path: root/Makefile
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19Makefile: rename TEXT_BASE to CONFIG_SYS_TEXT_BASEEric Cooper
2010-10-19Makefile: allow boards to check file size limitsMike Frysinger
Boards often have a reserved size limit on the flash where they're stored. Sometimes during upgrades or config changes, those limits are exceeded, but no one notices until they try to upgrade and the limit screws things up. Either not enough of U-Boot is written to flash (and so the reboot fails), or too much is written (and so things after it get clobbered). So allow boards to declare a size limit (in bytes) and have the build system check it while building. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-19Build: PXA: Fix TrizepsIV build variantsMarek Vasut
2010-10-19Build: PXA: Fix Vpac270 build variantsMarek Vasut
2010-10-19PXA: Fix vpac270 OneNAND booterMarek Vasut
NOTE: The modification in Makefile will be superseded by a pending patch! Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-18Makefile: clean MatrixVision buildsWolfgang Denk
"make clean" after builds of MatrixVision boards would leave stale files around: board/matrix_vision/mvblm7/bootscript.img board/matrix_vision/mvsmr/bootscript.img Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-13Fix define for MPC5121 ADS board.mark.vels@team-embedded.nl
Originally the Makefile defines CONFIG_ADS5121_REV2 when configuring for board mpc5121ads_rev2. The config in include/configs/mpc5121ads.h expects a define CONFIG_MPC5121ADS_REV2 for this. Therefore there are two defines used but only 1 is defined. This patch renames references to CONFIG_ADS5121_REV2 to CONFIG_MPC5121ADS_REV2 to have one common define. This patch fixes faulty mem size detection caused by wrong config in include/configs/mpc5121ads.h Signed-off-by: Mark Vels <mark.vels@team-embedded.nl>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28Prepare v2010.09v2010.09Wolfgang Denk
2010-09-19unify toplevel tools targetsMike Frysinger
Most tool subdirs do not rely on a configured tree, so move those targets out of the config checks and unify them in the process. Also add an easylogo target so people can easily build that. Also add these new tool targets to the 'tools-all' target. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19Makefile: restore support for board shortcut targetsMike Frysinger
The helpful shortcut for doing a board config + make was dropped recently as it conflicted with some new build code. However, the reason for using pattern targets originally was to avoid managing a duplicate list of boards. Since we now have one centralized place for a list of boards (the new boards.cfg), we don't need a pattern target -- we can generate the exact list of boards on the fly. So do just that. When cleaning things up, the top level gitignore file ignores all things that end with ".depend", but the clean target only deletes files that are named exactly ".depend". Keep these in sync by having the clean target punt all files that match the pattern that gitignore is using. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-19Prepare v2010.09-rc2v2010.09-rc2Wolfgang Denk
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-08Merge branch 'at91' of git://git.denx.de/u-boot-atmelWolfgang Denk
2010-09-08Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-08-23ARMV7: S5P: make s5p-common for sharing the code between s5pc1xx and s5pc2xxMinkyu Kang
This patch adds basic support for s5pc210. s5p-common will be used by all of s5p SoCs. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-20cpuat91: convert to new at91 soc architectureEric Bénard
convert the board to the new soc architecture update default config i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-07-26powerpc/p2020ds: Integrated with P2020DS DDR change and enabled hwconfigyork
Enabled SPD Enabled DDR2 Enabled hwconfig Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-07-16fdt: move fsl specific code from common fdt area to mpc8xxx/fdt.cKim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-15Merge branch 'master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
2010-07-13Blackfin: drop old u-boot.lds clean targetMike Frysinger
The u-boot.lds CPP unification missed the Blackfin-specific clean target. It is no longer needed, so punt it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05ARMV7: Add basic support for TI OMAP4Steve Sakoman
This patch adds minimum support for OMAP4. Code which can be shared between OMAP3 and OMAP4 is placed in arch/arm/cpu/armv7/omap-common Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-30Merge branch 'master' into nextWolfgang Denk
2010-06-29Prepare 2010.06v2010.06Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-29Merge branch 'master' of git://git.denx.de/u-boot-sh into nextWolfgang Denk
2010-06-28sh: Fix build on the targetNobuhiro Iwamatsu
SH fails building on the target. This supports this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-06-23Merge branch 'master' into nextWolfgang Denk
