Migrate to default NAND boot configuration (e.g. colibri_vf50_config)
and SD card boot on request (e.g. colibri_vf50_sdboot_config).
Automatically do the padding required for NAND boot image
(e.g. u-boot.nand).
This is also more in-line with how we did stuff back on the Colibri
T20.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Added from Linux - commit 62aa2b537c6f5957afd98e29f96897419ed5ebab
As mmc_spl now follows SPL infrastructure, removed unwanted
entries in Makefile for mmc_spl related compilation.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
This patch adds support for MMC SPL booting.
This patch is added to replace CONFIG_AM335X symbol
with CONFIG_AM333XX for AM33XX platforms.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Tested-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
Add partial ULPI specification implementation that should be enough to
interface the ULPI PHYs in the boot loader context.
Add a viewport implementation for Chipidea/ARC based controllers.
Signed-off-by: Jana Rapava <fermata7@gmail.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Wolfgang Grandegger <wg@denx.de>
Dave Peverley <dpeverley@mpc-data.co.uk>
Acked-by: Tom Rini <trini@ti.com>
Cc: Kshitij Gupta <kshitij@ti.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
In order to support the coming MX6 platform and to reducde
the duplicated code, we had better move some common files
or functions to the imx-common folder for sharing.
This patch does the following:
- move speed.c file from armv7/mx5/speed.c to armv7/imx-common/speed.c
- move armv7/mx5/timer.c to armv7/imx-common/timer.c, no any new feature
added but just fix the checkpatch errors in the old file and remove
the CONFIG_SYS_MX5_CLK32 reference in the file
- create one new file cpu.c file to store the common function with i.mx5/6
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Cc:Stefano Babic <sbabic@denx.de>
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15
based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15
based SoC's will be sub-classified as Exynos4 and Exynos5 respectively.
In order to better adapt and reuse code across various upcoming Samsung Exynos
based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in
this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix
are renamed as exynos4/EXYNOS4.
* 'master' of git://git.denx.de/u-boot-mpc83xx:
powerpc/83xx: fix sdram initialization for keymile boards
powerpc/mpc83xx: cleanup makefile for mpc83xx
TPM (Trusted Platform Module) is an integrated circuit and
software platform that provides computer manufacturers with the
core components of a subsystem used to assure authenticity,
integrity and confidentiality.
This driver supports version 1.2 of the TCG (Trusted Computing
Group) specifications.
The TCG specification defines several so called localities in a
TPM chip, to be controlled by different software layers. When
used on a typical x86 platform during the firmware phase, only
locality 0 can be accessed by the CPU, so this driver even while
supporting the locality concept presumes that only locality zero
is used.
This implementation is loosely based on the article "Writing a
TPM Device Driver" published on http://ptgmedia.pearsoncmg.com
Compiling this driver with DEBUG defined will generate trace of
all accesses to TMP registers.
This driver has been tested and is being used in three different
functional ChromeOS machines (Pinetrail and Sandy Bridge Intel
chipsets) all using the same Infineon SLB 9635 TT 1.2 device.
A u-boot cli command allowing access to the TPM was also
implemented and is being submitted as a second patch.
Change-Id: I22a33c3e5b2e20eec9557a7621bd463b30389d73
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
CC: Wolfgang Denk <wd@denx.de>
It is sometimes desireable to clean up the byproducts of the build
process without removing the executable results. "make clean" is
close, but leaves the build directory with a large number of
*.depend* files. This new build option invokes make clean, and then
removes the depend files.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
Instead of linking the file into $(obj) tree use directly the source file.
