The ml300 board has a number of issues, but nobody cares about this
long-orphaned board any more. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu>
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
The patch adds an entry for the DM365 EVM to MAKEALL
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Added support for the following EDB93xx boards:
EDB9301
EDB9302
EDB9302A
EDB9307
EDB9307A
EDB93012
EDB9315
EDB9315A
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
The EXBITGEN board has not been maintained for a long time; it has
build problems, but no hardware is available any more for testing.
Drop support for this board.
This patch add nand boot support for MPC8569mds board.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
SPEAr320 SoC support contains basic spear320 support along with the
usage of following drivers
- serial driver(UART)
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
- emi driver(cfi support)
Signed-off-by: Vipin <vipin.kumar@st.com>
SPEAr310 SoC support contains basic spear310 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr300 SoC support contains basic spear300 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr600 SoC support contains basic spear600 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
The new board revision has a different LCD.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru>
The caddy2 is a variant of the already supported vme8349. So we just
add the differences to this board port. To better support those two
boards we switched from fixed SDRAM configuration to usage of
spd_sdram(). This is done by providing a board specific SPD EEPROM
routine with different values for both boards.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
changed to use mkconfig -t option instead, plus misc codingstyle fixes.
The core support for NAND booting is there already, so this patch
is pretty straightforward.
There is one trick though: top level Makefile expects nand_spl to
be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code
from mpc8313erdb boards, and so to not duplicate the code we just
symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
o silence make during ln echo
o update documentation
o and avoid:
$ ./MAKEALL MPC8315ERDB_NAND
Configuring for MPC8315ERDB board...
sdram.o: In function `fixed_sdram':
/home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay'
by renaming udelay -> __udelay in the spirit of commit
3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog
support".
Previously MAKEALL would always return a value of 0, even if 1 or more
boards did not compile. This change causes MAKEALL to return 0 if all
boards were able to build, otherwise 1.
This change also requires changing the script interpreter from sh to
bash to support bash's PIPESTATUS variable.
This patch adds support for A320 evaluation board from Faraday. This board
uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM.
FA526 is an ARMv4 processor and uses the ARM920T source in this patch.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Integrate DA830 EVM support into U-Boot.
Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum
Digital EVM board. See http://www.spectrumdigital.com/
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
This patch adds support for the board IPEK01 based on the MPC5200.
The Futjitsu Lime graphics controller is configured in 16 bpp mode.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Start of support of
Texas Instruments Software Development Platform(SDP)
for OMAP3430 - SDP3430
Highlights of this platform are:
Flash Memory devices:
Sibley NOR, Micron 8bit NAND and OneNAND
Connectivity:
3 UARTs and expanded 4 UART ports + IrDA
Ethernet, USB
Other peripherals:
TWL5030 PMIC+Audio+Keypad
VGA display
Expansion ports:
Memory devices plugin boards (PISMO)
Connectivity board for GPS,WLAN etc.
Completely configurable boot sequence and device mapping
etc.
Support default jumpering and:
- UART1/ttyS0 console(legacy sdp3430 u-boot)
- UART3/ttyS2 console (matching other boards,
and SDP HW docs)
- Ethernet
- mmc0
- NOR boot
Currently the UART1 is enabled by default. for
compatibility with other OMAP3 u-boot platforms,
enable the #define of CONSOLE_J9.
Makefile
Fixed the conflict with smdkc100_config by moving omap_sdp3430_config
to it is alphabetically sorted location above zoom1.
Signed-off-by: David Brownell <david-b@pacbell.net>
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This patch adds support for the leopard board which is
based on the DM355 SOC.
This patch adds the initial support for DM6467 EVM.
Other features like NET and NAND support will be added as follow up patches.
On Chip BootROM support for P1 and P2 series RDB platforms.
This patch is derived from latest On Chip BootROM support on MPC8536DS
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
NAND Boot support for P1 and P2 series RDB platforms.
This patch is derived from NAND Boot support on MPC8536DS.
