path: root/Makefile
2011-11-16Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
* 'master' of git://git.denx.de/u-boot-video: api: export LCD device to external apps font: split font data from video_font.h tools: logo: split bmp arrays from bmp_logo.h lcd: add clear and draw bitmap declaration VIDEO: mx3fb: GCC4.6 fix build warnings Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bug
2011-11-15tools: logo: split bmp arrays from bmp_logo.hChe-Liang Chiou
The generated header bmp_logo.h is useful even outside common/lcd.c for the logo dimension. However, the problem is, the generated bmp_logo.h cannot be included multiple times because bmp_logo_palette[] and bmp_logo_bitmap[] are defined in the bmp_logo.h. This patch fixes this by defining these arrays in another header bmp_logo_data.h and in bmp_logo.h only declaring these arrays. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-15omap5: Add omap5_evm board build support.Sricharan
This patch adds the build support for the omap5_evm board. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-11iMX28: Add u-boot.sb target to MakefileMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board arm: jadecpu: Readd MACH_TYPE_JADECPU at91: defined mach-types for otc570 board in board config file at91: defined mach-types for meesc board in board config file mx31pdk: Enable D and I caches ehci-mxc: remove incorrect comment README: Fix supported i.MX SoC list for CONFIG_MXC_SPI mx53: Turn off child clocks before reconfigure perclk_root qong: enable support for compressed images imx: imx31_phycore.h: fix checkpatch warnings vision2: Remove unused get_board_rev function mx53smd: Remove unused get_board_rev function mx53ard: Remove unused get_board_rev function mx53evk: Remove unused get_board_rev function mx53evk: Add RTC support mx53loco: Remove unused get_board_rev function mx53evk: Remove unneeded '1' from mx53evk.h OMAP3: mvblx: Initial support for mvBlueLYNX-X ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE omap3: mem: Move comments next to definitions omap3: mem: Clean-up whitespaces omap3: mem: Define and use common macros Davinci: ea20: added PREBOOT to configuration Davinci: ea20: added I2C support Davinci: ea20: added video support VIDEO: davinci: add framebuffer to da8xx ARM: Davinci: added missing registers to hardware.h Davinci: ea20: add gpios for LCD backlight control Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: Add default U-Boot environment Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add NAND support Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: set console on UART0 arm, davinci: add cam_enc_4xx support arm926ejs, davinci: add missing spi defines for dm365 arm926ejs, davinci: add cpuinfo for dm365 arm, davinci: add lowlevel function for dm365 soc arm, davinci: add header files for dm365 spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add support for new spl framework spl: add option for adding post memory test to the SPL framework net, davinci_emac: make clock divider in MDIO control register configurable arm, usb, davinci: make USBPHY_CTL register configurable usb, davinci: add enable_vbus() weak function omap3evm: fix errors caused by multiple definitions omap3evm: Add (quick) configuration for NAND only omap3evm: Add (quick) configuration for MMC/SD only omap3evm: move common config options to new file omap3evm: Prepare to split configuration omap3evm: Reorder related config options omap/spl: actually enable the console davinci_emac: compilation fix, phy is array now omap3evm: Set environment variable 'ethaddr' arm, arm926: fix missing symbols in NAND_SPL mode arm, davinci: Add function lpsc_syncreset() arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm/km: portl2 environment address update to P1B arm/km: adapt bootcounter evaluation arm/km: enable jffs2 cmds arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: add boardid and hwkey to kernel command line ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards netspace_v2: enable I2C EEPROM support netspace_v2: fix SDRAM configuration armada100: define CONFIG_SYS_CACHELINE_SIZE pantheon: define CONFIG_SYS_CACHELINE_SIZE kirkwood: define CONFIG_SYS_CACHELINE_SIZE kirkwood: drop empty asm-offsets.s file arm/km/mgcoge3un: enhance "waitforne" feature arm/km: add variable waitforne to mgcoge3un gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared ARM: dreamplug: fix compilation ARM: DockStar: fix compilation ARM: netspace_v2: fix warnings am335x: Drop board_sysinfo struct am335x: Temporarily add MACH_TYPE define misc:pmic:samsung Enable PMIC driver at C210 Universal target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target smdkv310: use macro for mmc data read function address smdkv310: use spl framework for mmc spl SMDKV310: use get_ram_size() to validate dram size SMDKV310: Initialize board id using CONFIG_MACH_TYPE ORIGEN : use absolute paths and fix tool naming ORIGEN : enable device tree support MX25: tx25: Fix building due to missing MACH_TYPE mx31: Add board support for HALE TT-01 mx31: add ESD control registers mx31: define pins and init for UART2 and CSPI3 MX35: add support for flea3 board MX51: vision2: add MACH_TYPE in config file vision2: Remove unused header file mx51evk: Remove unused get_board_rev function mx51evk: Remove unneeded '1' from mx51evk.h I2C: Fix mxc_i2c.c problem on imx31_phycore mx35pdk: Add RTC support mx51evk: Use GPIO API for configuring the IOMUX mx51evk: Add RTC support rtc: Make mc13783-rtc driver generic qong: remove unneeded IOMUX settings qong: Use mx31_set_gpr to setup USBH2 pins mx31: Introduce mx31_set_gpr function mx31pdk: Add MC13783 PMIC support qong: remove unneeded "1" from qong.h misc: pmic: fix regression in pmic_fsl.c (SPI) mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME MX35: Drop unnecessary prototypes from imx-regs.h I2C: added I2C-2 and I2C-3 to MX35 MX35: factorize common assembly code MX35: add reset cause as provided by other i.MX MX35: add pins definition for UART3 MX35: added ESDC structure to imx-regs
