path: root/Makefile
2014-08-06Prepare v2014.10-rc1v2014.10-rc1Tom Rini
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-28Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-25keystone: add support for NAND gpheader imageKhoronzhuk, Ivan
Add support for NAND gpheader image. TI Keystone2 ROM bootloader expects 8 bytes of trailing zeroes in the nand u-boot image. So add zeros at the end of the nand gph image. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-22Makefile: fix tags target documentationIgor Grinberg
Replace the TAGS target name by the actual ctags target name. Also, add etags target documentation. Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-07-22Makefile: fix ctags/etags clean targetsIgor Grinberg
Commit efcf861 (kbuild: use scripts/Makefile.clean) refactored the cleaning targets and accidentially replaced the actually generated "ctags" and "etags" files in the file list by "tags" and "TAGS". "tags" and "TAGS" are not part of the Makefile build targets and therefore should not be a part of the list for clean targets. Substitute the actually generated files instead, to fix the clean targets behavior. Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-07-22Makefile: fix the {c, e}tags/cscope build targetsIgor Grinberg
Commit 9e41403 (kbuild: change out-of-tree build) changed the U-Boot build working directory to the output tree for the out-of-tree builds. This broke the {c,e}tags/cscope build targets as TAG_SUBDIRS variable collected directories based on assumption that the build working directory is the U-Boot source tree directory. Fix the {c,e}tags/cscope build targets by adding the $(srctree) prefix. Also, remove the $(obj) prefix from the etags build target to finish the $(obj) prefix removal started by the same commit. Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-07-14Prepare v2014.07v2014.07Tom Rini
2014-07-07Makefile: drop arch/*/include/asm/proc from make mrproper patternMasahiro Yamada
Commit 7d89982b stopped creating symbolic link arch/${arch}/include/asm/proc. We do not need to delete it by "make mrproper" any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Vasili Galka <vvv444@gmail.com>
2014-07-07Avoid using gawk-specific strtonum()Simon Glass
We need to subtract two hex numbers. Avoid using strtonum() by doing the subtraction in bc with a suitable input base. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Vasili Galka <vvv444@gmail.com>
2014-07-02Prepare v2014.07-rc4v2014.07-rc4Tom Rini
2014-06-20cosmetic: kbuild: clean-up coding style (sync with Linux 3.16-rc1)Masahiro Yamada
Import the following trivial commits from Linux v3.16-rc1: bb66fc6 kbuild: trivial - use tabs for code indent where possible 7eb6e34 kbuild: trivial - remove trailing empty lines 3fbb43d kbuild: trivial - fix comment block indent 38385f8 kbuild: trivial - remove trailing spaces Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-19fdt: Rename the DEV_TREE_BIN Makefile flag to to EXT_DTBSimon Glass
This seems like a better name. This is a patch-up to the earlier commit 63b4b5b, and also removes a redundant Makefile change. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11kbuild: move spl/Makefile to scripts/Makefile.splMasahiro Yamada
All files under spl/ and tpl/ are generated during the build process except spl/Makefile. We can simplify clean-rule and git-ignore by moving spl/Makefile to somewhere else. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-11kbuild: export HOSTCXX and HOSTCXXFLAGSMasahiro Yamada
2014-06-11fdt: Add DEV_TREE_BIN option to specify a device tree binary fileSimon Glass
In some cases, an externally-built device tree binary is required to be attached to U-Boot. An example is when using image signing, since in that case the .dtb file must include the public keys. Add a DEV_TREE_BIN option to the Makefile, and update the documentation. Usage is something like: make DEV_TREE_BIN=boot/am335x-boneblack-pubkey.dtb Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11Check that u-boot.bin size looks correctSimon Glass
Check that the image size matches the size we get from u-boot.bin. If it doesn't, that generally means that some extra sections are being added to u-boot.bin, meaning that it is not possible to access data appended to the U-Boot binary. This is used for device tree, so needs to work. This problem was introduced by commit b02bfc4. By adding a test we can prevent a reccurence. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11Makefile: fix clang warnings due to clang supportJeroen Hofstee
Building u-boot tools with clang as a host compiler e.g. on FreeBSD with `gmake HOSTCC=clang CONFIG_USE_PRIVATE_LIBGCC=y tools` leads to many warnings [1] for every compiler invocation since commit 598e2d33. Part of mentioned commit imports linux patches: - kbuild: LLVMLinux: Adapt warnings for compilation with clang - kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang No version of clang supports the gcc fno-delete-null-pointer-checks though, but it is only passed to clang. Gcc does not have the clang specific Qunused-arguments for the target. Furthermore several warnings are disabled which aren't encountered in u-boot. Since such a build has worked for quite some time and works after removing these changes, just remove the clang specific handling to restore normal building with clang as hostcc. [1] Actual warnings ------------------- GEN include/autoconf.mk.dep arm-freebsd-gcc: unrecognized option '-Qunused-arguments' HOSTCC scripts/basic/fixdep clang: warning: argument unused during compilation: '-fno-delete-null-pointer-checks' cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-10Prepare v2014.07-rc3v2014.07-rc3Tom Rini
