path: root/Makefile
2016-01-14arm: mvebu: Add runtime detection of UART (xmodem) boot-modeStefan Roese
This patch adds runtime detection of the Marvell UART boot-mode (xmodem protocol). If this boot-mode is detected, SPL will return to the BootROM to continue the UART booting. With this patch its now possible, to generate a U-Boot image that can be booted either from the strapped boot-device (e.g. SPI NOR, MMC, etc) or via the xmodem protocol from the UART. In the UART case, the kwboot tool will dynamically insert the UART boot-device type into the image. And also patch the load address in the header, so that the mkimage header will be skipped (as its not expected by the Marvell BootROM). This simplifies the development for Armada XP / 38x based boards. As no special images need to be generated by selecting the MVEBU_BOOTROM_UARTBOOT Kconfig option. Since the Kconfig option MVEBU_BOOTROM_UARTBOOT is not needed any more, its now completely removed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-12Prepare v2016.01v2016.01Tom Rini
2016-01-08arm, Makefile: correct compilation flag for u-boot-dtbAneesh Bansal
The compilation of u-boot-dtb.img should be controlled by CONFIG_OF_CONTROL and not CONFIG_DM. CONFIG_DM may be defined even without Device Tree requirement. This was added in commit 947cee1127c5fa97529c8cda4f0b48d141f92560. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
2016-01-04Prepare v2016.01-rc4v2016.01-rc4Tom Rini
2015-12-21Prepare v2016.01-rc3v2016.01-rc3Tom Rini
2015-12-07Prepare v2016.01-rc2v2016.01-rc2Tom Rini
2015-11-19ARM: zynq: Add target for building bootable SPL image for ZynqNathan Rossi
Add a build target to generate 'boot.bin' which includes SPL. This is used by the platforms BootROM to load SPL directly. This change also conditionally changes what the 'boot.bin' target generates depending on the SoC. Leaving the behaviour unchanged for the AT91 targets. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-16Prepare v2016.01-rc1v2016.01-rc1Tom Rini
2015-11-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-10arm: support Thumb-1 with CONFIG_SYS_THUMB_BUILDAlbert ARIBAUD
When building a Thumb-1-only target with CONFIG_SYS_THUMB_BUILD, some files fail to build, most of the time because they include mcr instructions, which only exist for Thumb-2. This patch introduces a Kconfig option CONFIG_THUMB2 and uses it to select between Thumb-2 and ARM mode for the aforementioned files. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-26arm: ls1021a: Add QSPI or IFC support in SD bootAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021atwr_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021atwr_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-21Merge git://git.denx.de/u-boot-x86Tom Rini
2015-10-21Makefile: Generate U_BOOT_DMI_DATE for SMBIOSBin Meng
Add U_BOOT_DMI_DATE (format mm/dd/yyyy) generation to be used by SMBIOS tables, as required by SMBIOS spec 3.0 [1]. See chapter 7.1, BIOS information structure offset 08h for details. [1] http://www.dmtf.org/sites/default/files/standards/documents/DSP0134_3.0.0.pdf Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Add DM (driver model) supportStefan Roese
This patch adds driver model support for some Marvell MVEBU SoC's. Including Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now selected automatically for MVEBU platforms. With this DM support now available for MVEBU, hardcoding the base addresses and other information is not necessary any more. Probing should be done by using the values provided via the device tree now instead. For this the driver also need to be converted to DM. Patches for some of the drivers will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-21arm: mvebu: Add option to use UART xmodem protocol via kwbootStefan Roese
This patch enables the use of the kwboot tool, to boot mainline U-Boot on the Marvell Armada XP/38x SoC's. This is done by returning to the SoC's BootROM after SPL has initialized the SDRAM. We need to make sure to not reconfigure the internal register space and MBARs. Otherwise the BootROM will not be able to continue after SPL jumps back to it. To use this feature, please don't forget to change the BOOT_FROM line in your board specfic kwbimage.cfg file this way: BOOT_FROM uart Tested on these Marvell eval boards: DB-MV784MP-GP - Armada XP DB-88F6820-GP - Armada 38x Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Kevin Smith <kevin.smith@elecsyscorp.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-19Prepare v2015.10v2015.10Tom Rini
