path: root/MAKEALL
2008-05-05MAKEALL: add inka4x0 boardWolfgang Denk
2008-04-20MAKEALL: sort entries / lists.Wolfgang Denk
2008-04-18Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Support for LinkStation / KuroBox HD and HG PPC modelsGuennadi Liakhovetski
This patch is based on the port by Mihai Georgian (see linkstation.c for Copyright information) and implements support for LinkStation / KuroBox HD and HG PPC models from Buffalo Technology, whereby HD is deactivated at the moment, pending network driver fixing. Notice to users: this is pretty much a barebone port. Support for network on HG models is already in the U-Boot mainline, but you might also want patches to switch fan / phy modes depending on the negotiated ethernet parameters. This patch also doesn't support console switching, booting EM mode, Buffalo specific ext2 magic number. So, if you want to use any of those, you need additional patches. Otherwise this patche provides a fully functional u-boot with a network console on your system. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Phytec Phycore-i.MX31 supportSascha Hauer
This patch adds support for the Phytec Phycore-i.MX31 board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13mx31 litekit supportSascha Hauer
This patch adds support for the mx31 litekit board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-sparcWolfgang Denk
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08microblaze: Sort microblaze boards in MAKEALL scriptMichal Simek
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for GR-CPCI-AX2000 FPGA AX board. The FPGA is ↵Daniel Hellstrom
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Altera NIOS Development kit (STRATIX II ↵Daniel Hellstrom
Edition) with GRLIB template design. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Gaisler GRSIM/TSIM2 SPARC/LEON3 simulatorn. ↵Daniel Hellstrom
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Added M5275EVB support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-30add missing ARM boards to MAKEALLDavid Brownell
Add some missing ARM boards to MAKEALL. These build correctly, unlike several of the boards already listed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
2008-03-30Phytec Phycore-i.MX31 supportSascha Hauer
2008-03-30mx31 litekit supportSascha Hauer
2008-03-30Add pmdra into MAKEALLPeter Pearse
Signed-off-by: Peter Pearse <peter.pearse@arm.com>
2008-03-28sh: Add support Renesas Solutions R2D plus boardNobuhiro Iwamatsu
R2D plus is SH reference board used with SH7751R. This board has 266Mhz CPU, 64MB SDRAM, Cardbus, CF interface, one PCI bus, VGA, and two Ethernet controller. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Added support for SH7720 based board MPR2.Mark Jonas
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions R7780MPYusuke Goda
Renesas Solutions R7780MP is a reference board on SH7780. This board has serial, 10/100 base Ethernet deivice, CF slot and VGA devices. This board can set extension board. Extension board has 10/100/1000 base Ethernet device, PCI slot, S-ATA, iDVR slot. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions Migo-R boardgoda.yusuke
Migo-R is a board based on SH7722 and has may devices. In this patch, supported SCIF, NOR flash and Ethernet. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-27ppc4xx: Add AMCC Glacier 406GT eval board supportStefan Roese
This patch adds support for the AMCC Glacier 460GT eval board. The main difference to the Canyonlands board are listed here: - 4 ethernet ports instead of 2 - no SATA port - no USB port Currently EMAC2+3 are not working. This will be fixed in a later release. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (3/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add 405GPr based MCU25 board. Global filesNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-15Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14Do not specify a CROSS_COMPILE default when executing sizeMike Frysinger
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
2008-02-14AT91CAP9 support : build integrationStelian Pop
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ixpWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-18Merge branch 'master' of git://www.denx.de/git/u-bootShinya Kuribayashi
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-18Add AcTux board supportMichael Schwingen
Hi, The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the files that contain changes for multiple boards, the board-specific files follow as separate patches. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-17ColdFire: MCF547x_8x - Add M5475EVB and M5485EVB supportTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