2014-06-05nand_spl: remove nand_spl infrastructureMasahiro Yamada
Remove the common infrastructure of nand_spl and clean-up the code inside ifdef(CONFIG_NAND_U_BOOT)..endif. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-05kbuild: add missing PERL definitionMasahiro Yamada
"checkstack" target uses $(PERL) so PERL must be defined. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-05kbuild: remove unused RANLIBMasahiro Yamada
RANLIB was added by commit e221174 (more than a decade ago) but it has been never referenced at all. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-30Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-27Prepare v2014.07-rc2v2014.07-rc2Tom Rini
2014-05-25sunxi: non-FEL SPL boot support for sun7iIan Campbell
Add support for booting from an MMC card. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-24Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-23examples: select libgcc for non-default architectureAlexey Brodkin
In case of multilib-enabled toolchains if default architecture differ from the one examples are being built for linker will fail to link example object files with libgcc of another (non-compatible) architecture. Interesting enough for years in main Makefile we used CFLAGS/c_flags for this but not for examples. So fixing it now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Acked-by: WOlfgang Denk <wd@denx.de> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-23Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-15build: support a new image u-boot-dtb.imgMasahiro Yamada
In SPL framework, SPL uses u-boot.img to load u-boot.bin. Here, u-boot.img = uImage header + u-boot.bin To use OF control with a separate devicetree, u-boot.dtb must be placed right after u-boot.bin. In this case, u-boot-dtb.bin is generally used. Here, u-boot-dtb.bin = u-boot.bin + u-boot.dtb We need u-boot-dtb.img to use both SPL framework and separate OF control at the same time. u-boot-dtb.img = uImage header + u-boot-dtb.bin For example, Zynq boards already define all of - CONFIG_SPL - CONFIG_OF_CONTROL - CONFIG_OF_SEPARATE So, the support of u-boot-dtb.img is urgent. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13arm, davinci: Use CONFIG_SPL_PAD_TO for padding the SPL in an ais imageChristian Riesch
The commits commit b7b5f1a16ca66dfdd817e7339f0e263a5b9f2758 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINT and commit e7497891e34efe5cb2b3a3dc7c6c096c012ede28 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINT replaced CONFIG_SPL_MAX_SIZE by CONFIG_SPL_MAX_FOOTPRINT. However, CONFIG_SPL_MAX_SIZE is used in the Makefile for padding the SPL when preparing an u-boot.ais image. By removing CONFIG_SPL_MAX_SIZE said commits broke the ais image of the da850evm and cam_enc_4xx configurations. This patch converts the u-boot.ais target to use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for padding the SPL and adds a #define CONFIG_SPL_PAD_TO where it is required. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Tom Taylor <ttaylor.tampa@gmail.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-12kbuild: Fix trailing whitespacesMichal Simek
Trivial fix. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-12kbuild: build with -Werror=date-time if the compiler supports itMasahiro Yamada
Using __DATE__, __TIME__ would make the build non-deterministic. If the code needs to refer to build date/time, use U_BOOT_DATE and U_BOOT_TIME in include/generated/timestamp_autogenerated.h instead. This commit has been imported from Linux Kernel, which should be applied to U-Boot too: commit fe7c36c7bde12190341722af69358e42171162f3 Author: Josh Triplett <josh@joshtriplett.org> Date: Mon Dec 23 13:56:06 2013 -0800 Makefile: Build with -Werror=date-time if the compiler supports it GCC 4.9 and newer have a new warning -Wdate-time, which warns on any use of __DATE__, __TIME__, or __TIMESTAMP__, which would make the build non-deterministic. Now that the kernel does not use any of those macros, turn on -Werror=date-time if available, to keep it that way. The kernel already (optionally) records this information at build time in a single place; other kernel code should not duplicate that. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12Prepare v2014.07-rc1v2014.07-rc1Tom Rini
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-04-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-04-23Revert "build: Use filechk rules to create and update u-boot.lds"Masahiro Yamada
This reverts commit a8b993eb81c142a439c24b871a2317f765fe5397. Commit a8b993eb claims it fixes u-boot.lds rule by replacing $(call if_changed) with $(call filechk). But the problem had already been fixed by commit 395e60cd a few days before commit a8b993eb was posted. There is no reason to apply commit a8b993eb. What is worse is $(call filechk) is too strong to fix the problem and looks weird. Date of the two patches: [1] commit 395e60cdc292dc0183c6867d34b43f14a373df55 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> AuthorDate: Wed Apr 9 20:10:43 2014 +0900 Commit: Tom Rini <trini@ti.com> CommitDate: Fri Apr 11 10:08:42 2014 -0400 replaces $(call if_changed) -> $(call if_changed_dep) [2] commit a8b993eb81c142a439c24b871a2317f765fe5397 Author: Jon Loeliger <jon.loeliger@oracle.com> AuthorDate: Tue Apr 15 16:09:37 2014 -0500 Commit: Tom Rini <trini@ti.com> CommitDate: Fri Apr 18 16:14:16 2014 -0400 replaces $(call if_changed) -> $(call filechk) A conflict must have happened when applying [2], but somehow it was applied, sadly. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jon Loeliger <jon.loeliger@oracle.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com>
