Initial support for Extreme Engineering Solutions XPedite5200 -
a MPC8548-based PMC single board computer.
Initial support for Extreme Engineering Solutions XPedite5370 -
a MPC8572-based 3U VPX single board computer with a PMC/XMC
site.
Initial support for NXP's 4 and 8 bit I2C gpio expanders
(eg pca9537, pca9557, etc). The CONFIG_PCA953X define
enables support for the devices while the CONFIG_CMD_PCA953X
define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO
define enables an 'info' sub-command which provides summary
information for the given pca953x device.
Parallel builds (using "make -jN") would occasionally fail with error
messages like
include/autoconf.mk:212: *** missing separator. Stop.
Line numbers and affected boards were changing. Obviously some
Makefiles included autoconf.mk while it was still being written to.
As a fix, we now write to a temporary file first and then rename it,
so that it is really ready to use as soon as it appears.
This patch fixes building U-Boot for CPCI405 boards.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Microblaze platforms use generic settings and to have
many platforms is confusing that's why I decided to remove this
platform from U-BOOT. ml401 tree is sufficient for covering
all Microblaze platforms.
This change will go through microblaze custodian tree.
Make should be using the bash shell by default which makes
CONFIG_SHELL unnecessary
Some Make script commands rely on bash-specific features like brace
expansion, so default to bash for the SHELL variable with a fallback
to the standard sh shell
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
This patch adds the possiblity to choose the media where the environment will
be located. This allow to choose this fundamental configuration without editing
config files.
Documentation file added.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Stelian Pop <stelian@popies.net>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
This will enable CONFIG_PHYS_36BIT for MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch provides support for AFEB9260 board, a product of
OpenSource hardware and software. Some commertial projects
are made with this design. A board is basically AT91SAM9260-EK
with some modifications and different peripherals and different
parts used. Main purpose of this project is to gain experience in
hardware design.
More info: http://groups.google.com/group/arm9fpga-evolution-board
(In Russian only, sorry).
Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Add serial boot support
This patch adds support for the avnet fx12 minimodul.
It needs the "ppc4xx: Generic architecture for xilinx ppc405"
patch from Ricardo.
Signed-off-by: Georg Schardt <schardt@team-ctech.de>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx
ppc440 boards, this patch presents a common architecture for all the
xilinx ppc405 boards.
Any custom xilinx ppc405 board can be added very easily with no code
duplicity.
This patch also adds a simple generic board, that can be used on almost
any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h
This patch is prepared to work with the latest version of EDK (10.1)
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
The Arches Evaluation board is based on the AMCC 460GT SoC chip.
This board is a dual processor board with each processor providing
independent resources for Rapid IO, Gigabit Ethernet, and serial
communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR
FLASH, UART, EEPROM and temperature sensor, along with a shared debug
port. The two 460GT's will communicate with each other via shared
memory, Gigabit Ethernet and x1 PCI-Express.
Signed-off-by: Adam Graham <agraham@amcc.com>
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
board/freescale/mpc8536ds/mpc8536ds.c
include/configs/mgcoge.h
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
There are some more extensions, which are for both boards
and some more boards from this manufacturer will follow soon.
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
This patch solves the problems compiling ml507, v5fx30teval and
ppc440-generic out of tree.
SREC files do not need gap fill: The load address is specified in the
file. On the other hand, it can't be avoided in a .bin object. It has
no information about memory location.