This also prevents littered source tree if building not out-of-tree.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
* 'sr@denx.de' of git://git.denx.de/u-boot-staging:
Makefile: Add the missing dependency for spl target
gpio: Adapt PCA9698 to standard GPIO API
Wolfgang's patch for build time improvement is bringing
out issues due to missing dependencies in the top-level
Makefile. I get errors such as the below while building
with many threads.
make[1]: /home/a0393566local/u-boot-denx/tools/mkimage: Command not found
This also allows one to do:
$ make spl/u-boot-spl.bin
if you want to build only spl
Signed-off-by: Aneesh V <aneesh@ti.com>
* 'master' of git://git.denx.de/u-boot-video:
api: export LCD device to external apps
font: split font data from video_font.h
tools: logo: split bmp arrays from bmp_logo.h
lcd: add clear and draw bitmap declaration
VIDEO: mx3fb: GCC4.6 fix build warnings
Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bug
The generated header bmp_logo.h is useful even outside common/lcd.c for
the logo dimension. However, the problem is, the generated bmp_logo.h
cannot be included multiple times because bmp_logo_palette[] and
bmp_logo_bitmap[] are defined in the bmp_logo.h.
This patch fixes this by defining these arrays in another header
bmp_logo_data.h and in bmp_logo.h only declaring these arrays.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This patch adds the build support for the
omap5_evm board.
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Remove symbolic link generated by compiling. Fix makefile for out-of-tree
compiling error.
Signed-off-by: York Sun <yorksun@freescale.com>
Cc: Detlev Zundel <dzu@denx.de>
* 'master' of git://git.denx.de/u-boot-arm:
Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board
arm: jadecpu: Readd MACH_TYPE_JADECPU
at91: defined mach-types for otc570 board in board config file
at91: defined mach-types for meesc board in board config file
mx31pdk: Enable D and I caches
ehci-mxc: remove incorrect comment
README: Fix supported i.MX SoC list for CONFIG_MXC_SPI
mx53: Turn off child clocks before reconfigure perclk_root
qong: enable support for compressed images
imx: imx31_phycore.h: fix checkpatch warnings
vision2: Remove unused get_board_rev function
mx53smd: Remove unused get_board_rev function
mx53ard: Remove unused get_board_rev function
mx53evk: Remove unused get_board_rev function
mx53evk: Add RTC support
mx53loco: Remove unused get_board_rev function
mx53evk: Remove unneeded '1' from mx53evk.h
OMAP3: mvblx: Initial support for mvBlueLYNX-X
ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE
omap3: mem: Move comments next to definitions
omap3: mem: Clean-up whitespaces
omap3: mem: Define and use common macros
Davinci: ea20: added PREBOOT to configuration
Davinci: ea20: added I2C support
Davinci: ea20: added video support
VIDEO: davinci: add framebuffer to da8xx
ARM: Davinci: added missing registers to hardware.h
Davinci: ea20: add gpios for LCD backlight control
Davinci: ea20: add gpio for keeping power on in board_late_init
Davinci: ea20: Add default U-Boot environment
Davinci: ea20: Add early init to get early output from console
Davinci: ea20: Add NAND support
Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console
Davinci: ea20: set console on UART0
arm, davinci: add cam_enc_4xx support
arm926ejs, davinci: add missing spi defines for dm365
arm926ejs, davinci: add cpuinfo for dm365
arm, davinci: add lowlevel function for dm365 soc
arm, davinci: add header files for dm365
spl, nand: add 4bit HW ecc oob first nand_read_page function
arm, davinci: add support for new spl framework
spl: add option for adding post memory test to the SPL framework
net, davinci_emac: make clock divider in MDIO control register configurable
arm, usb, davinci: make USBPHY_CTL register configurable
usb, davinci: add enable_vbus() weak function
omap3evm: fix errors caused by multiple definitions
omap3evm: Add (quick) configuration for NAND only
omap3evm: Add (quick) configuration for MMC/SD only
omap3evm: move common config options to new file
omap3evm: Prepare to split configuration
