path: root/Makefile
2007-09-20v1.3.0-rc2v1.3.0-rc2Wolfgang Denk
2007-09-18Merge with git+ssh://gemini_vpn/home/wd/git/u-boot/masterWolfgang Denk
2007-09-18Bugfix: remove embedded null (\0) from CFG_BOOTFILE macro in TQM8540_configGrant Likely
/bin/bash and /bin/dash (which /bin/sh is linked to on ubuntu) handle embedded nulls in a string differently. For example, the following statement: echo "this is a string\0" > afile Will produce the following with /bin/bash: "this is a string\0" But with /bin/dash, will produce: "this is a string Bug fixed by moving the embedded null out of the makefile and into the config header. Also renamed the macro to avoid usage colision with the same macro used by other board ports. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-18MCC200: fix build warningWolfgang Denk
The MCC200 board config file includes version.h for some customer- specific setting, which causes warnings with "make depend"; build version.h before depend. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-09-15Update MPC8349ITX*_config to place config.tmp in right place.Sam Sparks
MPC834ITX*_config does not store config.tmp at the correct locatation, causing MPC8349ITXGP to have the wrong TEXT_BASE. Signed-off-by: Sam Sparks <SSparks@twacs.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-10Update version to match current state.Wolfgang Denk
2007-09-07PXA270: Added support for TrizepsIV board.stefano babic
This patch add support for the Trizeps IV module (520Mhz). Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-08-29support board vendor-common makefilesKim Phillips
if a board/$(VENDOR)/common/Makefile exists, build it. also add the first such case, board/freescale/common/Makefile, to handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as dictated by board configuration. thusly get rid of alternate build dir errors such as: FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory by putting the common/ mkdir command in its proper place (the common Makefile). Common bits from existing individual board Makefiles have been removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-coldfireWolfgang Denk
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16mpc83xx: move freescale boards to boards/freescaleKim Phillips
includes build fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-16ColdFire: Add M5249EVB platform for MCF52x2TsiChungLiew
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-16Merge branch 'denx-coldfire' into coldfire-aug2007John Rigby
2007-08-15Move the MPC8641HPCN board under board/freescale.Jon Loeliger
Minor path corrections needed to ensure buildability. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-08-1485xxCDS: Add make targets for legacy systems.Randy Vinson
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x. Signed-off-by Randy Vinson <rvinson@mvista.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-13Merge commit 'remotes/wd/master'Jon Loeliger
Conflicts: MAKEALL With any luck, this is the last MAKEALL merge conflict!
2007-08-10Add support for SBC8641D. Config files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-08-10Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-10Coding style cleanupStefan Roese
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: make relatedNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-08-10mpc83xx: add support for the MPC8323E RDBKim Phillips
MPC8323E based board with 64MB fixed SDRAM, 16MB flash, five 10/100 ethernet ports connected via an ICPlus IP175C switch, one PCI slot, and serial. Features not supported in this patch are SD card interface, 2 USB ports, and the two phone ports. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10MPC83xx: Fix makefile to generate config.h file in the build directorydavid.saada
MPC83xx: Fix the Makefile config sections to generate the include/config.h file in the build directory instead of the source directory. Signed-off-by: David Saada <david.saada@ecitele.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-09Merge with git+ssh://atlas/home/wd/git/u-boot/masterWolfgang Denk
2007-08-09Merge with /home/wd/git/u-boot/workWolfgang Denk
2007-08-09Treat ppc64 host as ppcKumar Gala
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-07Merge with /home/tur/git/u-boot#cm5200-siWolfgang Denk
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-08-06Configurations for ATI video card BIOS emulatorJason Jin
This patch add definition of the BIOS emulator and the ATI framebuffer driver for MPC8641HPCN board. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-08-03cm1_qp1 -> cm5200: single U-Boot image for modules from the cm5200 family.Bartlomiej Sieka
Add the ability for modules from the Schindler cm5200 family to use a single U-Boot image: - rename cm1_qp1 to cm5200 - add run-time module detection - parametrize SDRAM configuration according to the module we are running on Few minor, board-specific fixes included in this patch: - better MAC address handling - updated default environment ('update' command uses +{filesize} now) - improved error messages in the auto-update code - allow booting U-Boot from RAM (CFG_RAMBOOT) Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-08-02Minor cleanup of <board>_nand build rules.Wolfgang Denk
2007-08-02Fix build errors and warnings / code cleanup.Wolfgang Denk
2007-07-27[ADS5121] Support for the ADS5121 boardRafal Jaworowski
The following MPC5121e subsystems are supported: - low-level CPU init - NOR Boot Flash (common CFI driver) - DDR SDRAM - FEC - I2C - Watchdog Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Jan Wrobel <wrr@semihalf.com>
2007-07-26ppc4xx: Add support for AMCC 405EP Taihu boardJohn Otken
Signed-off-by: John Otken <john@softadvances.com>
2007-07-16Merge with /home/stefan/git/u-boot/u-boot-coldfire-freescaleStefan Roese
2007-07-14[PCS440EP] - fix compile error, if BUILD_DIR is usedHeiko Schocher
2007-07-12Merge with /home/tur/git/u-boot#cm1_qp1Wolfgang Denk
2007-07-11CM1.QP1: Support for the Schindler CM1.QP1 board.Bartlomiej Sieka