2010-06-23Prepare v2010.06-rc3v2010.06-rc3Wolfgang Denk
2010-06-22Makefile: always call date with LC_ALL=C setIlya Yanok
Ensure that date is called only with LC_ALL=C locale set to make dates locale neutral thus preventing lurking of non-ASCII characters into U-Boot binary. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Changed LANG= into LC_ALL= as suggested by Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-18Merge branch 'master' into nextWolfgang Denk
Conflicts: Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
Conflicts: CONFLICT (rename/add): Rename board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b. board/ti/tnetv107xevm/Makefile added in HEAD But files were identical, so no problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-06-14s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
This patch adds support for the Samsung Goni board (S5PC110 SoC) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-06-13Makefile/mkconfig: read simple board configurations from boards.cfgWolfgang Denk
Instead of adding explicit build rules for each and every board to the top level Makefile (which makes it grow and grow), we now provide a simple default rule and extend the "mkconfig" script to read board configurations from a plain text file (table), "boards.cfg". For simple boards it is now sufficient to add a single line of text to the "boards.cfg" file, no changes to the top level Makefile are needed any more. To make the table better readable, change the notation for unused fields from "NULL" into "-". Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Mike Frysinger <vapier@gentoo.org>
2010-06-13Makefile: simplify handling of common board configurationsWolfgang Denk
Many boards don't need any special handling in the Makefile. Try and provide as generic make rules for these as possible. There are still many areas where this does not work out really well, but the changes show the direction we should take, and point out which boards or architectures need further cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-13Makefile: simplify handling of build target namesWolfgang Denk
Instead of stripping the "_config" part from the make target names in each call of the "mkconfig" script let this script strip the string. This prepares the ground for forther simplification of the top level Makefile. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-13Fix printing of make targets, simplify MakefileWolfgang Denk
Make printing the "board names" more useful. So far, we would get output like this; $ ./MAKEALL P2020RDB P2020RDB_NAND P2020RDB_SDCARD P2020RDB_SPIFLASH Configuring for P1_P2_RDB board... text data bss dec hex filename 342612 32656 265212 640480 9c5e0 /work/wd/tmp-ppc/u-boot Configuring for P1_P2_RDB board... text data bss dec hex filename 343160 32704 265212 641076 9c834 /work/wd/tmp-ppc/u-boot Configuring for P1_P2_RDB board... text data bss dec hex filename 341908 32620 265212 639740 9c2fc /work/wd/tmp-ppc/u-boot Configuring for P1_P2_RDB board... text data bss dec hex filename 341908 32620 265212 639740 9c2fc /work/wd/tmp-ppc/u-boot For all build targets the same board name would be printed, which makes is often pretty difficult to find out which exact build target caused problems. With this commit, the real make target name gets printed instead, which is way more useful: $ ./MAKEALL P2020RDB P2020RDB_NAND P2020RDB_SDCARD P2020RDB_SPIFLASH Configuring for P2020RDB board... text data bss dec hex filename 342612 32656 265212 640480 9c5e0 /work/wd/tmp-ppc/u-boot Configuring for P2020RDB_NAND board... text data bss dec hex filename 343160 32704 265212 641076 9c834 /work/wd/tmp-ppc/u-boot Configuring for P2020RDB_SDCARD board... text data bss dec hex filename 341908 32620 265212 639740 9c2fc /work/wd/tmp-ppc/u-boot Configuring for P2020RDB_SPIFLASH board... text data bss dec hex filename 341908 32620 265212 639740 9c2fc /work/wd/tmp-ppc/u-boot Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-06-13Prepare v2010-rc2v2010.06-rc2Wolfgang Denk
2010-06-10TI: DaVinci: Add board specific code for da850 EVMSudhakar Rajashekhara
Provides initial support for TI OMAP-L138/DA850 SoC devices on a Logic PD EVM board. Provides: Initial boot and configuration. Support for i2c. UART support (console). Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-10TI: DaVinci: Prepare for da850 supportSudhakar Rajashekhara
DA850/OMAP-L138 is a new SoC from Texas Instruments (http://focus.ti.com/docs/prod/folders/print/omap-l138.html). This SoC is similar to DA830/OMAP-L137 in many aspects. Hence rename the da830 specific files and folders to da8xx to accommodate DA850/OMAP-L138. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for AM3517EVMVaibhav Hiremath
This patch adds basic support for the AM3517EVM. It includes: - Board files (.c and .h) - Default configuration file - Updates for Makefile Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