2015-10-12Prepare v2015.10-rc5v2015.10-rc5Tom Rini
2015-09-28Prepare v2015.10-rc4v2015.10-rc4Tom Rini
2015-09-07Prepare v2015.10-rc3v2015.10-rc3Tom Rini
2015-08-28Makefile: fix SOURCE_DATE_EPOCH for *BSD hostAndreas Bießmann
The SOURCE_DATE_EPOCH mechanism for reproducible builds require some date(1) with -d switch to print the relevant date and time strings of another point of time. In other words it requires some date(1) that behaves like the GNU date(1) [1]. The BSD date(1) [2] on the other hand has the same switch but with a different meaning. Respect this and check the date(1) abilities before usage, error on non working version. Use the well known pre- and suffixes for the GNU variant of a tool on *BSD hosts to search for a working date(1) version. [1] http://man7.org/linux/man-pages/man1/date.1.html [2] http://www.freebsd.org/cgi/man.cgi?query=date Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-28ARM: keystone2: move the custom build rules out to keystone specific makefileNishanth Menon
Keystone has build rules introduced by commit ef509b9063fb7 ("k2hk: add support for k2hk SOC and EVM") and commit 0e7f2dbac6ead ("keystone: add support for NAND gpheader image"). These are not reused by other platforms for the build, hence there is no clear benefit is maintaining them in the generic makefile as a build target. move these to the keystone specific make option Original idea of using config.mk by Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-28Makefile: Use correct timezone for U_BOOT_TZChris Packham
When building with SOURCE_DATE_EPOCH the timezone is in UTC. When building normally the timezone is taken from the build machine's locale setting. Signed-off-by: Chris Packham <judge.packham@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-26x86: ifdtool: Support collating microcode into one placeSimon Glass
The Intel Firmware Support Package (FSP) requires that microcode be provided very early before the device tree can be scanned. We already support adding a pointer to the microcode data in a place where early init code can access. However this just points into the device tree and can only point to a single lot of microcode. For boards which may have different CPU types we must support multiple microcodes and pass all of them to the FSP in one place. Enhance ifdtool to scan all the microcode, place it together in the ROM and update the microcode pointer to point there. This allows us to pass multiple microcode blocks to the FSP using its existing API. Enable the flag in the Makefile so that this feature is used by default for all boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-17Prepare v2015.10-rc2v2015.10-rc2Tom Rini
2015-08-08Makefile: Add target for building bootable SPL image for SoCFPGAMarek Vasut
Add build target for generating boot partition images recognised by the SoCFPGA BootROM. The SoCFPGA BootROM expects four copies of the u-boot-spl-dtb.sfp at the beginning of boot partition. Those are u-boot-spl-dtb.bin augmented by a header with which the BootROM can work. The u-boot-dtb.img uImage is appended to this to produce a full boot partition image, the u-boot-with-spl-dtb.sfp . This is the name of the final target. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08driver/ddr/altera: Add DDR driver for Altera's SDRAM controllerDinh Nguyen
This patch enables the SDRAM controller that is used on Altera's SoCFPGA family. This patch configures the SDRAM controller based on a configuration file that is generated from the Quartus tool, sdram_config.h. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-08-05efi: Add 64-bit payload supportSimon Glass
Most EFI implementations use 64-bit. Add a way to build U-Boot as a 64-bit EFI payload. The payload unpacks a (32-bit) U-Boot and starts it. This can be enabled for x86 boards at present. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Support building a u-boot-app.efi executableSimon Glass
Add support for building U-Boot as an EFI application with a .efi suffix. This can be loaded by EFI provided that EFI has the same bit width (32- or 64-bit) as U-Boot. This unfortunate limitation is imposed by EFI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Allow objcopy to work without filling gaps with 0xffSimon Glass
