2005-11-30 | Add support for TQM8541/8555 boards, TQM85xx support reworked: | Stefan Roese | |
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005 | |||
2005-11-29 | Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board. | Stefan Roese | |
Patch by John Otken, 23 Nov 2005 | |||
2005-11-22 | Add support for Prodrive P3P440 board: | Stefan Roese | |
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005 | |||
2005-11-15 | New PPC 405EP board added: CMS700 | Stefan Roese | |
Added CONFIG_NET_MULTI for VOM405 board. Added reset_phy() for VOM405 board. Patch by Matthias Fuchs, 09 Nov 2005 | |||
2005-10-15 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2005-10-13 | Support passing of OF flat trees to the kernel. | Wolfgang Denk | |
Patch by Pantelis Antoniou, 04 Sep 2005 | |||
2005-10-11 | Added support for TQM834x boards. | Marian Balakowicz | |
2005-10-09 | Add support for AP1000 board. | Wolfgang Denk | |
Patch by James MacAulay, 07 Oct 2005 | |||
2005-10-09 | Cleanup warnings for cpu/arm720t & cpu/arm1136 files. | Wolfgang Denk | |
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005 | |||
2005-10-06 | Make "split_by_variant.sh" executable. | Wolfgang Denk | |
2005-10-06 | Update make target for ARM supported boards. | Wolfgang Denk | |
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005 | |||
2005-10-05 | Add support for Cogent csb637 | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 | |||
2005-10-05 | Added support for KwikByte KB920x boards (based on AT91RM9200) | Wolfgang Denk | |
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005 | |||
2005-09-26 | Add support for MP2USB board. | Wolfgang Denk | |
Patch by Eric Benard, 07 Apr 2005 | |||
2005-09-26 | Add board support for armadillo HT1070 | Wolfgang Denk | |
Patch by Rowel Atienza, 06 Apr 2005 | |||
2005-09-25 | Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) board | Wolfgang Denk | |
Patch by Marc Leeman, 04 Mar 2005 | |||
2005-09-25 | Cleanup | Wolfgang Denk | |
2005-09-25 | Add ARM946E cpu and core module targets; remap memory to 0x00000000 | Wolfgang Denk | |
Patch by Peter Pearse, 2 Feb 2005 | |||
2005-09-25 | Add support for AMD's Pb1x00 eval board; | Wolfgang Denk | |
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005 | |||
2005-09-22 | esd CPCI2DP board added | Stefan Roese | |
Patch by Matthias Fuchs, 22 Sep 2005 | |||
2005-08-22 | Add esd cpci5200 and pf5200 boards | Stefan Roese | |
Patch by Reinhard Arlt, 22 Aug 2005 | |||
2005-08-18 | Add 82dnt board support | Wolfgang Denk | |
2005-08-18 | Add CHANEGLOG entry; sort Makefile entries | Wolfgang Denk | |
2005-08-18 | Minor Makefile cleanup | Wolfgang Denk | |
2005-08-16 | Merge with pollux.denx.org:/home/git/u-boot/.git | ||
2005-08-15 | Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board. | Wolfgang Denk | |
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005 | |||
2005-08-15 | Add Sandburst Metrobox and Sandburst Karef board support packages. | Stefan Roese | |
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005 | |||
2005-08-13 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-13 | make "make clean" remove all build results | Wolfgang Denk | |
2005-08-12 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-12 | Make "tr" command use POSIX compliant; export HOSTOS make variable | Wolfgang Denk | |
Patch by Murray Jensen, 30 Jun 2005 | |||
2005-08-12 | Merge with pollux.denx.org:/home/git/u-boot/.git | ||
2005-08-12 | Merge with /home/wd/git/u-boot/masterLABEL_2005_08_12_0050 | Wolfgang Denk | |
2005-08-10 | Add configuration for IFM AEV FIFO board. | Wolfgang Denk | |
Minor coding style cleanup. | |||
2005-08-10 | Add configuration for IFM SPI eval board | Wolfgang Denk | |
2005-08-09 | Added support for O2DNT board. | ||
2005-08-08 | Fix dbau1xxx (= MIPS big and little endian) build options. | Wolfgang Denk | |
Incorrect gcc options (big endian -BE switch) were used for dbau1550_el which is a little endian build; also get rid of reference to non-existant cpu/mips/little/liblittle.a library | |||
2005-08-06 | Add support for ep8248 board | Wolfgang Denk | |
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup. | |||
2005-08-05 | Merge with /home/wd/git/u-boot/jon_loeliger | Wolfgang Denk | |
2005-08-05 | Add support for MicroSys PM856 board | Wolfgang Denk | |
Patch by Josef Wagner, 03 Aug 2005 | |||
2005-08-05 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-03 | Cleanup build problems (on Fedora Core x86_64 build host) | Wolfgang Denk | |
2005-08-02 | Merge with rsync://git-user@source.denx.net/git/u-boot.git | Jon Loeliger | |
2005-08-01 | Major cleanup for AMCC PPC4xx eval boards. | Stefan Roese | |
Patch by Stefan Roese, 01 Aug 2005 | |||
2005-07-29 | * Patch by Ron Alder, 11 July 2005 | Lunsheng Wang | |
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board. | |||
2005-07-28 | * Patch by Eran Liberty | Eran Liberty | |
Add support for the Freescale MPC8349ADS board. | |||
2005-07-25 | * Patch by Jon Loeliger, 2005-05-05 | Jon Loeliger | |
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O | |||
2005-06-10 | * Add support for HMI1001 board | wdenk | |
* Disable "date" and "sntp" commands on TQM866M which has no RTC | |||
2005-05-30 | Patch by Juergen Selent, 17 May 2005: | wdenk | |
Add support for Funkwerk VoVPN gateway module. | |||
2005-05-19 | Patch by Greg Ungerer, 19 May 2005: | wdenk | |
add support for the OpenGear CM4008 board |
