path: root/MAKEALL
2009-09-30On-chip ROM boot: MPC8536DS supportMingkai Hu
The MPC8536E is capable of booting from the on-chip ROM - boot from eSDHC and boot from eSPI. When power on, the porcessor excutes the ROM code to initialize the eSPI/eSDHC controller, and loads the mian U-Boot image from the memory device that interfaced to the controller, such as the SDCard or SPI EEPROM, to the target memory, e.g. SDRAM or L2SRAM, then boot from it. The memory device should contain a specific data structure with control word and config word at the fixed address. The config word direct the process how to config the memory device, and the control word direct the processor where to find the image on the memory device, or where copy the main image to. The user can use any method to store the data structure to the memory device, only if store it on the assigned address. The on-chip ROM code will map the whole 4GB address space by setting entry0 in the TLB1, so the main image need to switch to Address space 1 to disable this mapping and map the address space again. This patch implements loading the mian U-Boot image into L2SRAM, so the image can configure the system memory by using SPD EEPROM. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30NAND boot: MPC8536DS supportMingkai Hu
MPC8536E can support booting from NAND flash which uses the image u-boot-nand.bin. This image contains two parts: a 4K NAND loader and a main U-Boot image. The former is appended to the latter to produce u-boot-nand.bin. The 4K NAND loader includes the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. The main U-Boot image just like a general U-Boot image except the parts that included by CONFIG_SYS_RAMBOOT. When power on, eLBC will automatically load from bank 0 the 4K NAND loader into the FCM buffer RAM where CPU can execute the boot code directly. In the first stage, the NAND loader copies itself to RAM or L2SRAM to free up the FCM buffer RAM, then loads the main image from NAND flash to RAM or L2SRAM and boot from it. This patch implements the NAND loader to load the main image into L2SRAM, so the main image can configure the RAM by using SPD EEPROM. In the first stage, the NAND loader copies itself to the second to last 4K address space, and uses the last 4K address space as the initial RAM for stack. Obviously, the size of L2SRAM shouldn't be less than the size of the image used. If so, the workaround is to generate another image that includes the code to configure the RAM by SPD and load it to L2SRAM first, then relocate the main image to RAM to boot up. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-09-24sbc8548: allow enabling PCI via a make config optionPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, and if you had 33MHz PCI, you had to manually change CONFIG_SYS_NS16550_CLK too, which was not real user friendly, This adds the typical PCI and clock speed make targets to the toplevel Makefile in accordance with what is being done with other boards (i.e. using the "-t" to mkconfig). Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24MAKEALL: Use POSIX mathPeter Tyser
2009-09-24MAKEALL: Add summary informationPeter Tyser
This change adds some basic summary information to the MAKEALL script. The summary information includes how many boards were compiled, how many boards had compile warnings or errors, and which specific boards had compile warnings or errors. This information is useful when doing compile testing to quickly determine which boards are broken. As a side benefit, no empty $BOARD.ERR files are generated by MAKEALL. Previously, each board had a corresponding $BOARD.ERR file, even if the board compiled cleanly. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-15Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-09-14microblaze: Remove AtmarkTechno Suzaku boardMichal Simek
Users should use microblaze-generic platform. This platform is longer not supported. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-09-11ppc4xx: Rename compactcenter to intipDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
2009-09-02Blackfin: cm-bf537u: new board portHarald Krapfenbauer
The CM-BF537U is similar to the CM-BF537E module, but enough to need its own board port. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-01Support for the Calao TNY-A9260/TNY-A9G20 boardsAlbin Tonnerre
The Calao TNY-A9260 and TNY-9G20 are boards manufactured and sold by Calao Systems <http://www.calao-systems.com>. Their components are very similar to the AT91SAM9260EK board, so their configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, no ethernet. They also can use SPI EEPROM to store the environment. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-09-01Add support for the Calao SBC35-A9G20 boardAlbin Tonnerre
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems <http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. More informations can be found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-2885xx: Added support for P1011RDB and P2010RDBPoonam Aggrwal
P1011 and P2010 are single core variants of P1010 and P2020 respectively. The board(RDB) will be same. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: P1020RDB Support AddedPoonam Aggrwal
