Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact
on files outside of this scope.
Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig:
re-sync with Linux 4.17-rc4").
A very small number of changes upstream since our sync with v4.17-rc4
that exist in the v4.18 release have already been applied here and have
been omitted from the list in this commit (and are readily available in
our own git history).
The imported Linux commits are:
[From prior to v4.17-rc4]
39a33ff80a25 kbuild: remove cc-option-align
db547ef19064 Kbuild: don't add obj tree in additional includes
b999596b963a Kbuild: don't add ../../ to include path
[From v4.17 to v4.18]
b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files
74656b682902 kbuild: disable new dtc graph and unit-address warnings
74d931716151 genksyms: remove symbol prefix support
e6ecfb45072c kbuild: do not display CHK for filechk
0b669a5076fd kconfig: refactor Qt package checks for building qconf
b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf
1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf
694c49a7c01c kconfig: drop localization support
96f60dfa5819 trace: Use -mcount-record for dynamic ftrace
bb222ceeb327 kconfig: remove string expansion in file_lookup()
96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse()
5b31a9746756 kconfig: remove sym_expand_string_value()
137c0118a900 kconfig: make default prompt of mainmenu less specific
e298f3b49def kconfig: add built-in function support
2fd5b09c201e kconfig: add 'shell' built-in function
9de071536c87 kconfig: begin PARAM state only when seeing a command keyword
9ced3bddec08 kconfig: support user-defined function and recursively expanded variable
1175c02506ff kconfig: support simply expanded variable
ed2a22f277c6 kconfig: support append assignment operator
82bc8bd82e5c kconfig: expand lefthand side of assignment statement
1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions
a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables
915f64901eb3 kconfig: error out if a recursive variable references itself
2bece88f89fa kconfig: test: add Kconfig macro language tests
21c54b774744 kconfig: show compiler version text in the top comment
59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice
145167650b96 kbuild: add endianness flag to CHEKCFLAGS
1f2f01b122d7 kbuild: add machine size to CHECKFLAGS
d6a0c8a1326b kconfig: Add testconfig into make help output
bb6d83dde191 kbuild: Move last word of nconfig help to the previous line
8593080c0fcf kconfig: fix localmodconfig
ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount
b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree
ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol()
73d1c580f92b kconfig: loop boundary condition fix
48f6e3cf5bc6 kbuild: do not drop -I without parameter
bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is
6916162c7308 kbuild: remove duplicated comments about PHONY
Cc: Masahiro Yamada <masahiroy@kernel.org>
Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
Allow the default environment file to contain long lines split into
multiples lines.
Leading white spaces can be added for readability as well.
Signed-off-by: Samuel Mescoff <samuel@mescoff.fr>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Support redundant boot for rk3399
- Support binman for rockchip platform
- Update ram driver and add ddr4 support for rk3328
Since commit e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to
reST") MIGRATION.txt has been converted to migration.rst, so update
the Makefile references accordingly.
Fixes: e1910d93b890 ("doc: driver-model: Convert MIGRATION.txt to reST")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
All rockchip platforms support TPL or SPL-based bootloader
in mainline with U-Boot proper as final stage. For each
stage we need to burn the image on to flash with respective
offsets.
This patch creates a single boot image component using
- binman, for arm32 rockchip platforms
- pad_cat, for arm64 rockchip platforms.
This would help users to get rid of burning different
boot stage images.
The new image called 'u-boot-rockchip.bin'
which can burn into flash like:
₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64
This would support all rockchip platforms, except rk3128
since it doesn't support for SPL yet.
Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Cc: Wadim Egorov <w.egorov@phytec.de>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add SPL-alone mkimage tooling support via Makefile for
few platforms or boards used in rockchip family.
With this users would get rid of explicitly creating
mkimage tool for rockchip rksd or rkspi boot modes.
Most of the platforms uses the platform type on their boot
stage image naming conventions in makefile like,
u-boot-x86-start16-tpl.bin - x86 start16 TPL bin
u-boot-spl-mtk.bin - Mediatek SPL bin
This would help to understand the users to what that
particular image belongs to? and less confused.
On that note, suffix platform type rockchip for existing
u-boot-tpl.img so now it become u-boot-tpl-rockchip.bin
Also, bin is more conventional way to include it on tools
like binman, pad_cat etc in future patches.
Note: usage of platform type doesn't follow consistent order
as of now.
Add rockchip image type support. right now the image
type marked with rksd, So create image type variable
with required image type like rksd or rkspi.
In order to generate a bootable U-Boot binary for i.MX8QXP MEK
we need to run:
$ make imx8qxp_mek_defconfig
$ make flash.bin
The resultant flash.bin and flash.log are not removed after
running 'make mrproper'.
Include these files into the CLEAN_FILES list entry so that
they can be properly deleted after 'make mrproper'.
This only exists to control whether the post/ directory is build. It is
just as easy to check this in the Makefile. Remove CONFIG_HAS_POST and use
an ifdef in the Makefile instead.