This is currently done for all targets, since 0xff is the default erased value for most flash devices. In some cases this is not what we want (e.g. for EFI images) so provide a command to do a vanilla objcopy. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-03Prepare v2015.10-rc1v2015.10-rc1Tom Rini
2015-07-31Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-07-31powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P3041Aneesh Bansal
Secure Boot Target is added for NAND for P3041. For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC. In case of secure boot, this default address maps to Boot ROM. The Boot ROM code requires that the bootloader(U-boot) must lie in 0 to 3.5G address space i.e. 0x0 - 0xDFFFFFFF. In case of NAND Secure Boot, CONFIG_SYS_RAMBOOT is enabled and CPC is configured as SRAM. U-Boot binary will be located on SRAM configured at address 0xBFF00000. In the U-Boot code, TLB entries are created to map the virtual address 0xFFF00000 to physical address 0xBFF00000 of CPC configured as SRAM. Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-27Reproducible U-Boot build support, using SOURCE_DATE_EPOCHPaul Kocialkowski
In order to achieve reproducible builds in U-Boot, timestamps that are defined at build-time have to be somewhat eliminated. The SOURCE_DATE_EPOCH environment variable allows setting a fixed value for those timestamps. Simply by setting SOURCE_DATE_EPOCH to a fixed value, a number of targets can be built reproducibly. This is the case for e.g. sunxi devices. However, some other devices might need some more tweaks, especially regarding the image generation tools. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-27kbuild: use relative path more to include MakefileMasahiro Yamada
Prior to this commit, it was impossible to use relative path to include Makefiles from the top level Makefile because the option "--include-dir=$(srctree)" becomes effective when Make enters into sub Makefiles. To use relative path in any places, this commit moves the option above the "sub-make" target. This was imported from Linux (commit a436bb7b8063) and adjusted for U-Boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-07-27kbuild: sync with Linux 4.1Masahiro Yamada
Update some build scripts to match Linux 4.1. Commit-based syncing was done so as not to break U-Boot specific changes. The previous big sync was from Linux 3.18-rc1 by commit 176d09827725 (kbuild: sync misc scripts with Linux 3.18-rc1). The commits imported from Linux (some with adjustments) are: [1] commit 9fb5e5372208973984a23ee6f5f025c05d364633 Author: Robert Richter <rrichter@cavium.com> dts, kbuild: Factor out dtbs install rules to Makefile.dtbinst [2] commit 371fdc77af44f4cb32475fd499e1d912ccc30890 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: collect shorthands into scripts/Kbuild.include [3] commit a29b82326ed4eb5567b03c85b52c6891578d5a03 Author: Michal Marek <mmarek@suse.cz> kbuild: Remove duplicate $(cmd) definition in Makefile.clean [4] commit 1846dfbde3e8a53f3673dcb1c1b79fd9b3f8d40d Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: remove redundant -rR flag of hdr-inst [5] commit 34948e0bbf98640fc1821751b01d2f0cd17d84d5 Author: Michal Marek <mmarek@suse.cz> kbuild: Drop support for clean-rule [6] commit a16c5f99a28c9945165c46da27fff8e6f26f8736 Author: Michal Marek <mmarek@suse.cz> kbuild: Fix removal of the debian/ directory [7] commit d0d38cd9e853db11e0242b3df4c9c3c4a663fbb4 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: use mixed-targets when two or more config targets are given [8] commit dd33c03b18b3f2db791eb6a17c37d2de66e4de18 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: fix cc-ifversion macro [9] commit 665d92e38f65d70796aad2b8e49e42e80815d4a4 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion [10] commit 6dcb4e5edf39e3b65a75ca76f087b2fdbee8a808 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: allow cc-ifversion to have the argument for false condition [11] commit c0a80c0c27e5e65b180a25e6c4c2f7ef9e386cd3 Author: Heiko Carstens <heiko.carstens@de.ibm.com> ftrace: allow architectures to specify ftrace compile options [12] commit 0b24becc810dc3be6e3f94103a866f214c282394 Author: Andrey Ryabinin <a.ryabinin@samsung.com> kasan: add kernel address sanitizer infrastructure [13] commit 4218affdf57f938c04e3a916a9685ee27079f377 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: remove warning about "make depend" [14] commit 77479b38e2f58890eb221a0418357502a5b41cd6 Author: Nathan Rossi <nathan.rossi@xilinx.com> kbuild: Create directory for target DTB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-07-23Merge git://git.denx.de/u-boot-marvellTom Rini