2011-11-07ColdFire:Moving the remaining coldfire boards to boards.cfgJason Jin
Move the coldfire boards to boards.cfg. The config name for the EB+MCF-EV123 boards are changed to EB-MCF-EV123 as the '+' cannot be recognized. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-11-03arm, davinci: add support for new spl frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03sandbox: Adjust Makefile so that standalone/api are not builtSimon Glass
The check for sandbox architecture is too early in the Makefile, so standalone and api are built regardless. This moves the check until after autoconf.mk has been read. This fixes a build breakage. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27ARM:AM33XX: Added timer supportChandan Nath
This patch adds timer support for AM33xx platform. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. The device tree compiler output should be placed in the $(obj) rooted tree. Since $(OBJCOPY) insists on adding the path to the generated symbol names, to ensure consistency it should be invoked from the directory where the .dtb file is located and given the input file name without the path. This commit contains my entry for the ugliest Makefile / shell interaction competition. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-22autoconf.mk.dep: use target cflags, not hostMike Frysinger
The current autoconf.mk.dep rule uses the host cflags when executing the target compiler (which includes target header files). We don't want to mix the target compiler and host compiler flags, so change it to CFLAGS. Otherwise we get things like -pedantic which the U-Boot source code does not build with. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22Makefile: Remove MLO on make cleanJoel A Fernandes
SPL builds could leave an MLO which is an mkimage of type omapimage Make sure its deleted on make clean/distclean Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
2011-10-22examples: api: allow build with private libgccChe-liang Chiou
The examples/api is not configured with USE_PRIVATE_LIBGCC. This makes building examples/api break on certain boards that do not/cannot use the public libgcc. Nevertheless, this patch has to also touch the top-level Makefile to fix this problem because the current top-level Makefile does not specify libgcc as a prerequisite of examples/api, and explicitly builds examples/api _before_ libgcc. For testing this patch, I added the following to configs/seaboard.h and ran demo.bin on a Seaboard. +#define CONFIG_API +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#define CONFIG_CMD_NET +#define CONFIG_NET_MULTI Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-19ColdFire: Clean Makefile _config rulesstany MARCEL
Remove unused mkdir, and add missing ones. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
2011-10-19ColdFire: Move boards with simple _config rules to boards.cfgstany MARCEL
2011-10-19ColdFire: Merge differentiated linking files into a sigle one by boardstany MARCEL
The spa, stm, int, 32 and 16 linking files are identical so there is no need to differentiate them. A single lds file is now used, and _config rule are simplified. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
2011-10-17Move timestamp and version files into 'generated' subdirSimon Glass
There is a rather subtle build problem where the build time stamp is not updated for out-of-tree builds if there exists an in-tree build which has a valid timestamp file. So if you do an in-tree build, then an out-of-tree build your timestamp will not change. The correct timestamp_autogenerated.h lives in the object tree, but it is not always found there. The source still lives in the source tree and when compiling version.h, it includes timestamp_autogenerated.h. Since the current directory is always searched first, this will come from the source tree rather than the object tree if it exists there. This affects dependency generation also, which means that common/cmd_version.o will not even be rebuilt if you have ever done an in-tree build. A similar problem exists with the version file. This change moves both files into the 'generated' subdir, which is already used for asm-offsets.h. Then timestamp.h and version.h are updated to include the files from there. There are other places where these generated files are included, but I cannot see why these don't just use the timestamp.h and version.h headers. So this change also tidies that up. I have tested this with in- and out-of-tree builds, but not SPL. I have looked at various other options for fixing this, including sed on the dep files, -I- and -include flags to gcc, but I don't think they can be made to work. Comments welcome. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17sandbox: Makefile changes to build sandbox architectureSimon Glass