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-25Add support for the galaxy5200Eric Millbrandt
Add support for the DEKA Research and Development galaxy5200 board The galaxy5200 is an Freescale mpc5200 based embedded industrial control board. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-08-04Merge branch 'next' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-07-29Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-07-28ppc4xx: Add GDsys CompactCenter board support.Dirk Eibach
Board support for the Guntermann & Drunck CompactCenter and DevCon-Center. Based on the AMCC Canyonlands board support by Stefan Roese. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-27mpc83xx: Add esd VME8349 board supportReinhard Arlt
This patch adds support for the esd VME8349 board equipped with the MPC8349. It's a VME PMC carrier board equipped with the Tundra TSI148 VME-bridge. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-24ppc4xx: Add 405EP based PMC405DE boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24xpedite1k: Move to X-ES vendor directoryPeter Tyser
The XPedite1000 is an X-ES product thus it can be put in board/xes along with other X-ES boards. Along with the move, the board was renamed to XPedite1000 from XPedite1K to fit X-ES's standard naming convention. Maintainership was also transfered to Peter Tyser. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Add DL-Vision 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck DL-Vision. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-23Marvell RD6281A Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based reference design board This patch is tested for- 1. Boot from DRAM/NAND flash/NFS 2. File transfer using tftp and loadb 3. NAND flash read/write/erase Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-18Marvell MV88F6281GTW_GE Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based custom board developed for wireless access point product This patch is tested for- 1. Boot from DRAM/SPI flash/NFS 2. File transfer using tftp and loadb 3. SPI flash read/write/erase 4. Booting Linux kernel and RFS from SPI flash 5. Boot from USB supported Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-18Marvell Sheevaplug Board supportPrafulla Wadaskar
Reference: http://plugcomputer.org/ http://openplug.org/plugwiki/index.php/Das_U-boot_plug_support This patch is tested for- 1. Boot from DRAM/NAND flash 2. File transfer using tftp 3. NAND flash read/write/erase 4. Linux kernel and RFS Boot from NAND 5. Enabled USB PHY init for kernel need 6. Boot from USB supported Note: to boot Kirkwood kernel with USB support, you should add "usb start" in the boot sequence Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-14ColdFire: Add M5208EVB and MCF520x CPU supportTsiChung Liew
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-11sh: Add support ESPT-GIGA boradNobuhiro Iwamatsu
ESPT-Giga is SH7763-based reference board. Board support is relatively sparse, presently supporting serial, gigabit ethernet, USB host, and MTD. More information (in Japanese) available at: http://www.cente.jp/product/cente_hard/ESPT-Giga.html Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-10board support patch for phyCORE-MPC5200B-tinyJon Smirl
Add support for the Phytec phyCORE-MPC5200B-tiny. Code originally from Pengutronix.de. Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on Timer 0/1 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2009-07-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
Conflicts: drivers/spi/Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-06nhk8815: fix MAKEALLJean-Christophe PLAGNIOL-VILLARD
2009-07-06MX31: Add NAND SPL boot support to i.MX31 PDK board.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-07-06xscale: add support for the polaris boardStefano Babic
The Polaris board is based on the TrizepsIV module of Keith & Koep (http://www.keith-koep.com). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-07-06MX31: Add basic support for Freescale i.MX31 PDK board.Magnus Lilja
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board). This patch assumes that some other program performs the actual NAND boot. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabioestevam@yahoo.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-0186xx: XPedite5170 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5170 - a MPC8640-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-21at91: add support for the PM9261 board of Ronetix GmbHIlko Iliev
The PM9261 board is based on the AT91SAM9261-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9261.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-14Blackfin: ibf-dsp561: new board portHoan Hoang
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: blackstamp: new board portMike Frysinger
2009-06-14Blackfin: bf537-srv1: new board portMike Frysinger
2009-06-14Blackfin: bf537-minotaur: new board portMike Frysinger
2009-06-14Blackfin: bf537-pnav: new board portMike Frysinger
2009-06-14Blackfin: cm-bf527: new board portMike Frysinger