2015-07-23Makefile: Fix mvebu build target to use SPL load and exe-addressStefan Roese
The u-boot-spl.kwb build target needs the SPL text-base (CONFIG_SPL_TEXT_BASE) as load and execution address. Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-21dm: Reduce SPL device tree sizeSimon Glass
The SPL device tree size must be minimised to save memory. Only include properties that are needed by SPL - this is determined by the presence of the "u-boot,dm-pre-reloc" property. Also remove a predefined list of unused properties from the nodes that remain. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: Move VGA option rom macros to KconfigBin Meng
Move X86_OPTION_ROM_FILE & X86_OPTION_ROM_ADDR to arch/x86/Kconfig and rename them to VGA_BIOS_FILE & VGA_BIOS_ADDR which depend on HAVE_VGA_BIOS. The new names are consistent with other x86 binary blob options like HAVE_FSP/FSP_FILE/FSP_ADDR. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14Prepare v2015.07v2015.07Tom Rini
2015-07-08Makefile:Add GCC flag -fno-delete-null-pointer-checksPrabhakar Kushwaha
-fdelete-null-pointer-checks flag controls global dataflow analyses and eliminate useless checks for null pointers; It assume that if a pointer is checked after it has already been dereferenced, it cannot be null. This flag is enabled by default. gcc v4.9 has more optimizations added to this option. Hence it is very aggressive with GCC v4.9 series. Add -fno-delete-null-pointer-checks to disable the optimization Signed-off-by: Rohit Dharmakan <rohitarulraj@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2015-06-29Prepare v2015.07-rc3v2015.07-rc3Tom Rini
2015-06-08Prepare v2015.07-rc2v2015.07-rc2Tom Rini
2015-05-28kbuild: define DO_DEPS_ONLY for u-boot.cfg to fix build errorMasahiro Yamada
Since 741e58e0fc8e (Create a .cfg file containing the CONFIG options used to build), all the Blackfin boards fail to build if the parallel (-j) option is passed. $ make -s bf506f-ezkit_defconfig # # configuration written to .config # $ make -j8 CROSS_COMPILE=bfin-elf- scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h UPD include/config.h GEN include/autoconf.mk GEN include/autoconf.mk.dep CHK include/config/uboot.release CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CFG u-boot.cfg include/asm-offsets.h:3:43: fatal error: generated/generic-asm-offsets.h: No such file or directory compilation terminated. make: *** [u-boot.cfg] Error 1 When parsing header files for defined CONFIG options, DO_DEPS_ONLY must be defined to exclude generated headers that might not have been available yet. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-27Makefile: Add U_BOOT_TZ and include in versionChris Packham
Define U_BOOT_TZ alongside U_BOOT_TIME and U_BOOT_DATE and use it to include the timezone in the version output. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2015-05-21test: env: Add test framework for envJoe Hershberger
Add a new "env" subcommand to the ut command. This will run unit tests on the env code. This should be targetable to any device that supports the env features needed for the tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: regulator: add implementation of driver model regulator uclassPrzemyslaw Marczak
This commit introduces the implementation of dm regulator API. Device tree support allows for auto binding. And by the basic uclass operations, it allows to driving the devices in a common way. For detailed informations, please look into the header file. Core files: - drivers/power/regulator-uclass.c - provides regulator common functions api - include/power/regulator.h - define all structures required by the regulator Changes: - new uclass-id: UCLASS_REGULATOR - new config: CONFIG_DM_REGULATOR Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-10Makefile: add a symbol link tags for ctagsDu Huanpeng
Signed-off-by: Du Huanpeng <u74147@gmail.com>
