path: root/Makefile
2013-03-04Prepare v2013.04-rc1v2013.04-rc1Tom Rini
2013-03-04sandbox: Add host filesystemSimon Glass
This allows reading of files from the host filesystem in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-14x86: Remove unneeded cruft from main MakefileSimon Glass
These lines are dealt with in the x86 Makefile and link script, so punt them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gabe Black <gabeblack@chromium.org>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-02Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-22imximage.cfg: run files through C preprocessorTroy Kisky
The '#' used as comments in the files cause the preprocessor trouble, so change to /* */. The mkimage command which uses this preprocessor output was moved to arch/arm/imx-common/Makefile .gitignore was updated to ignore .cfgtmp files. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-21mx23: config: Enable building of u-boot.sb binaryOtavio Salvador
For i.MX23 we need to pass imx23 as elftosb param. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-01-16Merge remote-tracking branch 'mpc83xx/next'Kim Phillips
2013-01-16Tegra30: Add generic Tegra30 build supportTom Warren
This patch adds basic Tegra30 (T30) build support - no specific board is targeted. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-01-15Prepare v2013.01v2013.01Tom Rini
2013-01-11Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-10Makefile: remove MLO.byteswap on clobberNishanth Menon
On clobber, do a cleanup even for SPL build else, we'd have MLO.byteswap remaining for certain platforms like am33xx SPL builds Signed-off-by: Nishanth Menon <nm@ti.com>
2013-01-10Prepare v2013.01-rc3v2013.01-rc3Tom Rini
2012-12-22Merge samsung, imx, tegra into u-boot-arm/masterAlbert ARIBAUD
This commit merges branches from samsung, imx and tegra meant to fix merge issues between u-boot/master and u-boot-arm/master, as well as a few manual merge fixes.
2012-12-19spl: Change PAD_TO to CONFIG_SPL_PAD_TOScott Wood
This was already used by some SPL targets, and allows the pad amount to be specified by board config headers rather than only in makefile fragments. Also supply a pad-to of zero if the variable is undefined. It works without this, but this avoids relying on undocumented behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-14Prepare v2013.01-rc2v2013.01-rc2Tom Rini
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-12-06Allow CONFIG_BOARD_SIZE_LIMIT to be specified in hexJoe Hershberger
Use the printf command to convert the number in any valid format into the expected decimal format. The resulting errors should be printed to stderr. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-05Makefile: Add target for combined spl/u-boot.bin & u-boot.imgStefan Roese
This new make target "u-boot-img.bin" consists of the U-Boot SPL image with the real, full-blown U-Boot image directly attached to it. The full-blown U-Boot image has the mkimage header included, with its load-address and entry-point. This will be used by the upcoming a3m071 MPC5200 board port. Signed-off-by: Stefan Roese <sr@denx.de>
2012-12-05Makefile: Add possibility to set entry-point for u-boot.imgStefan Roese
This patch enabled boards using the SPL framework to set an entry point in the U-Boot mkimage image "u-boot.img". Until now the entry point in the header has been set to 0. By setting CONFIG_SYS_UBOOT_START in the board header, boards can override this default location. This will be used by the upcoming a3m071 MPC5200 board port. Signed-off-by: Stefan Roese <sr@denx.de>
2012-12-04mxs: Silence elftosbMarek Vasut
The elftosb tool is now called with -d switch, which produces debug output to the stdout. The debug output is completely useless for regular operation, so silence it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2012-11-28x86: Allow excluding reset vector code from u-bootGabe Black
When running from coreboot we don't want this code. This version works by ifdef-ing out all of the code that would go into those sections and all the code that refers to it. The sections are then empty, and the linker will either leave them empty for the loader to ignore or remove them entirely. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-26Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2012-11-26powerpc: change .fixup test to a GCC version testScott Wood
This was introduced by commit 244615197469dd6fe75ae082f38424b97c79aeaf, but it fails in a minimal SPL build where the only thing in arch/powerpc/lib is cache.c, which apparently doesn't generate any fixup records. The problem is reported to occur with GCC 3.x, so insist on GCC 4.0 or newer. Patterned after checkthumb as suggested by Tom Rini. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Tom Rini <trini@ti.com> -- v2: test gcc version instead of testing nothing
2012-11-26spl: introduce CONFIG_SPL_TARGETScott Wood
Currently the SPL target is specified in a CPU-specific makefile fragment. While some targets may need something more complicated than a simple target name, targets which don't need this shouldn't have to provide a makefile fragment just for this. Signed-off-by: Scott Wood <scottwood@freescale.com> --- v2: Removed default target as it's been pointed out to me how existing platforms cause the SPL to be built.
2012-11-26spl: rename u-boot-pad.bin to u-boot-with-spl.binScott Wood
2012-11-26Add u-boot-pad.bin target to the MakefileJosé Miguel Gonçalves
Samsung's S3C24XX SoCs need this in order to generate a binary image with a padded SPL concatenated with U-Boot. Signed-off-by: José Miguel Gonçalves <jose.goncalves@inov.pt> [scottwood@freescale.com: fixed prereq of u-boot.ubl] Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: Removed spl/ prefix from u-boot.ubl prerequisite.