GCC 9.x starts complaining about potential misalignment of the pointer to
the array (in this case alignment=2) in the packed (alignment=1) structures.
Repeating Linus' Torvalds commit 6f303d60534c in the Linux kernel.
Original commit message:
We already did this for clang, but now gcc has that warning too.
Yes, yes, the address may be unaligned. And that's kind of the point.
This in particular hides the warnings like
drivers/usb/gadget/composite.c:545:23: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
545 | collect_langs(sp, s->wData);
drivers/usb/gadget/composite.c:550:24: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
550 | collect_langs(sp, s->wData);
drivers/usb/gadget/composite.c:555:25: warning: taking address of packed member of ‘struct usb_string_descriptor’ may result in an unaligned pointer value [-Waddress-of-packed-member]
555 | collect_langs(sp, s->wData);
This patches restores boot on boards which rely on
CONFIG_SYS_UBOOT_START equal to CONFIG_SYS_TEXT_BASE when using SPL
Fixes: d3e97b53c1f2 ("spl: fix entry_point equal to load_addr")
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
If u-boot.img is a FIT image, CONFIG_OF_OVERLAY_LIST can be used to add
DT overlays to u-boot.img.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
With the change to make tools/version.h a file we need to make sure that
the output directory exists first otherwise we will get a build failure.
Reported-by: Peter Robinson <pbrobinson@gmail.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Fixes: 4d90f6cd9813 ("tools: Avoid creating symbolic links for tools/version.h")
This rule will be used to build x509 and pkcs7 parsers.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Move MTD-related lines out of the root Makefile. Put them in their
respective directories. Enclose some of these new lines to skip them
when building the SPL. MTD core files and some MTD device drivers are
compiled in a mtd.o object and included in the final object only if
MTD support is required (there are two different symbols for that, one
for U-Boot and one for the SPL).
Now that all defconfigs have been fixed, we can stop the logic where
enabling a command selects the core files to compile. This logic is
broken since selecting a symbol with a 'depends on' will not enforce
this secondary dependency.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
This file is generated in the root during Rockchip builds and so should
be cleaned up.
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
Currently, we have two places where we list files that should always be
cleaned if they exist. One, the CLEAN_FILES variable, is from the Linux
build system and is the proper place to list files.
The other, a set of extra arguments passed in the xargs template used to
remove files with certain extensions, was introduced by 8f06f0cee3d3
("Makefile: clean image.map") and is clearly wrong: by extending the
xargs template, we attempt to remove the files once for each batch of
arguments that xargs produces and we reduce the number of files from
stdin that xargs can include in each of its rm commands.
To fix this, put all hardcoded files into CLEAN_FILES.
All of the clean targets (clean, dist-clean, mrproper) are run without
loading a configuration. That means that any conditional modification of
CLEAN_FILES will either always apply or never apply and so shouldn't be
in a conditional in the first place.
Since CLEAN_FILES is allowed to list nonexistent files, just add
everything to it unconditionally to fix the issue.
The NAND devices with 128 kiB erase blocks require extra 64 kiB padding
between each SPL image. Generate U-Boot image with such a padding using
this new target.
Cc: Chin Liang See <chin.liang.see@intel.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Cc: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Add OP-TEE test swuit
Fix patman cc_file output
Minor sandbox/pinctrl changes
OP-TEE can get supplied with a devicetree and will then insert
its firmware node and reserved-memory sections into it.
As this devicetree often is not the one supplied to a later
loaded kernel, a previous commit added functionality to transfer
these nodes onto that new devicetree.
To make sure this functionality stays intact, also add a test
for the transfer functionality.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
On the sandbox the UEFI binaries must match the host architectures.
Adjust the Makefiles. Provide the PE/COFF header and relocation files.
Allow building helloworld.efi on the sandbox.
Add support for USB3 host and gadget driver. This is a direct sync of
Linux kernel Cadence USB stack that from v5.4-rc1 release.
Driver has been modified so that it compiles without errors against
U-Boot code base.
Features not required for U-Boot such as scatter-gather DMA and OTG
interrupt handling has been dropped.
[jjhiblot@ti.com: Add PHY support]
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
imx targets are defined in arch/arm/mach-imx/Makefile.
Some of them are dependent on targets defined in main
Makefile. For the Makefile in arch/arm/mach-imx this
targets must be finished before the imx targets are
build, if not you get for example the error:
make -f /home/hs/abb/mainlining/u-boot/scripts/Makefile.build obj=arch/arm/mach-imx u-boot-dtb.imx
make[2]: *** No rule to make target 'u-boot-fit-dtb.bin', needed by 'u-boot-dtb.imx'. Stop.
make[1]: *** [/home/hs/abb/mainlining/u-boot/Makefile:1123: u-boot-dtb.imx] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/work/hs/compile/u-boot/aristainetos2_defconfig'
make: *** [Makefile:148: sub-make] Error 2
compile failed
In above case of CONFIG_MULTI_DTB_FIT is defined, the
u-boot-dtb.imx is dependent on the u-boot-fit-dtb.bin
which may is not build yet ...
