path: root/Makefile
2011-10-06Safer timestamp_autogenerated.h generationLoïc Minier
Generate timestamp_autogenerated.h as safely as version_autogenerated.h. Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06Build timestamp_autogenerated.h without configLoïc Minier
Tools such as mkimage include version information but are config-agnostic; build timestamp_autogenerated.h even when config.mk isn't generated to fix "make tools" build failure: gcc [...] -o mkimage.o mkimage.c -c In file included from include/version.h:27:0, from mkimage.c:26: include/timestamp.h:27:37: fatal error: timestamp_autogenerated.h: No such file or directory Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05Makefile: remove mx31pdk exceptionStefano Babic
An entry in the main Makefile for the mx31pdk board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05Makefile: drop imx31_phycore from general MakefileStefano Babic
2011-10-05Makefile: remove tx25 exceptionStefano Babic
An entry in the main Makefile for the tx25 board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-29powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driverYork Sun
Unified DDR driver is maintained for better performance, robustness and bug fixes. Upgrading to use unified DDR driver for MPC83xx takes advantage of overall improvement. It requires changes for board files to customize platform-dependent parameters. To utilize the unified DDR driver, a board needs to define CONFIG_FSL_DDRx in the header file. No more boards will be accepted without such definition. Note: the workaround for erratum DDR6 for the very old MPC834x Rev 1.0/1.1 and MPC8360 Rev 1.1/1.2 parts is not migrated to unified driver. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add support for FMan ethernet in Independent modeKumar Gala
The Frame Manager (FMan) on QorIQ SoCs with DPAA (datapath acceleration architecture) is the ethernet contoller block. Normally it is utilized via Queue Manager (Qman) and Buffer Manager (Bman). However for boot usage the FMan supports a mode similar to QE or CPM ethernet collers called Independent mode. Additionally the FMan block supports multiple 1g and 10g interfaces as a single entity in the system rather than each controller being managed uniquely. This means we have to initialize all of Fman regardless of the number of interfaces we utilize. Different SoCs support different combinations of the number of FMan as well as the number of 1g & 10g interfaces support per Fman. We add support for the following SoCs: * P1023 - 1 Fman, 2x1g * P4080 - 2 Fman, each Fman has 4x1g and 1x10g * P204x/P3041/P5020 - 1 Fman, 5x1g, 1x10g Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Ioana Radulescu <ruxandra.radulescu@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29Prepare v2011.09v2011.09Wolfgang Denk
2011-09-22Prepare v2011.09-rc2v2011.09-rc2Wolfgang Denk
2011-09-11Prepare v2011.09v2011.09-rc1Wolfgang Denk
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04ColdFire:Fix the configuration broken for some boards.Jason Jin
Some typoes in Makefile and boards.cfg make the M54455 board and M53017 board configuration broken. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "edb93xx" boardsWolfgang Denk
Remove edb9301, edb9302, edb9302a, edb9307, edb9307a, edb9312, edb9315 and edb9315a boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-28Correct ih_os for u-boot.imganeeshv
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-28Let source cross-reference targets follow symbolic linksHorst Kronstorfer
Tell 'find' to follow symbolic links, so that files under include/asm and arch/$(ARCH)/include/asm/arch are added to the indexing file list. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-26fix unconfigured out-of-tree building of toolsMike Frysinger
Now that the tools target requires the generated version header file, we need to make sure that the directory it writes to exists. In a configured tree, this is taken care of for us. But in an unconfigured one, the dir does not yet exist causing a build error like so: /bin/sh: line 5: ..../u-boot_build/include/version_autogenerated.h.tmp: No such file or directory So create the dir for this file before we attempt to generate it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26simplify clobber behavior with out-of-tree buildsMike Frysinger
The targets/prerequisites are the same here; the rules only differ in the recipes. So move the if logic protection to the recipe part so we can keep the rest the same. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Hook SPL build-system into toplevel MakefileDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-26Extend build-system for SPL frameworkDaniel Schwierzeck
2011-07-26Use ALL-y style instead of ifeq blocks for better readabilityDaniel Schwierzeck
2011-07-12Blackfin: add init.elf helper codeMike Frysinger
This creates a standalone ELF that executes just the Blackfin initcode. This is useful for people who want to program the low level aspects of the CPU (memory/clocks/etc...) and can easily be used with JTAG for quick booting while developing. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-01Makefile: need to remove generated u-boot-nand_spl.ldsKumar Gala
On MPC85xx based NAND_SPL builds we generate a u-boot-nand_spl.lds based on output from preprocessor. We where never removed it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-06-30nios2: move generic config to boards.cfgMike Frysinger
I can't build test this, but just looking at the config files written and it seems OK ... Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-06-27Prepare v2011.06v2011.06Wolfgang Denk
2011-06-25usb: convert to partial linkingMike Frysinger
Looks like this was missed during the conversion to partial linking. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22Makefile: move $(VERSION_FILE) rule out of ifeq configuredIlya Yanok
mkimage relies on autogenerated version so we need to move $(VERSION_FILE) rule out of ifeq and make tools rule depend on it to be able to run 'make tools' from the unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22config.mk: move LDSCRIPT processing to the top-level MakefileIlya Yanok
LDSCRIPT is used only from the top-level Makefile and only when the system is configured so we can move LDSCRIPT and CONFIG_SYS_LDSCRIPT related logic into the top level Makefile and under configured condition to avoid errors when building tools from unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-22Prepare v2011.06-rc3v2011.06-rc3Wolfgang Denk
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-02Prepare v2011.06-rc2v2011.06-rc2Wolfgang Denk
2011-05-26ARMV7: MMC SPL Boot support for SMDKV310 boardChander Kashyap
Added MMC SPL boot support for SMDKV310. This framework design is based on nand_spl support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-19Prepare v2011.06-rc1v2011.06-rc1Wolfgang Denk
2011-05-12examples: add smc911x_eeprom to clean targetMike Frysinger
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-27nhk8815: move config targets from Makefile to boards.cfgAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
