On clobber, do a cleanup even for SPL build else, we'd have
MLO.byteswap remaining for certain platforms like am33xx SPL builds
Signed-off-by: Nishanth Menon <nm@ti.com>
This commit merges branches from samsung, imx and tegra
meant to fix merge issues between u-boot/master and
u-boot-arm/master, as well as a few manual merge fixes.
README
arch/arm/cpu/armv7/exynos/clock.c
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
README
include/configs/woodburn_common.h
board/woodburn/woodburn.c
These boards still use the old old PMIC framework, so they
do not merge properly after the power framework was merged into
mainline.
Fix all conflicts and update woodburn to use Power Framework.
Use the printf command to convert the number in any valid format into
the expected decimal format. The resulting errors should be printed to
stderr.
This new make target "u-boot-img.bin" consists of the U-Boot
SPL image with the real, full-blown U-Boot image directly
attached to it. The full-blown U-Boot image has the mkimage
header included, with its load-address and entry-point.
This will be used by the upcoming a3m071 MPC5200 board port.
This patch enabled boards using the SPL framework to set
an entry point in the U-Boot mkimage image "u-boot.img".
Until now the entry point in the header has been set to 0.
By setting CONFIG_SYS_UBOOT_START in the board header, boards
can override this default location.
The elftosb tool is now called with -d switch, which produces debug
output to the stdout. The debug output is completely useless for
regular operation, so silence it.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
When running from coreboot we don't want this code.
This version works by ifdef-ing out all of the code that would go
into those sections and all the code that refers to it. The sections are
then empty, and the linker will either leave them empty for the loader
to ignore or remove them entirely.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
This was introduced by commit 244615197469dd6fe75ae082f38424b97c79aeaf, but it
fails in a minimal SPL build where the only thing in arch/powerpc/lib is
cache.c, which apparently doesn't generate any fixup records.
The problem is reported to occur with GCC 3.x, so insist on GCC 4.0 or newer.
Patterned after checkthumb as suggested by Tom Rini.
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Tom Rini <trini@ti.com>
v2: test gcc version instead of testing nothing
Currently the SPL target is specified in a CPU-specific makefile
fragment. While some targets may need something more complicated than a
simple target name, targets which don't need this shouldn't have to provide a makefile fragment just for this.
v2: Removed default target as it's been pointed out to me how existing platforms
cause the SPL to be built.
Samsung's S3C24XX SoCs need this in order to generate a binary image
with a padded SPL concatenated with U-Boot.
Signed-off-by: José Miguel Gonçalves <jose.goncalves@inov.pt>
[scottwood@freescale.com: fixed prereq of u-boot.ubl]
v2: Removed spl/ prefix from u-boot.ubl prerequisite.
Existing U-Boot musb driver has no support for the new gadget framework
and also seems to have other limitations. As gadget framework is ported
from Linux it seems pretty natural to port musb gadget driver as well.
This driver supports both host and peripheral modes.
This is not a replacement for current musb driver (at least now) as
there are still some consumers of the old UDC interface.
No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be
defined.
Virtual root hub device is not implemented.
Known problems: with no devices connected usb_lowlevel_start() fails.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
This patch adds driver for I2S interface specific to samsung.
Signed-off-by: R. Chandrasekar <rcsekar@samsung.com>
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997
power management device.
Special file - fg_battery_cell_params.h with cells characteristics
added.
The FG device will work with redesigned PMIC framework.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Trats battery is now treated in the same way as other power related
devices. This approach allows for more unified handling of all devices
responsible for power management.
The PMIC framework has been moved to its more natural place
./drivers/power from ./drivers/misc directory.
When using SUBLEVEL for the -rc? tag, this results in an ugly version
string like "2013.01.-rc1" - let's use EXTRAVERSION instead to get the
simple "2013.01-rc1"
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load},
and transparently handle either file-system. This scheme could easily be
extended to other filesystem types; I only didn't do it for zfs because
I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code
too.
The rules to generate u-boot-{no,}dtb-tegra.bin were almost identical.
Combine them into a single paremeterized rule. This will allow the next
patch to edit a single rule, rather than being cut/paste twice.
Signed-off-by: Tom Warren <twarren@nvidia.com>
SX1 does not build properly by itself, is not built
as part of MAKEALL arm or MAKEALL -a arm, and is only
present in Makefile, not boards.cfg. As it also has no
entry in MAINTAINERS, it is orphan and non-functional.
Remove it.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The patch adds SPL for the arm1136 architecture and
inserts SPL (the produced binary) to clobber target
in the main Makefile.
This change adds CBFS support and some commands to use it to u-boot. These
commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of
the ROM is an optional parameter which defaults to the standard 0xffffffff and
can be used to support multiple CBFSes in a system. The last one set up with
cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current
CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat
filesystems, you can optionally provide a maximum size.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
The CBFS driver can also be used programmatically from within u-boot.
If u-boot needs something out of CBFS very early before the heap is
configured, it won't be able to use the normal CBFS support which caches some
information in memory it allocates from the heap. The
cbfs_file_find_uncached function searches a CBFS instance without touching
the heap.
Signed-off-by: Gabe Black <gabeblack@google.com>
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
This patch adds essential components for generation of the contents of
the linker section that is used by the linker-generated array. All of
the contents is held in a separate file, u-boot.lst, which is generated
at runtime just before U-Boot is linked.
The purpose of this code is to especially generate the appropriate
boundary symbols around each subsection in the section carrying the
linker-generated arrays. Obviously, the interim linker code for actual
placement of the variables into the section is generated too. The
generated file, u-boot.lst, is included into u-boot.lds via the linker
INCLUDE directive in u-boot.lds .
Adjustments are made in the Makefile and spl/Makefile so that the
u-boot.lds and u-boot-spl.lds depend on their respective .lst files.
Tested-by: Joe Hershberger <joe.hershberger@ni.com>
Pull slightly modified version of Documentation/DocBook, the related perl
script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and
implant it into U-Boot. This will allow smooth generation of kerneldoc
style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build
system. The changes were only minor though and involved replacing the kbuild
specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with
U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so
the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in
U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in
case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with
Linux kernel, these parts are still left in. The targets enabled now are
"htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results
of documentation build.
Linux scripts/docproc.c:
commit f0f3ca8d967462dafb815412b14ca3339b9817a6
Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc:
commit 1b40c1944db445c1de1c47ffd8cd426167f488e8
Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook:
commit bb8187d35f820671d6dd76700d77a6b55f95e2c5
Date: Thu May 17 19:06:13 2012 -0400
patches.
Move files that are going to be common between T20 and T30 into 'tegra-common'
subdirs in AVP (arm720t), CPU (armv7), and shared (arch/arm/cpu/.) areas. Any
files that are left behind in '/tegra20' will be copied to '/tegra30' subdirs
and modified for that SoC. The 'common' files should need only minor changes.
Include files (arch/arm/include/asm/arch-tegra/tegra20) will be done in a
follow-on patch.
Builds fine w/MAKEALL -s tegra20. Checkpatch.pl is clean.
Add support for running source code checkers on u-boot source, e.g.,
using sparse to aid with typechecking. This comes in especially
handy as SoC vendors mix and match cores and devices with different
endianness, thus here we add CHECK_ENDIAN to the otherwise linux
kernel default CHECKFLAGS.
- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs.
- Remove duplicated code.
- Add spl_boot_device() that returns the statically chosen boot device.
The 'clean' target has been removing all of spl but not u-boot itself.
For consistency and ease of testing, only remove SPL binaries / maps in
the clobber target, just like for full U-Boot
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
