path: root/Makefile
2005-08-12Merge with /home/wd/git/u-boot/masterLABEL_2005_08_12_0050Wolfgang Denk
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-08-10Add configuration for IFM SPI eval boardWolfgang Denk
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
2005-08-05Merge with /home/wd/git/u-boot/jon_loeligerWolfgang Denk
2005-08-05Add support for MicroSys PM856 boardWolfgang Denk
Patch by Josef Wagner, 03 Aug 2005
2005-08-05Merge with /home/wd/git/u-boot/masterWolfgang Denk
2005-08-03Cleanup build problems (on Fedora Core x86_64 build host)Wolfgang Denk
2005-08-02Merge with rsync://git-user@source.denx.net/git/u-boot.gitJon Loeliger
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
2005-07-29* Patch by Ron Alder, 11 July 2005Lunsheng Wang
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board.
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
2005-05-30Patch by Juergen Selent, 17 May 2005:wdenk
Add support for Funkwerk VoVPN gateway module.
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
2005-05-09On LWMON we must use the watchdog to reset the board as the CPULABEL_2005_05_09_1245wdenk
genereated HRESET pulse is too short to reset the external circuitry.
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
2005-04-05Add support for TQM8560 boardLABEL_2005_04_05_1830wdenk
2005-04-03Patch by Jerry Van Baren, 08 Nov 2004:wdenk
- Add low-boot option for MPC8260ADS board (if lowboot is selected, the jumper for the HRCW source should select flash. If lowboot is not selected, the jumper for the HRCW source should select the BCSR. - change default load base address to 0x00400000
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
2005-03-14* Patch by David Brownell, 10 Mar 2005:wdenk
Restore copyright statements in OHCI drivers. * Add support for TQM8540 board
2005-02-03* Removed '--no-warn-mismatch' option from Makefile. This optionwdenk
makes 'ld' to overlook binary objects compatibility. * Moved $(PLATFORM_LIBS) from the library group (--start-group ... --end-group) outside of the group. This will make 'ld' to do _multiple_ search in the library group when resolving symbol references and do only a _single_ seach in libgcc.a after the group search. * Fix stability problems on CPC45 board again. * Make image detection for diskboot / usbboot / scsiboot more robust (also check header checksum)
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2005-01-09Patches by David Snowdon, 07 Sep 2004:wdenk
- add u-boot.hex target in the top level Makefile - add support for the UNSW/NICTA PLEB 2 board (pleb2) - use -mtune=xscale and -march=armv5 options for PXA
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-12-16some new esd boards addedstroese
2004-12-16Add support for INKA4X0 boardwdenk
2004-12-12Patch by Martin Krause, 27 Oct 2004:wdenk
- add support for "STK52xx" board (including PS/2 multiplexer) - add hardware detection for TQM5200
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-10-10* Patch by Gary Jennejohn, 01 Oct 2004:wdenk
- add support for CMC PU2 board - add support for I2C on at91rm9200 * Patch by Gary Jennejohn, 28 Sep 2004: fix baudrate handling on at91rm9200
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
2004-09-09Fix SysClk handling for PPChameleon and CATcenter boardswdenk
