- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- logdl
- csb226
- innokom
* Patch by Pantelis Antoniou, 25 Jun 2003:
update NetVia with V2 board support
* Patch by Murray Jensen, 24 Jun 2003:
- make sure to use only U-boot provided header files
- fix problems with ".rodata.str1.4" section as used by GCC-3.x
Fix clock divider rounding problem in drivers/serial.c
* Patch by Ken Chou, 19 June 2003:
Added support for A3000 SBC board (Artis Microsystems Inc.)
- add support for Logotronic DL datalogger board
- cleanup serial line after kermit binary download
- add debugX macro (debug level support)
- update mach-types.h to latest arm.linux.org.uk master list.
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
add support for the MIP405T board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
In preparation for an ixp port, rename cpu/xscale and arch-xscale
into cpu/pxa and arch-pxa.
- BUBINGA405EP added (PPC405EP based).
- CPCI405AB added (PPC405GP based).
- PMC405 added (PPC405GP based).
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
Add IDMA example code (tested on 8260 only)
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
- Add port to MPC555/556 microcontrollers
- Add support for cmi customer board with
Intel 28F128J3A, 28F320J3A or 28F640J3A flash.
* Patch by Rick Bronson, 28 Mar 2003:
- fix common/cmd_nand.c
- add threads / scheduler example code
- add ctrl-c support for kermit download
- align bdinfo output on ARM
* Add CPU ID, version, and clock speed for INCA-IP
Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
- Add support for Innokom board
- Don't complain if "install" fails
- README cleanup (remove duplicated lines)
- Update PXA header files
* Add documentation for existing POST code (doc/README.POST)
* Patch by Laudney Ren, 15 Jan 2003:
Fix handling of redundand environment in "tools/envcrc.c"
* Patch by Detlev Zundel, 28 Feb 2003:
Add bedbug support for 824x systems
* Add support for 16 MB flash configuration of TRAB board
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
(patch by Jón Benediktsson, 11 Dec 2002)
to log on the console, too (like in Linux); get rid of "logstart"
Fixes for x86 port (mostly strings issues)
* Patch by Ken Chou, 18 Nov 2002:
Fix for natsemi NIC cards (DP83815)
* Patch by Pierre Aubert, 19 Nov 2002:
fix a bug for the MII configuration, and some warnings
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
- use watchdog to reset PXA250 systems
- added progress callbacks to (some of the) ARM code
- update for Cogent CSB226 board
* Add support for FPS860 board
