This patch adds support for the Voipac PXA270 board. The support includes:
- Ethernet
- USB
- MMC
- NOR Booting
- OneNAND Booting
- LCD
- HDD
Acked-by: Scott Wood <scottwood@freescale.com>
The u-boot.lds CPP unification missed the Blackfin-specific clean target.
It is no longer needed, so punt it.
This patch adds minimum support for OMAP4. Code which can be shared
between OMAP3 and OMAP4 is placed in arch/arm/cpu/armv7/omap-common
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Update CHANGELOG
SH fails building on the target.
This supports this.
Ensure that date is called only with LC_ALL=C locale set to make dates
locale neutral thus preventing lurking of non-ASCII characters into
U-Boot binary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Changed LANG= into LC_ALL= as suggested by Mike Frysinger <vapier@gentoo.org>
Makefile
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Instead of adding explicit build rules for each and every board to the
top level Makefile (which makes it grow and grow), we now provide a
simple default rule and extend the "mkconfig" script to read board
configurations from a plain text file (table), "boards.cfg".
For simple boards it is now sufficient to add a single line of text to
the "boards.cfg" file, no changes to the top level Makefile are needed
any more.
To make the table better readable, change the notation for unused
fields from "NULL" into "-".
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Many boards don't need any special handling in the Makefile. Try and
provide as generic make rules for these as possible. There are still
many areas where this does not work out really well, but the changes
show the direction we should take, and point out which boards or
architectures need further cleanup.
Instead of stripping the "_config" part from the make target names in
each call of the "mkconfig" script let this script strip the string.
This prepares the ground for forther simplification of the top level
Makefile.
Make printing the "board names" more useful. So far, we would get
output like this;
$ ./MAKEALL P2020RDB P2020RDB_NAND P2020RDB_SDCARD P2020RDB_SPIFLASH
Configuring for P1_P2_RDB board...
342612 32656 265212 640480 9c5e0 /work/wd/tmp-ppc/u-boot
343160 32704 265212 641076 9c834 /work/wd/tmp-ppc/u-boot
341908 32620 265212 639740 9c2fc /work/wd/tmp-ppc/u-boot
For all build targets the same board name would be printed, which
makes is often pretty difficult to find out which exact build target
caused problems. With this commit, the real make target name gets
printed instead, which is way more useful:
Configuring for P2020RDB board...
Configuring for P2020RDB_NAND board...
Configuring for P2020RDB_SDCARD board...
Configuring for P2020RDB_SPIFLASH board...
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
DA850/OMAP-L138 is a new SoC from Texas Instruments
(http://focus.ti.com/docs/prod/folders/print/omap-l138.html).
This SoC is similar to DA830/OMAP-L137 in many aspects. Hence
rename the da830 specific files and folders to da8xx to
accommodate DA850/OMAP-L138.
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
It includes:
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The nios-32 arch is obsolete and broken. So it is removed.
When we changed ARCH from ppc to powerpc we need to treat HOSTARCH the
same way. We use HOSTARCH == ARCH to determine if a build is native.
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0
GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot
References:
http://www.globalscaletechnologies.com/t-guruplugdetails.aspx
http://plugcomputer.org
This patch is for GuruPlug Plus, but it supports Standard version
as well.
Signed-off-by: Siddarth Gore <gores@marvell.com>
This patch adds support for the magnesium board from
projectiondesign. This board uses i.MX27 SoC and has
8MB NOR flash, 128MB NAND flash, FEC ethernet controller
integrated into i.MX27. As this port is based on
the imx27lite port, common config options are collected
in include/configs/imx27lite-common.h
This patch adds support for the Mosaix Technologies, Inc. ICON board,
based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM
(512MB standard) and 64MByte of NOR FLASH.
Support for the onboard SM502 will be added later.
This is a generic approach to port u-boot for nios2 boards.
You may find the usage of this approach on the nioswiki,
http://nioswiki.com/DasUBoot
A fpga parameter file, which contains base address information
and drivers declaration, is generated from Altera's hardware system
description sopc file using tools.
The example fpga parameter file is compatible with EP1C20, EP1S10
and EP1S40 boards. So these boards can be removed after this commit.
Though epcs controller is removed to cut the dependency of altera_spi
driver.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh.
Signed-off-by: Michael Weiss <michael.weiss@ifm.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Move the libfdt directory into the common lib/ directory to clean up the
top-level directory.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
