Coding style cleanup, update CHANGELOG.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
commit 2e95004deb6e33e33bf1b8a92a38cd2115bac4c2 "mpc83xx: Add NAND boot support
for MPC8315E-RDB boards" symlinked nand_spl/board/freescale/mpc8315erdb to
mpc8313erdb in order to not duplicate code.
Since the main makefile builds nand_spl/board/$(BOARDDIR) (which makes sense),
and the board Makefile and linker script are the only two necessary files
to enable out-of-tree building, and other boards have duplicated nand makefiles
(e.g. 8536ds & 8569mds), it only seems prudent to copy these two files in the
name of the 8315 too.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Added support for the following EDB93xx boards:
EDB9301
EDB9302
EDB9302A
EDB9307
EDB9307A
EDB93012
EDB9315
EDB9315A
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
The EXBITGEN board has not been maintained for a long time; it has
build problems, but no hardware is available any more for testing.
Drop support for this board.
This patch add nand boot support for MPC8569mds board.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
This patch adds support for "imximage" (MX Boot Image)
to the mkimage utility. The imximage is used on the Freescales's
MX.25, MX.35 and MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
SPEAr320 SoC support contains basic spear320 support along with the
usage of following drivers
- serial driver(UART)
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
- emi driver(cfi support)
Signed-off-by: Vipin <vipin.kumar@st.com>
SPEAr310 SoC support contains basic spear310 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr300 SoC support contains basic spear300 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr600 SoC support contains basic spear600 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
It's useful to be able to build up the host tools without having to select
a board first. Pretty much all tools in there are config-independent
anyways.
Also add a shortcut "tools-all" to quickly build all host tools that are
actually config-independent to allow for simple test builds.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
During parallel build, the top Makefile spawns multiple sub-makes for
targets in cpu/$(CPU) and $(dir $(LDSCRIPT)). If the .depend files are
not present in these directories, the sub-makes may end up generating
these files simultaneously which leads to corrupted content.
A typical error message is:
.depend:39: *** multiple target patterns. Stop.
This patch serializes the creation of .depend in cpu/$(CPU) and
$(dir $(LDSCRIPT)) by adding these directories to the depend target
in the top Makefile.
Other directories in $(LIBS) are not affected since they contain only
one Make target and thus only one sub-make is spawned per directory.
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
The new board revision has a different LCD.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru>
Use the common config option for extracting the environment for embedding
into LDR files and clarify the LDR-specific option.
The caddy2 is a variant of the already supported vme8349. So we just
add the differences to this board port. To better support those two
boards we switched from fixed SDRAM configuration to usage of
spd_sdram(). This is done by providing a board specific SPD EEPROM
routine with different values for both boards.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
changed to use mkconfig -t option instead, plus misc codingstyle fixes.
The core support for NAND booting is there already, so this patch
is pretty straightforward.
There is one trick though: top level Makefile expects nand_spl to
be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code
from mpc8313erdb boards, and so to not duplicate the code we just
symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
o silence make during ln echo
o update documentation
o and avoid:
$ ./MAKEALL MPC8315ERDB_NAND
Configuring for MPC8315ERDB board...
sdram.o: In function `fixed_sdram':
/home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay'
by renaming udelay -> __udelay in the spirit of commit
3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog
support".
The twl4030 provides a PHY device for connecting a link device,
like musb, to physical connection.
This change adds the twl4030 usb registers and functions for
initializing the PHY as required by omap3.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Get tag directories from the $(__LIB) and also generate tag for .S files.
Signed-off-by: Li Yang <leoli@freescale.com>
lib_generic/zlib.c
This patch adds support for A320 evaluation board from Faraday. This board
uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM.
FA526 is an ARMv4 processor and uses the ARM920T source in this patch.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Integrate DA830 EVM support into U-Boot.
Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum
Digital EVM board. See http://www.spectrumdigital.com/
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
This patch adds support for the board IPEK01 based on the MPC5200.
The Futjitsu Lime graphics controller is configured in 16 bpp mode.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Start of support of
Texas Instruments Software Development Platform(SDP)
for OMAP3430 - SDP3430
Highlights of this platform are:
Flash Memory devices:
Sibley NOR, Micron 8bit NAND and OneNAND
Connectivity:
3 UARTs and expanded 4 UART ports + IrDA
Ethernet, USB
Other peripherals:
TWL5030 PMIC+Audio+Keypad
VGA display
Expansion ports:
Memory devices plugin boards (PISMO)
Connectivity board for GPS,WLAN etc.
Completely configurable boot sequence and device mapping
etc.
Support default jumpering and:
- UART1/ttyS0 console(legacy sdp3430 u-boot)
- UART3/ttyS2 console (matching other boards,
and SDP HW docs)
- Ethernet
- mmc0
- NOR boot
Currently the UART1 is enabled by default. for
compatibility with other OMAP3 u-boot platforms,
enable the #define of CONSOLE_J9.
Makefile
Fixed the conflict with smdkc100_config by moving omap_sdp3430_config
to it is alphabetically sorted location above zoom1.
Signed-off-by: David Brownell <david-b@pacbell.net>
Signed-off-by: Nishanth Menon <nm@ti.com>
This patch adds support for the leopard board which is
based on the DM355 SOC.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch adds the initial support for DM6467 EVM.
Other features like NET and NAND support will be added as follow up patches.
The majority of the time that I build things in U-Boot, I want to just
build for the board. I don't make board config tweaks after selecting the
board. So add a new pattern rule that allows people to combine two steps
in one go:
`make foo_config && make` => `make foo`
This shouldn't conflict with any existing make rules as the pattern rule
is used only the rule doesn't already exist.
On Chip BootROM support for P1 and P2 series RDB platforms.
This patch is derived from latest On Chip BootROM support on MPC8536DS
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
NAND Boot support for P1 and P2 series RDB platforms.
This patch is derived from NAND Boot support on MPC8536DS.
Adds new board SMDKC100 that uses s5pc100 SoC
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
The implementation is borrowed from the sheevaplug board and the Marvell
1.1.4 code. Unsupported (or untested) is the SD card, PCIe and SATA.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
these boards are built around Atmel's AT91SAM9260/9G20 and have
up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND
and include a 10/100 Ethernet PHY in RMII mode.
Signed-off-by: Eric Benard <eric@eukrea.com>