Adds new board SMDKC100 that uses s5pc100 SoC
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
The implementation is borrowed from the sheevaplug board and the Marvell
1.1.4 code. Unsupported (or untested) is the SD card, PCIe and SATA.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
these boards are built around Atmel's AT91SAM9260/9G20 and have
up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND
and include a 10/100 Ethernet PHY in RMII mode.
Signed-off-by: Eric Benard <eric@eukrea.com>
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR
flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII
mode.
The MPC8536E is capable of booting from the on-chip ROM - boot from
eSDHC and boot from eSPI. When power on, the porcessor excutes the
ROM code to initialize the eSPI/eSDHC controller, and loads the mian
U-Boot image from the memory device that interfaced to the controller,
such as the SDCard or SPI EEPROM, to the target memory, e.g. SDRAM or
L2SRAM, then boot from it.
The memory device should contain a specific data structure with control
word and config word at the fixed address. The config word direct the
process how to config the memory device, and the control word direct
the processor where to find the image on the memory device, or where
copy the main image to. The user can use any method to store the data
structure to the memory device, only if store it on the assigned address.
The on-chip ROM code will map the whole 4GB address space by setting
entry0 in the TLB1, so the main image need to switch to Address space 1
to disable this mapping and map the address space again.
This patch implements loading the mian U-Boot image into L2SRAM, so
the image can configure the system memory by using SPD EEPROM.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
MPC8536E can support booting from NAND flash which uses the
image u-boot-nand.bin. This image contains two parts: a 4K
NAND loader and a main U-Boot image. The former is appended
to the latter to produce u-boot-nand.bin. The 4K NAND loader
includes the corresponding nand_spl directory, along with the
code twisted by CONFIG_NAND_SPL. The main U-Boot image just
like a general U-Boot image except the parts that included by
CONFIG_SYS_RAMBOOT.
When power on, eLBC will automatically load from bank 0 the
4K NAND loader into the FCM buffer RAM where CPU can execute
the boot code directly. In the first stage, the NAND loader
copies itself to RAM or L2SRAM to free up the FCM buffer RAM,
then loads the main image from NAND flash to RAM or L2SRAM
and boot from it.
This patch implements the NAND loader to load the main image
into L2SRAM, so the main image can configure the RAM by using
SPD EEPROM. In the first stage, the NAND loader copies itself
to the second to last 4K address space, and uses the last 4K
address space as the initial RAM for stack.
Obviously, the size of L2SRAM shouldn't be less than the size
of the image used. If so, the workaround is to generate another
image that includes the code to configure the RAM by SPD and
load it to L2SRAM first, then relocate the main image to RAM
to boot up.
Prior to this commit, to enable PCI, you had to go manually
edit the board config header, and if you had 33MHz PCI, you
had to manually change CONFIG_SYS_NS16550_CLK too, which was
not real user friendly,
This adds the typical PCI and clock speed make targets to the
toplevel Makefile in accordance with what is being done with
other boards (i.e. using the "-t" to mkconfig).
This change adds some basic summary information to the MAKEALL script.
The summary information includes how many boards were compiled, how many
boards had compile warnings or errors, and which specific boards had
compile warnings or errors.
This information is useful when doing compile testing to quickly
determine which boards are broken.
As a side benefit, no empty $BOARD.ERR files are generated by MAKEALL.
Previously, each board had a corresponding $BOARD.ERR file, even if the
board compiled cleanly.
Users should use microblaze-generic platform.
This platform is longer not supported.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
This patch adds support for the DevKit8000 board.
Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
The CM-BF537U is similar to the CM-BF537E module, but enough to need its
own board port.
The Calao TNY-A9260 and TNY-9G20 are boards manufactured and sold by
Calao Systems <http://www.calao-systems.com>. Their components are very
similar to the AT91SAM9260EK board, so their configuration is based on
the configuration of this board. There are however some differences:
different clocks, no LCD, no ethernet. They also can use SPI EEPROM to
store the environment.
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems
<http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC
running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard
battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND
flash, two USB host ports, and an USB device port. More informations can be
found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936>