omap3evm: Reorder related config options
omap/spl: actually enable the console
davinci_emac: compilation fix, phy is array now
omap3evm: Set environment variable 'ethaddr'
arm, arm926: fix missing symbols in NAND_SPL mode
arm, davinci: Add function lpsc_syncreset()
arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD
arm/km: portl2 environment address update to P1B
arm/km: adapt bootcounter evaluation
arm/km: enable jffs2 cmds
arm/km: trigger reconfiguration for the Xilinx FPGA
arm/km: add boardid and hwkey to kernel command line
ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards
netspace_v2: enable I2C EEPROM support
netspace_v2: fix SDRAM configuration
armada100: define CONFIG_SYS_CACHELINE_SIZE
pantheon: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: drop empty asm-offsets.s file
arm/km/mgcoge3un: enhance "waitforne" feature
arm/km: add variable waitforne to mgcoge3un
gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared
ARM: dreamplug: fix compilation
ARM: DockStar: fix compilation
ARM: netspace_v2: fix warnings
am335x: Drop board_sysinfo struct
am335x: Temporarily add MACH_TYPE define
misc:pmic:samsung Enable PMIC driver at C210 Universal target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target
smdkv310: use macro for mmc data read function address
smdkv310: use spl framework for mmc spl
SMDKV310: use get_ram_size() to validate dram size
SMDKV310: Initialize board id using CONFIG_MACH_TYPE
ORIGEN : use absolute paths and fix tool naming
ORIGEN : enable device tree support
MX25: tx25: Fix building due to missing MACH_TYPE
mx31: Add board support for HALE TT-01
mx31: add ESD control registers
mx31: define pins and init for UART2 and CSPI3
MX35: add support for flea3 board
MX51: vision2: add MACH_TYPE in config file
vision2: Remove unused header file
mx51evk: Remove unused get_board_rev function
mx51evk: Remove unneeded '1' from mx51evk.h
I2C: Fix mxc_i2c.c problem on imx31_phycore
mx35pdk: Add RTC support
mx51evk: Use GPIO API for configuring the IOMUX
mx51evk: Add RTC support
rtc: Make mc13783-rtc driver generic
qong: remove unneeded IOMUX settings
qong: Use mx31_set_gpr to setup USBH2 pins
mx31: Introduce mx31_set_gpr function
mx31pdk: Add MC13783 PMIC support
qong: remove unneeded "1" from qong.h
misc: pmic: fix regression in pmic_fsl.c (SPI)
mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME
MX35: Drop unnecessary prototypes from imx-regs.h
I2C: added I2C-2 and I2C-3 to MX35
MX35: factorize common assembly code
MX35: add reset cause as provided by other i.MX
MX35: add pins definition for UART3
MX35: added ESDC structure to imx-regs
Move the coldfire boards to boards.cfg. The config name
for the EB+MCF-EV123 boards are changed to EB-MCF-EV123
as the '+' cannot be recognized.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Scott Wood <scottwood@freescale.com>
The check for sandbox architecture is too early in the Makefile, so
standalone and api are built regardless. This moves the check until
after autoconf.mk has been read.
This fixes a build breakage.
U-Boot Makefiles contain a number of tests for compiler features etc.
which so far are executed again and again. On some architectures
(especially ARM) this results in a large number of calls to gcc.
This patch makes sure to run such tests only once, thus largely
reducing the number of "execve" system calls.
Example: number of "execve" system calls for building the "P2020DS"
(Power Architecture) and "qong" (ARM) boards, measured as:
-> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board>
-> grep execve /tmp/foo | wc -l
Before: After: Reduction:
P2020DS 20555 15205 -26%
qong 31692 14490 -54%
As a result, built times are significantly reduced, typically by
30...50%.
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Albert Aribaud <albert.aribaud@free.fr>
cc: Graeme Russ <graeme.russ@gmail.com>
cc: Mike Frysinger <vapier@gentoo.org>
Tested-by: Graeme Russ <graeme.russ@gmail.com>
Tested-by: Matthias Weisser <weisserm@arcor.de>
Tested-by: Sanjeev Premi <premi@ti.com>
Tested-by: Macpaul Lin <macpaul@gmail.com>
This patch adds timer support for AM33xx platform.
