Renesas Solutions R7780MP is a reference board on SH7780.
This board has serial, 10/100 base Ethernet deivice, CF slot
and VGA devices. This board can set extension board.
Extension board has 10/100/1000 base Ethernet device, PCI slot,
S-ATA, iDVR slot.
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
Migo-R is a board based on SH7722 and has may devices.
In this patch, supported SCIF, NOR flash and Ethernet.
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Flex-OneNAND is a monolithic integrated circuit with a NAND Flash array
using a NOR Flash interface. This on-chip integration enables system designers
to reduce external system logic and use high-density NAND Flash
in applications that would otherwise have to use more NOR components.
Flex-OneNAND enables users to configure to partition it into SLC and MLC areas
in more flexible way. While MLC area of Flex-OneNAND can be used to store data
that require low reliability and high density, SLC area of Flex-OneNAND
to store data that need high reliability and high performance. Flex-OneNAND
can let users take advantage of storing these two different types of data
into one chip, which is making Flex-OneNAND more cost- and space-effective.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
460EX doesn't support a fixed bootstrap option to boot from 512 byte page
NAND devices. The only bootstrap option for NAND booting is option F for
2k page devices. So to boot from a 512 bype page device, the I2C bootstrap
EEPROM needs to be programmed accordingly.
This patch adds basic NAND booting support for the AMCC Canyonlands aval
board and also adds support to the "bootstrap" command, to enable NAND
booting I2C setting.
Tested with 512 byte page NAND device (32MByte) on Canyonlands.
This patch adds support for the AMCC Canyonlands 460EX evaluation
board.
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
and simplify Makefile a bit.
Commit 5013c09f (Makefile: cleanup "clean" target) introduced a
problem for out-of-tree builds which caused "make clean" to fail.
Make sure CDPATH settings cannot interfere.
Update CHANGELOG.
Add cscope build target to generate cscope database for code browsing.
Signed-off-by: Li Yang <leoli@freescale.com>
Adds PCI support for MPC5121
Tested with drivers/net/rtl8139.c
Support is conditional since PCI on old silicon does not work.
ads5121_PCI_config turns on PCI
In this version, condition compilation of PCI code has been moved
from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as
suggested by Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: John Rigby <jrigby@freescale.com>
If any of the steps for generating autoconf.mk fail currently, they go
unnoticed. To fix, we can simply add 'set -e' to the long list of commands.
This is simpler and more robust than placing '|| exit $$?' after every line.
By adding VERSION_FILE to the PHONY targets the script
/tools/setlocalversion is always called and version_autogenerated.h
is replaced only if the script find a modified source file.
If the $(LDSCRIPT) does not exist (normally it's board/$(BOARD)/u-boot.lds),
then change into the board directory and try and create it. This allows you
to generate the linker script on the fly based upon board defines (like the
Blackfin boards do).
There should be no regressions due to this change as the normal case is to
already have a u-boot.lds file. If that's the case, then there's nothing to
generate, and so make will always exit. The fix here is that if the linker
script does not exist, the implicit rules take over and attempt to guess how
to generate the file.
Signed-off-by: James Mahan <kmahan@freescale.com>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Makefile
doc/README.standalone
Constantly rebuilding the version header will force useless relinking, so we
simply need to compare the new header with the existing one before updating
it.
This patch enables the OneNAND boot within U-Boot.
Before this work, we used another OneNAND IPL called X-Loader based
on open source. With this work, we can build the oneboot.bin image
without other program.
The build sequence is simple.
First, it compiles the u-boot.bin
Second, it compiles OneNAND IPL
Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin
The mechanism is similar with NAND boot except it boots from itself.
Another thing is that you can only use the OneNAND IPL only to work
other bootloader such as RedBoot and so on.
We already have a vendor subdir for Atmel, so we should use it.
Signed-off-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
Kimmo Leppala / Sysart and
Timo Tuunainen / Sysart
AT91CAP9 support : move at91cap9adk board files to Atmel vendor directory.
Signed-off-by: Stelian Pop <stelian@popies.net>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Johannes Stezenbach <js@sig21.net>