At this point U-Boot will build and run on x86 under Linux. The idea is to define a new architecture called 'sandbox', alongside ARM and x86. This runs natively on Linux to suit the host machine. All hardware access is either omitted or emulated. The purpose of this system is to test the bulk of the non-hardware-specific U-Boot code. We can mock the SPI flash, GPIOs, UART and keyboard, then test that U-Boot behaves as we wish. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17Adjust dependency rules to permit per-file flagsSimon Glass
The dependency rules are currently done in a shell 'for' loop. This does not permit Makefile variables to adjust preprocessor flags as is done with normal compile flags, using the CFLAGS_path/file.o syntax. This change moves the dependency generation into the Makefile itself, and permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or directory basis. The CPPFLAGS_... variable is also folded into CFLAGS during the build. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Disable standalone/API supportSimon Glass
This is not useful on the sandbox architecture since we can simply link all our code with U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-06Safer timestamp_autogenerated.h generationLoïc Minier
Generate timestamp_autogenerated.h as safely as version_autogenerated.h. Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06Build timestamp_autogenerated.h without configLoïc Minier
Tools such as mkimage include version information but are config-agnostic; build timestamp_autogenerated.h even when config.mk isn't generated to fix "make tools" build failure: gcc [...] -o mkimage.o mkimage.c -c In file included from include/version.h:27:0, from mkimage.c:26: include/timestamp.h:27:37: fatal error: timestamp_autogenerated.h: No such file or directory Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05Makefile: remove mx31pdk exceptionStefano Babic
An entry in the main Makefile for the mx31pdk board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05Makefile: drop imx31_phycore from general MakefileStefano Babic
2011-10-05Makefile: remove tx25 exceptionStefano Babic
An entry in the main Makefile for the tx25 board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-29powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driverYork Sun
Unified DDR driver is maintained for better performance, robustness and bug fixes. Upgrading to use unified DDR driver for MPC83xx takes advantage of overall improvement. It requires changes for board files to customize platform-dependent parameters. To utilize the unified DDR driver, a board needs to define CONFIG_FSL_DDRx in the header file. No more boards will be accepted without such definition. Note: the workaround for erratum DDR6 for the very old MPC834x Rev 1.0/1.1 and MPC8360 Rev 1.1/1.2 parts is not migrated to unified driver. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add support for FMan ethernet in Independent modeKumar Gala
The Frame Manager (FMan) on QorIQ SoCs with DPAA (datapath acceleration architecture) is the ethernet contoller block. Normally it is utilized via Queue Manager (Qman) and Buffer Manager (Bman). However for boot usage the FMan supports a mode similar to QE or CPM ethernet collers called Independent mode. Additionally the FMan block supports multiple 1g and 10g interfaces as a single entity in the system rather than each controller being managed uniquely. This means we have to initialize all of Fman regardless of the number of interfaces we utilize. Different SoCs support different combinations of the number of FMan as well as the number of 1g & 10g interfaces support per Fman. We add support for the following SoCs: * P1023 - 1 Fman, 2x1g * P4080 - 2 Fman, each Fman has 4x1g and 1x10g * P204x/P3041/P5020 - 1 Fman, 5x1g, 1x10g Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Ioana Radulescu <ruxandra.radulescu@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29Prepare v2011.09v2011.09Wolfgang Denk
2011-09-22Prepare v2011.09-rc2v2011.09-rc2Wolfgang Denk
2011-09-11Prepare v2011.09v2011.09-rc1Wolfgang Denk
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04ColdFire:Fix the configuration broken for some boards.Jason Jin
Some typoes in Makefile and boards.cfg make the M54455 board and M53017 board configuration broken. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "edb93xx" boardsWolfgang Denk
Remove edb9301, edb9302, edb9302a, edb9307, edb9307a, edb9312, edb9315 and edb9315a boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-28Correct ih_os for u-boot.imganeeshv
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-28Let source cross-reference targets follow symbolic linksHorst Kronstorfer
Tell 'find' to follow symbolic links, so that files under include/asm and arch/$(ARCH)/include/asm/arch are added to the indexing file list. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com> Acked-by: Detlev Zundel <dzu@denx.de>