This adds support for an FDT to be build as a separate binary file called
u-boot.dtb. This can be concatenated with the U-Boot binary to provide a
device tree located at run-time by U-Boot. The Makefile is modified to
provide this file in u-boot-dtb.bin.
This new option allows U-Boot to embed a binary device tree into its image
to allow run-time control of peripherals. This device tree is for U-Boot's
own use and is not necessarily the same one as is passed to the kernel.
The device tree compiler output should be placed in the $(obj)
rooted tree. Since $(OBJCOPY) insists on adding the path to the
generated symbol names, to ensure consistency it should be
invoked from the directory where the .dtb file is located and
given the input file name without the path.
This commit contains my entry for the ugliest Makefile / shell interaction
competition.
The current autoconf.mk.dep rule uses the host cflags when executing the
target compiler (which includes target header files). We don't want to
mix the target compiler and host compiler flags, so change it to CFLAGS.
Otherwise we get things like -pedantic which the U-Boot source code does
not build with.
SPL builds could leave an MLO which is an mkimage of type omapimage
Make sure its deleted on make clean/distclean
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
The examples/api is not configured with USE_PRIVATE_LIBGCC. This makes
building examples/api break on certain boards that do not/cannot use the
public libgcc.
Nevertheless, this patch has to also touch the top-level Makefile to fix
this problem because the current top-level Makefile does not specify
libgcc as a prerequisite of examples/api, and explicitly builds
examples/api _before_ libgcc.
For testing this patch, I added the following to configs/seaboard.h and
ran demo.bin on a Seaboard.
+#define CONFIG_API
+#define CONFIG_SYS_MMC_MAX_DEVICE 2
+#define CONFIG_CMD_NET
+#define CONFIG_NET_MULTI
Remove unused mkdir, and add missing ones.
Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
The spa, stm, int, 32 and 16 linking files are identical so there is
no need to differentiate them. A single lds file is now used, and
_config rule are simplified.
There is a rather subtle build problem where the build time stamp is not
updated for out-of-tree builds if there exists an in-tree build which
has a valid timestamp file. So if you do an in-tree build, then an
out-of-tree build your timestamp will not change.
The correct timestamp_autogenerated.h lives in the object tree, but it
is not always found there. The source still lives in the source tree and
when compiling version.h, it includes timestamp_autogenerated.h. Since
the current directory is always searched first, this will come from the
source tree rather than the object tree if it exists there. This affects
dependency generation also, which means that common/cmd_version.o will not
even be rebuilt if you have ever done an in-tree build.
A similar problem exists with the version file.
This change moves both files into the 'generated' subdir, which is already
used for asm-offsets.h. Then timestamp.h and version.h are updated to
include the files from there.
There are other places where these generated files are included, but I
cannot see why these don't just use the timestamp.h and version.h headers.
So this change also tidies that up.
I have tested this with in- and out-of-tree builds, but not SPL. I have
looked at various other options for fixing this, including sed on the dep
files, -I- and -include flags to gcc, but I don't think they can be made
to work. Comments welcome.
At this point U-Boot will build and run on x86 under Linux.
The idea is to define a new architecture called 'sandbox', alongside ARM
and x86. This runs natively on Linux to suit the host machine. All
hardware access is either omitted or emulated.
The purpose of this system is to test the bulk of the non-hardware-specific
U-Boot code. We can mock the SPI flash, GPIOs, UART and keyboard, then test
that U-Boot behaves as we wish.
The dependency rules are currently done in a shell 'for' loop. This does not
permit Makefile variables to adjust preprocessor flags as is done with normal
compile flags, using the CFLAGS_path/file.o syntax.
This change moves the dependency generation into the Makefile itself, and
permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or
directory basis.
The CPPFLAGS_... variable is also folded into CFLAGS during the build.
This is not useful on the sandbox architecture since we can simply link all
our code with U-Boot.
Generate timestamp_autogenerated.h as safely as version_autogenerated.h.
Cc: patches@linaro.org
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
