6DL_init_LPDDR2_400MHz_Micron_1.1.inc" in IVT, make U-boot
work for the LPDDR2 Board. The Make target name for the new board is
"MX6DL_ARM2_LPDDR2_CONFIG"
The script is provided by Chen Wei - B26879 for a quick bring up, which don't
have a corresponding compass link. It is uploaded to CR ticket page for
reference.
Originally for MX6DL DDR3 board, "CONFIG_MX6DL" is defined. It is used by
"board/freescale/mx6q_arm2/flash_header.S" to select the correct IVT. Since
MX6DL LPDDR2 board also define this macro, for distiguish purpose, another
2 macros "CONFIG_MX6DL_DDR3", "CONFIG_MX6DL_LDPPR2" are defined
Signed-off-by: Eric Sun <jian.sun@freescale.com>
enable mfg profile.
enable recovery mode.
mx6q_sabresd board's usb otg have HW issue, disable it in
android profile.
Add MFG tool support in imx6dl U-boot
Add mx6dl iram boot config.
This patch add the initial support for i.mx6dl ARM2 board
-SD/MMC basic
-DDR 400Mhz,
-FEC,basic
Due to i.mx6dl shares the same board with i.mx6q on ARM2,
the most common code should be the same as the i.mx6q ARM2
So, no need to create one seperate board file for i.mx6dl.
But We can't simply resue anything from the board file since
the i.mx6dl iomux is changed and thus we have to deal with the
difference between i.mx6q and i.mx6dl for the pad setting part.
Signed-off-by: Jason Liu <r64343@freescale.com>
Add suport for i.MX 6Quad SABRE Smart Device.
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
Signed-off-by: Tony Lin <tony.lin@freescale.com>
Signed-off-by: Frank Li <Frank.Li@freescale.com>
add android mx6q sabrelite configure file.
Add support for MX6Q ARM2 LPDDR2 POP CPU Board. Change thing include
- TEXT_BASE
- RAM address and size
- Initialization DCD
- MMU related code
Use mx6q_arm2_lpddr2pop_config as the build config. After u-boot.bin is
generated, set the board to serial download mode, use sb loader to run the
bootloader.
There is one line in the original DDR initialization script
setmem /32 0x00B00000 = 0x1
however this address can not be accessed by DCD. A try to add it later in
"dram_init" block the boot up. Waiting for IC team to give an explanation
on it. Hold temperorily
The MMU Change can be concluded as the following
- Cacheable and Uncacheable SDRAM allocation changes to
Phys Virtual Size Property
0x10000000 0x10000000 256M cacheable
0x80000000 0x20000000 16M uncacheable
0x81000000 0x21000000 240M cacheable
- TEXT_BASE change to 0x10800000, which reserves 8MB of memory at the start
of SDRAM. This address makes sure that the text section of U-boot have the
same Physical and Virtural address, thus the PC don't need to change when
MMU is enabled. Also the text section is all allocated in cacheable memory,
which may increase excecution performance.
- Since this SDRAM allocation avoid overlap in physical memory between
cacheable and uncacheable memory, the implementation of __ioremap can be
ignored
1. Change RAM size from 2GB to 1GB
2. Default boot from MMC Dev 2
Add support for the manufacturing tool on MX6 Sabre-lite
Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
Sabreauto is an inaccurate name for the Armadillo2 board that
this code is actually meant for. So, replaced "sabreauto" in folder names,
file names, configs, and code with "arm2". Created a new machine id for
ARM2 board.
Signed-off-by: Anish Trivedi <anish@freescale.com>
Includes support for uSDHC read, write, FEC, SPI-NOR etc.
add the MFGTOOL support for mx6q.
Signed-off-by: Huang Shijie <b32955@freescale.com>
And new config to enable lpddr2 board with
H9TKNNN4KDMPQR-NDM chip.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add new machine type for pcba.
Add UART, I2C, SD/MMC, PMIC, DDR initial support.
Add MFG tool support.
Add support for MC34708 on revB pcba board.
Update VDDGP setting on MC34708 PMIC for revB board.
Close unused clock, for fastboot it will enable usb_phy
usb_oh3 clock by itself, still need to verify this work
or not when revB bootup.