I could reproduce this error on a travis build also if
I build an out-of-tree build on a local machine with a
build directory on a "slow" slow storage device. If
building the same source target with a build dir on a
fast storage device, the build works.
I found no solution to tell the arch/arm/mach-imx/Makefile
to find the targets in main Makefile, if there is a way
this would be the better fix.
I solved it by adding a IMX_DEPS var, which holds a list
of main u-boot targets, which must be finished, before
calling imx targets and fixed the build for imx
targets which enabled CONFIG_MULTI_DTB_FIT.
I think it is just luck, that imx targets with
CONFIG_OF_SEPARATE enabled build, because the
u-boot-dtb.imx target depends on u-boot-dtb.bin
which gets build early enough before starting with
u-boot-dtb.imx. May this targets should be fixed too.
We have the ability to enforce a maximum size for SPL but not yet for TPL.
Add a new option for this.
Document the size check macro while we are here.
When we have an excess size growth, fix the "limit" printf call to pass
in just the limit variable rather than the string bytes to the format
character.
At present some boards generate kwbimage.cfg in the source tree
during the build. This breaks buildman testing on some systems
where the source tree is read-only. Update makefile rules to
generate it in the build tree instead.
Note some other boards have the kwbimage.cfg file written in
advance, hence we need check if the file exists in the build
tree first, otherwise we fall back to one in the source tree.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
When building U-Boot host tools for Windows from Microsoft Azure
Pipelines, the following errors were seen:
HOSTCC tools/mkenvimage.o
In file included from tools/mkenvimage.c:25:
./tools/version.h:1:1: error: expected identifier or ‘(’ before ‘.’ token
1 | ../include/version.h
tools/mkenvimage.c: In function ‘main’:
tools/mkenvimage.c:117:4: warning: implicit declaration of function ‘usage’ [-Wimplicit-function-declaration]
117 | usage(prg);
tools/mkenvimage.c:120:35: error: ‘PLAIN_VERSION’ undeclared (first use in this function)
120 | printf("%s version %s\n", prg, PLAIN_VERSION);
tools/mkenvimage.c:120:35: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [scripts/Makefile.host:114: tools/mkenvimage.o] Error 1
It turns out tools/version.h is a symbolic link and with Windows
default settings it is unsupported hence the actual content of
tools/version.h is not what file include/version.h has, but the
the linked file path, which breaks the build.
To fix this, remove the symbolic links for tools/version.h. Instead
we perform a copy from include/version.h during the build.
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
binman enhancements:
- Dropping some test Elf files and building them from source instead
- Refactoring of x86 16-bit entries
- Support for SPL symbols within sections
- Handle the 'notes' sections and hidden symbols in recent binutils
- Improved error reporting with a tool fails
libfdt and documentation fixes
vboot required-key test
driver model power-domain controls
patman Message-Id enhancement
cscope complains that it can't find files that appears to be symbolic links
cscope: cannot find file tools/binman/test/u_boot_binman_syms_bad.c
cscope: cannot find file tools/version.h
`find -L` tests properties, but name, and cscope can't cope with symbolic
links (a lot of bugs in upstream were simple closed as kinda invalid).
To work around the problem, exclude symbolic links from the cscope.files.
Note, it's done in two pass to speed up the process (`-exec realpath ...`
approach is not portable and introduces a 3x delay).
At present these two sections of code are linked together into a single
2KB chunk in a single file. Some Intel SoCs like to have a FIT (Firmware
Interface Table) in the ROM and the pointer for this needs to go at
0xffffffc0 which is in the middle of these two sections.
Make use of the new 'reset' entry and change the existing 16-bit entry to
include just the 16-bit data.
When building a FIT image for SPL to load also take into account the
configured external offset. This allows the SPL to load the u-boot FIT
image correctly when configuring SECURE_BOOT on i.mx6 is enabled
(with CONFIG_FIT_EXTERNAL_OFFSET=0x3000).
Note this doesn't allow secure booting; but it does allow an unsigned
SPL/u-boot with secure boot support eanbled to boot on open device.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20191009
Travis : https://travis-ci.org/sbabic/u-boot-imx/builds/595148532
- MX6UL / ULZ
- Toradex board
- Allow to set OCRAM for MX6Q/D
- MX7ULP
- MX8: (container image, imx8mq_mek), SCU API
- fix several board booting from SD/EMMC (cubox-i for example)
- pico boards
[trini: display5 merged manually]
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross
architecture purposes. If Secure Boot is required for imx, this means to
enable and use the HAB processor in the soc.
To support SPL loading container file, add a new Makefile target,
and introduce a new Kconfig file to source the cfg file which
will be parsed by mkimage.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This is currently a decimal value which is not as convenient or
meaningful. Also U-Boot tends to use hex everywhere.
Convert this option to hex and add a comment for the size_check macro.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
[bmeng: correct the typo in the commit title]
Support a new BINMAN_VERBOSE option to the build, to allow passing the
-v flag to binman.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Pass in the toolpath in case binman needs to use tools compiled in the
U-Boot tools/ directory.
