path: root/Makefile
2011-09-29Prepare v2011.09v2011.09Wolfgang Denk
2011-09-22Prepare v2011.09-rc2v2011.09-rc2Wolfgang Denk
2011-09-11Prepare v2011.09v2011.09-rc1Wolfgang Denk
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04ColdFire:Fix the configuration broken for some boards.Jason Jin
Some typoes in Makefile and boards.cfg make the M54455 board and M53017 board configuration broken. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "edb93xx" boardsWolfgang Denk
Remove edb9301, edb9302, edb9302a, edb9307, edb9307a, edb9312, edb9315 and edb9315a boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-28Correct ih_os for u-boot.imganeeshv
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-28Let source cross-reference targets follow symbolic linksHorst Kronstorfer
Tell 'find' to follow symbolic links, so that files under include/asm and arch/$(ARCH)/include/asm/arch are added to the indexing file list. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-26fix unconfigured out-of-tree building of toolsMike Frysinger
Now that the tools target requires the generated version header file, we need to make sure that the directory it writes to exists. In a configured tree, this is taken care of for us. But in an unconfigured one, the dir does not yet exist causing a build error like so: /bin/sh: line 5: ..../u-boot_build/include/version_autogenerated.h.tmp: No such file or directory So create the dir for this file before we attempt to generate it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26simplify clobber behavior with out-of-tree buildsMike Frysinger
The targets/prerequisites are the same here; the rules only differ in the recipes. So move the if logic protection to the recipe part so we can keep the rest the same. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Hook SPL build-system into toplevel MakefileDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-26Extend build-system for SPL frameworkDaniel Schwierzeck
2011-07-26Use ALL-y style instead of ifeq blocks for better readabilityDaniel Schwierzeck
2011-07-12Blackfin: add init.elf helper codeMike Frysinger
This creates a standalone ELF that executes just the Blackfin initcode. This is useful for people who want to program the low level aspects of the CPU (memory/clocks/etc...) and can easily be used with JTAG for quick booting while developing. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-01Makefile: need to remove generated u-boot-nand_spl.ldsKumar Gala
On MPC85xx based NAND_SPL builds we generate a u-boot-nand_spl.lds based on output from preprocessor. We where never removed it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-06-30nios2: move generic config to boards.cfgMike Frysinger
I can't build test this, but just looking at the config files written and it seems OK ... Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-06-27Prepare v2011.06v2011.06Wolfgang Denk
2011-06-25usb: convert to partial linkingMike Frysinger
Looks like this was missed during the conversion to partial linking. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22Makefile: move $(VERSION_FILE) rule out of ifeq configuredIlya Yanok
mkimage relies on autogenerated version so we need to move $(VERSION_FILE) rule out of ifeq and make tools rule depend on it to be able to run 'make tools' from the unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22config.mk: move LDSCRIPT processing to the top-level MakefileIlya Yanok
LDSCRIPT is used only from the top-level Makefile and only when the system is configured so we can move LDSCRIPT and CONFIG_SYS_LDSCRIPT related logic into the top level Makefile and under configured condition to avoid errors when building tools from unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-22Prepare v2011.06-rc3v2011.06-rc3Wolfgang Denk
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-02Prepare v2011.06-rc2v2011.06-rc2Wolfgang Denk
2011-05-26ARMV7: MMC SPL Boot support for SMDKV310 boardChander Kashyap
Added MMC SPL boot support for SMDKV310. This framework design is based on nand_spl support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-19Prepare v2011.06-rc1v2011.06-rc1Wolfgang Denk
2011-05-12examples: add smc911x_eeprom to clean targetMike Frysinger
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-27nhk8815: move config targets from Makefile to boards.cfgAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2011-04-27cpuat91: fix board supportEric Benard
- fix board support following relocation changes - switch to boards.cfg - disable i2c to keep size under 128kiB (1 sector) Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-04-27Makefile: change rule to build IMX imageStefano Babic
config.mk in board directory is obsolete and should be removed. The patch allows to get rid of own config.mk adding the imximage.cfg file to the options in the boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12mkimage: add "-V" option to print version informationWolfgang Denk
2011-04-01Fix NAND_SPL and ONENAND_IPL in MakefileHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-03-31Prepare v2011.03v2011.03Wolfgang Denk
2011-03-27Prepare vv2011.03-rc2Wolfgang Denk