2014-04-22Makefile: Add support of CONFIG_SPL_FSL_PBLPrabhakar Kushwaha
Objective of this target to have concatenate binary having - SPL binary in PBL command format - U-boot binary Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-21Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-04-18build: Use filechk rules to create and update u-boot.ldsJon Loeliger
Prior to this patch, the top-level linker script u-boot.lds used a simple $(call if_changed) check when generated. That mechanism misses cases where a possible include file change induces a change in the u-boot.lds too. This patch converts it to a stronger check using ($call filechk) that will also notice differences in file contents and will catch changes due to pre-processing as well. Signed-off-by: Jon Loeliger <jon.loeliger@oracle.com>
2014-04-18kbuild: add user-supplied CPPFLAGS, AFLAGS and CFLAGSMasahiro Yamada
Like Linux Kernel, this commit provides environment variables KCPPFLAGS, KAFLAGS and KCFLAGS, which are useful to pass additional options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18kbuild: sync with Linux Kernel v3.15-rc1Masahiro Yamada
This commit imports Kbuild-related updates from v3.14 to v3.15-rc1. - commit 3d3d6b8474204b6819688c9800774d52d370a538 kbuild: LLVMLinux: Adapt warnings for compilation with clang - commit 61163efae02040f66a95c8ed17f4407951ba58fa kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang - commit 79192ca8ebd9a25c583aa46024a250fef1e7766f scripts: objdiff: detect object code changes between two commits - commit 1c9e70a55b088d97a59241744fe459409d0c3582 kbuild: create a build directory automatically for out-of-tree build - commit a03fcb50e816a69acffb13b5e56db75063aeba8a kbuild: remove redundant '.*.cmd' pattern from make distclean - commit 13338935f1574a2dcd1c891461b0dcc42f8cff42 kbuild: move "quote" to Kbuild.include to be consistent - commit bfdfaeae500a3b194b73b01e92a8034791a58b7f kbuild: specify build_docproc as a phony target - commit f4d4ffc03efc864645b990e1d579bbe1b8e358a4 kbuild: dtbs_install: new make target - commit 1e64ff42ea3d8d2fc8aa71f9717b3c1cb6c2f893 Kbuild, lto: Disable LTO for asm-offsets.c - commit ccbef1674a1579842c7dbdf554efca85d2cd245a Kbuild, lto: add ld-version and ld-ifversion macros - commit ae63b2d7bdd9bd66b88843be0daf8e37d8f0b574 scripts/tags.sh: Ignore *.mod.c - commit e36aaea28972c57a32a3ba5365e61633739719b9 kbuild: Fix silent builds with make-4 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17k2hk: add support for k2hk SOC and EVMVitaly Andrianov
k2hk EVM is based on Texas Instruments Keystone2 Hawking/Kepler SoC. Keystone2 SoC has ARM v7 Cortex-A15 MPCore processor. Please refer the ti/k2hk_evm/README for details on the board, build and other information. This patch add support for keystone architecture and k2hk evm. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com>
2014-04-14Prepare v2014.04v2014.04Tom Rini
2014-04-11kbuild: fix a bug in regeneration of linker scriptsMasahiro Yamada
In some use cases, SPL linker script was not updated even when it should be. For instance, $ make tricoder_config all [ build complete ] ... modify include/configs/tricoder.h $ make spl/u-boot-spl.lds should be updated in this case, but it wasn't. To fix this problem, linker scripts generation should be handled by $(call if_changed_dep,...) rather than by $(call if_changed,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-04arm: mxs: Add support for generating signed BootStreamMarek Vasut
This patch adds the groundwork for generating signed BootStream, which can be used by the HAB library in i.MX28. We are adding a new target, u-boot-signed.sb , since the process for generating regular non-signed BootStream is much easier. Moreover, the signed bootstream depends on external _proprietary_ _binary-only_ tool from Freescale called 'cst', which is available only under NDA. To make things even uglier, the CST or HAB mandates a kind-of circular dependency. The problem is, unlike the regular IVT, which is generated by mxsimage, the IVT for signed boot must be generated by hand here due to special demands of the CST. The U-Boot binary (or SPL binary) and IVT are then signed by the CST as a one block. But here is the problem. The size of the entire image (U-Boot, IVT, CST blocks) must be appended at the end of IVT. But the size of the entire image is not known until the CST has finished signing the U-Boot and IVT. We solve this by expecting the CST block to be always 3904B (which it is in case two files, U-Boot and the hand-made IVT, are signed in the CST block). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-04-04Merge branch 'master' of git://git.denx.de/u-boot-arm into masterStefano Babic
Conflicts: arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-04Revert "arm: mxs: Add support for generating signed BootStream"Stefano Babic
This reverts commit 53e6b14e037c9f72e6d03244c32d8d597e2e0234. Patch does not merge anymore with u-boot-arm and must be rebased. Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-02imx: add rules for U-Boot DTB supportStefano Babic
