path: root/MAKEALL
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
2008-01-17Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-01-17ppc4xx: Complete DU440 board supportMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-01-16Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-01-16Add support for the MPC837xERDBKim Phillips
MPC837xERDB board support includes: * DDR2 330MHz hardcoded (soldered on the board) * Local Bus NOR Flash * I2C, UART and RTC * eTSEC RGMII (TSEC0 - RTL8211B with MII; * TSEC1 - VSC7385 local bus, hardcoded, requires seperate firmware * load) Signed-off-by: Kevin Lam <kevin.lam@freescale.com> Signed-off-by: Joe D'Abbraccio <joe.d'abbraccio@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add the support for MPC8315ERDB boardDave Liu
The features list: - Boot from NOR Flash - DDR2 266MHz hardcoded configuration - Local bus NOR Flash R/W operation - I2C, UART, MII and RTC - eTSEC0/1 support - PCI host Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-15sh: Add MS7720SE to MAKEALLNobuhiro Iwamatsu
2008-01-12added basic support for the MUNICes board.Heiko Schocher
2008-01-12Added support for the mgcoge board from keymile.Heiko Schocher
2008-01-12Added support for the mgsuvd board from keymile.Heiko Schocher
2008-01-12Add support for the TK885D baseboard from TELE-DATAGuennadi Liakhovetski
The TK885D board uses a TQM885D module from TQ, this port adds an own configuration file and adds a last_stage_init() method to configure the two PHYs, depending on the phy_auto_nego environment variable. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-01-10mpc83xx: add support for the MPC8360E-RDKAnton Vorontsov
This is MPC8360E based board with: - 256MB fixed SDRAM; - 8MB Intel Strata NOR flash; - StMICRO 64MiB NAND flash; - two 10/100/1000 ethernet ports connected via Broadcom BCM5481 PHYs; - two 10/100 ethernet ports connected via National DP83848 PHYs; - one PCI and one miniPCI slots; - four serial ports (two NS16550-compatible, two UCCs); - four USB ports working through MPC8360E "FHCI" USB controller; - Fujitsu MB86277 graphics controller; - Analog to Digital Converter/Touchscreen controller, AD7843 connected to SPI. Features not supported in this patch are: - StMICRO 64MiB NAND flash (patch sent); - MINT framebuffer initialization (patch is pending); - Fetching production information from the EEPROM via I2C; - FHCI USB; - Two slow UCCs used as RS-485 UARTs. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-09mpc85xx: Add support for ATUM8548 (updated)robert lazarski
Add support for Instituto Atlantico's ATUM8548 board Signed-off-by: robert lazarski <robertlazarski@gmail.com>
2008-01-09mpc85xx: Add support for SBC8548 (updated)Joe Hamman
Add support for Wind River's SBC8548 reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signed-off by: Andy Fleming <afleming@freescale.com>
2008-01-09Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-01-08mpc83xx: add MAINTAINER and MAKEALL entries for the mpc837xemdsDave Liu
Add the MAINTAINER and MAKEALL entries for mpc837xemds Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-07Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2008-01-03Merge commit 'wd/master'Jon Loeliger
2007-12-28ppc4xx: Complete PMC440 board supportMatthias Fuchs
This patch brings the PMC440 board configuration file. Finally it enables the PMC440 board support. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-12-27Merge branch 'master' of /home/stefan/git/u-boot/u-boot into for-1.3.2-ver2Stefan Roese
2007-12-27Remove CPCI440 boardMatthias Fuchs
This board never left prototyping state and it became a millstone round my neck. So remove it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-12-27Add support for Korat PPC440EPx boardLarry Johnson
These patches add support for the PPC440EPx-based "Korat" board to U-Boot. They are based primarily on support for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-27Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
Conflicts: MAINTAINERS Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-12-17AVR32: Add support for the ATSTK1004 boardHaavard Skinnemoen
ATSTK1004 is a daughterboard for ATSTK1000 with the AT32AP7002 CPU, which is a derivative of AT32AP7000. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-17AVR32: Add support for the ATSTK1003 boardHaavard Skinnemoen
ATSTK1003 is a daughterboard for ATSTK1000 with the AT32AP7001 CPU, which is a derivative of AT32AP7000. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-11Merge commit 'u-boot/master' into for-1.3.1Stefan Roese
Conflicts: drivers/rtc/Makefile
2007-12-06Merge commit 'wd/master'Jon Loeliger
2007-12-07Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: drivers/Makefile
2007-11-29sh: Add ms7750se support in MAKEALLNobuhiro Iwamatsu
2007-11-29sh: Add sh3 and sh4 support in MAKEALLJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-11-26MAKEALL: add missing 512x boards in ppcJean-Christophe PLAGNIOL-VILLARD
2007-11-20Merge commit 'remotes/wd/master'Jon Loeliger
2007-11-17MAKEALL: Added missing pb1000 boardShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-09Add apollon board supportPeter Pearse
2007-11-03ppc4xx: Add AMCC Kilauea/Haleakala NAND booting supportStefan Roese
This patch adds NAND booting support for the AMCC 405EX(r) eval boards. Again, only one image supports both targets. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-02Merge commit 'remotes/wd/master'Jon Loeliger
2007-10-31ppc4xx: Add initial AMCC Haleakala PPC405EXr eval board supportStefan Roese
The Haleakala is nearly identical with the Kilauea eval board. The only difference is that the 405EXr only supports one EMAC and one PCIe interface. This patch adds support for the Haleakala board by using the identical image for Kilauea and Haleakala. The distinction is done by comparing the PVR. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Makalu 405EX supportStefan Roese
2007-10-31ppc4xx: Add initial AMCC Kilauea 405EX supportStefan Roese
2007-10-18mpc83xx: Add configure entry for MPC83xx ATM supportTony Li
Add MPC8360EMDS_ATM_config and MPC832XEMDS_ATM_config into Makfile and MAKEALL Signed-off-by: Tony Li <tony.li@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-10-17Initial mpc8610hpcd Makefile files.Jon Loeliger
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Mahesh Jade <mahesh.jade@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-09-07Fix typo in MAKEALL script.v1.3.0-rc1Wolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-coldfireWolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-16Merge branch 'denx-coldfire' into coldfire-aug2007John Rigby