2012-11-20musb-new: port of Linux musb driverIlya Yanok
Existing U-Boot musb driver has no support for the new gadget framework and also seems to have other limitations. As gadget framework is ported from Linux it seems pretty natural to port musb gadget driver as well. This driver supports both host and peripheral modes. This is not a replacement for current musb driver (at least now) as there are still some consumers of the old UDC interface. No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be defined. Virtual root hub device is not implemented. Known problems: with no devices connected usb_lowlevel_start() fails. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-11-15SOUND: SAMSUNG: Add I2S driverRajeshwari Shinde
This patch adds driver for I2S interface specific to samsung. Signed-off-by: R. Chandrasekar <rcsekar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-14pmic:fuel-gauge: Support for MAX17042 fuel-gaugeŁukasz Majewski
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997 power management device. Special file - fg_battery_cell_params.h with cells characteristics added. The FG device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:battery: Support for Trats Battery at PMIC frameworkŁukasz Majewski
Trats battery is now treated in the same way as other power related devices. This approach allows for more unified handling of all devices responsible for power management. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Move pmic related code to ./drivers/power directoryŁukasz Majewski
The PMIC framework has been moved to its more natural place ./drivers/power from ./drivers/misc directory. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-11-14Makefile: silence 'make clean'Andreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-11-10Merge git://git.denx.de/u-bootStefano Babic
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-04Makefile: use EXTRAVERSION for -rc? tagWolfgang Denk
When using SUBLEVEL for the -rc? tag, this results in an ugly version string like "2013.01.-rc1" - let's use EXTRAVERSION instead to get the simple "2013.01-rc1" Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-11-04Prepare v2013.01-rc1v2013.01-rc1Tom Rini
2012-10-29fs: add filesystem switch libary, implement ls and fsload commandsStephen Warren
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load}, and transparently handle either file-system. This scheme could easily be extended to other filesystem types; I only didn't do it for zfs because I don't have any filesystems of that type to test with. Replace the implementation of {fat,ext[24]}{ls,load} with this new code too. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-29ARM: tegra: combine duplicate Makefile rulesStephen Warren
The rules to generate u-boot-{no,}dtb-tegra.bin were almost identical. Combine them into a single paremeterized rule. This will allow the next patch to edit a single rule, rather than being cut/paste twice. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-26arm: arm925t: remove SX1 boardAlbert ARIBAUD
SX1 does not build properly by itself, is not built as part of MAKEALL arm or MAKEALL -a arm, and is only present in Makefile, not boards.cfg. As it also has no entry in MAINTAINERS, it is orphan and non-functional. Remove it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-26ARM: Add SPL target to arm1136Stefano Babic
The patch adds SPL for the arm1136 architecture and inserts SPL (the produced binary) to clobber target in the main Makefile. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-22fs: Add a Coreboot Filesystem (CBFS) driver and commandsGabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. The CBFS driver can also be used programmatically from within u-boot. If u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. The cbfs_file_find_uncached function searches a CBFS instance without touching the heap. Signed-off-by: Gabe Black <gabeblack@google.com> Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add symbol handling for generic lists into MakefileMarek Vasut
This patch adds essential components for generation of the contents of the linker section that is used by the linker-generated array. All of the contents is held in a separate file, u-boot.lst, which is generated at runtime just before U-Boot is linked. The purpose of this code is to especially generate the appropriate boundary symbols around each subsection in the section carrying the linker-generated arrays. Obviously, the interim linker code for actual placement of the variables into the section is generated too. The generated file, u-boot.lst, is included into u-boot.lds via the linker INCLUDE directive in u-boot.lds . Adjustments are made in the Makefile and spl/Makefile so that the u-boot.lds and u-boot-spl.lds depend on their respective .lst files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15kerneldoc: Implant DocBook from Linux kernelMarek Vasut
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation. It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts. It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches. Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel. Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build. Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200 Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200 Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400 Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-15Tegra20: Move some code files to common directories for upcoming Tegra30 ↵Tom Warren
patches. Move files that are going to be common between T20 and T30 into 'tegra-common' subdirs in AVP (arm720t), CPU (armv7), and shared (arch/arm/cpu/.) areas. Any files that are left behind in '/tegra20' will be copied to '/tegra30' subdirs and modified for that SoC. The 'common' files should need only minor changes. Include files (arch/arm/include/asm/arch-tegra/tegra20) will be done in a follow-on patch. Builds fine w/MAKEALL -s tegra20. Checkpatch.pl is clean. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15add check infrastructure, default sparseKim Phillips
Add support for running source code checkers on u-boot source, e.g., using sparse to aid with typechecking. This comes in especially handy as SoC vendors mix and match cores and devices with different endianness, thus here we add CHECK_ENDIAN to the otherwise linux kernel default CHECKFLAGS. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-15Prepare v2012.10v2012.10Tom Rini