Signed-off-by: Wayne Zou <b36644@freescale.com>
Use 528M DDR script
Disable L2 cache because rom enable L2 cache when use plug-in
Fix usdhc pad settings
Remove mac address hardcode
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add mx50_rd3_android default config file
Add basic support for UBI partition mount and UBIFS file read for recovery
Add gpmi nand enable in MFG kernel commandline by uboot configure,
which enable MFG tool to flash system images on NAND.
The total NAND boot and NAND recovery has been disabled.
They will be enabled later.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
Add MFG tool support for MX53 ARD DDR3 board.
Assembled With new PMIC chip - MC34708 (Ripley),
and new SPI NOR - M25P32 as well.
Add new config file for RD3.
Signed-off-by: Robby Cai <R63905@freescale.com>
Enable fastboot support for mx50 rdp.
Signed-off-by: Sammy He <r62914@freescale.com>
Added a new config file, the DDR setup is similar to the MX53 Quick
Start & MX53 SABRE-Tablet ref design boards.
- Add MFG tool support for MX53 SMD and MX53 LOCO
boards
- Update mx53 ARD MFG defconfig to pass compile
Add mx53_smd_android config for android build.
Add MX53 LOCO board support
The following functions are tested in the board:
- Micro SD boot
- MMC/SD read/write.
- clk command
- fuse command
Add MX53 SMD support:
- Use DDR3 script for SMD board from Mike Kjar:
"Rita_init_LCB_CMOS.inc"
- Set the default CPU core frequency as 1GHZ.
The following functions are tested on SMD board:
- SD/MMC boot, read, write via SDHC1
- eMMC4.4 boot, read, write via SDHC3.
- SATA boot, read, write. To support SATA boot via internal
clock, please ensure the fuse "SATA_ALT_CLK_REF" was blown.
- FEC
- UART
- clk command
- iim command
Signed-off-by: Liu Ying <b17645@freescale.com>
Signed-off-by: Jason Chen <b02280@freescale.com>
Split different MX53 board files into different folder.
Merge mx50_arm2 to mx50_rdp.
Add fastboot driver support for android. In this commit,
basic fastboot command is supported.
1) Reboot board
>fastboot reboot
2) Get information of board, e.g, product name
>fastboot getvar product
3) Download images in PC and flash to SD card
>fastboot flash bootloader u-boot-no-padding.bin
>fastboot flash kernel uImage
>fastboot flash uramdisk uramdisk.img
>fastboot flash system system.img
>fastboot flash recovery recovery.img
Certainly, SD card must have been formatted as Android user
guider doc already.
Add mx50 rdp board mfg-tool firmware configration
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add default uboot defconfig for MX53 ARD MFG
tool
Add support for building uboot for MX50 reference design platform:
1) LPDDR2 init script (v0.3 from Mike Kjar, dated 9/14)
2) iomux
3) new board file and machine id for RDP
4) Updates for iram boot on RDP
Use serial_mxc as uart driver for all platforms.
Add MX53 Automotive Reference Board (ARD) support
1. Add DDR2 initialization script
2. Add external ethernet support
3. Update PIN settings for UART, I2C, SDHC etc
Rename the folder "mx53_evk" as "mx53_rd" to put
all MX53 board files.
Add android recovery mode support for mx53.
add DDR2 support for U-BOOT.
The infomation about the init script:
Date : Aug-30,2010
Author : Tommy
Version: 0.1
please check :
http://compass.freescale.net/doc/219931536/Codex_DDR2_266MHz.inc.txt
Add mx50 mfg firmware support
Add initial support for MX50
-Support mddr200Mhz, lpddr2266Mhz ARM2 board,
-Support boot from SD/MMC,
-Support boot from SPI-NOR,
-Support FEC, UART,
-Support SD/MMC/SPI command within UBOOT
Add MFG tool support for MX53 EVK
Add DDR3 CPU board support, DDR3 clock 400Mhz
Create one config file for it since the DDR3 init
script is much different wtih DDR2.
Signed-off-by:Jason Liu <r64343@freescale.com>
Change stmp378x to mx23evk in u-boot.
Add mfg firmware support for imx25
Signed-off-by:Yan Wang<r65094@freescale.com>
Both EVK and ARM2 board using the same machine id.
Currently, use system_rev to diff ARM2 board. DDR freq
for ARM2 has been set to 400M, but 300M on EVK.
Build Mfg firmware for mx35 3stack
Signed-off-by: Wallace Wang <r59996@freescale.com>
