path: root/MAKEALL
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-12-07MAKEALL: fix AT91Andreas Bießmann
* add boards_by_soc() * remove boards already in boards.cfg from LIST_AT91 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-11-14MAKEALL: Do a sanity check on user-supplied argumentsPeter Tyser
Add a check to make sure that the user's arguments actually find a board in boards.cfg. Previously, if a user misspelled an argument the argument would be discarded without warning. For example, running 'MAKEALL -c 85xx' with the intention of compiling all Freescale 85xx boards would instead silently discard the '-c 85xx' argument since the proper cpu name is 'mpc85xx' and then proceed to compile all PowerPC boards (MAKEALL's default). Also fix an unrelated typo. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-25Blackfin: bf527-ezkit-v2: move to boards.cfgMike Frysinger
Now that the boards.cfg file supports options to mkconfig, we can move the bf527-ezkit-v2 target out of the Makefile and into boards.cfg. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-23MAKEALL: drop non-existent i386 configMike Frysinger
2010-10-21sh: sh4: Move to boards.cfgNobuhiro Iwamatsu
Move the sh4 target boards out of the Makefile and into boards.cfg. And fix sh4 of MAKEALL. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-10-21sh: sh3: Move to boards.cfgNobuhiro Iwamatsu
Move the sh3 target boards out of the Makefile and into boards.cfg. And fix sh3 of MAKEALL. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-10-21sh: rsk7203: Move to boards.cfgNobuhiro Iwamatsu
Move the rsk7203 target out of the Makefile and into boards.cfg. And fix sh2 of MAKEALL. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-10-19Build: PXA: Fix TrizepsIV build variantsMarek Vasut
2010-10-19Build: PXA: Fix Vpac270 build variantsMarek Vasut
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-18MAKEALL: allow additional board selectionsWolfgang Denk
Add command line handling to select boards to be built by architecture, CPU family, vendor or SoC name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-17OMAP3: Add support for the OMAP3 IGEP module.Enric Balletbo i Serra
The IGEP module is a low-power, high performance production-ready system-on-module (SOM) based on TI's OMAP3 family.The IGEP module solution based upon TI OMAP3 provides a low-power/low-cost platform for a variety of consumer/industrial/medical devices. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: Add support for the IGEP v2 board.Enric Balletbo i Serra
The IGEP v2 board is a low-cost, fan-less and industrial temperature range single board computer that unleashes laptop-like performance and expandability without the bulk, expense, or noise of typical desktop machines. Its architecture shares much in common with other OMAP3 boards. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-13ARMV7: Versatile Express Coretile CortexA9x4 supportMatt Waddel
Adds support for the ARM quad-core Cortex-A9 processor This system includes a motherboard(Versatile Express), daughterboard (Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet, and flash systems work with these additions. The naming convention is: SOC -> CortexA9 quad core = ca9x4 daughterboard -> Coretile = ct motherboard -> Versatile Express = vxp This gives ca9x4_ct_vxp.c as the board support file. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-09-21silence config step commands display during MAKEALL buildsKim Phillips
[u-boot next]$ ./MAKEALL 83xx awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend Configuring for ve8313 board... Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-19MAKEALL: cut down on duplication of targetsMike Frysinger
Merge the other significant source of board name duplication with the new boards.cfg file. I cleaned up most targets, but the ARM and MIPS trees are such a mess than I didn't bother. If those maintainers care, they can take are of it. While we're at it, we can be a bit more clever in the LIST_xxx handling and avoid duplicating the list names too. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-09-13x86: Remove Unmaintained BoardsGraeme Russ
The SC520 CDP boards originally implemented by Daniel Engström are now very broken. Attempts to contact Daniel via the email address on the copyright notice have failed. Remove these boards from mainline
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-01powerpc/p4080: Add support for the P4080DS boardKumar Gala
Add support for the P4080DS board, with the following features: * 36-bit only * Boots from NOR flash * FMAN drivers NOT supported * SPD DDR initialization Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Ashish Kalra <Ashish.Kalra@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-17Drop support for GTH boardWolfgang Denk
The board maintainer states: The GTH board is obsolete and has not been manufactured for several years. To my knowledge, no recent U-Boot build has been tested on that card. So drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Acked-by: Thomas Lange<thomas@corelatus.se>
2010-07-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-07-16powerpc: add support for the Freescale P1022DS reference boardTimur Tabi
Specifics: 1) 36-bit only 2) Booting from NOR flash only 3) Environment stored in NOR flash only 4) No SPI support 5) No DIU support Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-15Merge branch 'master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-14PXA: ZipitZ2 supportMarek Vasut
This patch adds support for Aeronix Zipit Z2 handheld. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-07-14PXA: Toradex Colibri PXA270 supportMarek Vasut
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
2010-07-14Merge branch 'next' of git://git.denx.de/u-boot-niosWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2010-07-13Blackfin: bf527-ad7160-eval: new board supportMichael Hennerich
Support the new AD7160 eval board. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-0983xx: add support for ve8313 boardHeiko Schocher
This patch add support for the ve8313 board based on Freescale MPC8313 CPU. - serial console on UART 1 - 128 MB DDR RAM - 32 MB NOR Flash - 16 MB NAND Flash - Ethernet MII Mode over on TSEC0 - micrel ksz804 phy - Hardware WDT MAX824 changes since v1 - Environment size = sector size - use red. environment - add comments from Kim Phillips - add MAKEALL, MAINTAINERS entry - Codingstyle issues fixed - inserted original Copyrights - PCI subsys vendor ID changed from 0x1057 (Motorola) to 0x1957 (Freescale) changes since v2 - add comments from Wolfgang Denk - fix Codingstyle and some comments - reworked WDT reset (just toggling the WD_TRIG pin) - Environment size now 16KiB - fixed RAMBOOT version - fixed CONFIG_SYS_LOAD_ADDR - renamed CONFIG_TSEC1_NAME to TSEC1 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-09MPC8308RDB: minimal support for devboard from FreescaleIlya Yanok
This patch provides support for MPC8308RDB development board from Freescale with a minimal set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported The following features are enabled in configuration but not fully tested: I2C (used to get the board revision) I2C-connected RTC VSC7385 switch There is one (hopefully) minor issue: on soft reset the board sometimes resets twice. I've not managed to find the fix for this problem yet. As a workaround instruction cache can be disabled. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-05ARMV7: Add support for TI OMAP4 PandaSteve Sakoman
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4430 SDPSteve Sakoman
OMAP4430 SDP is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-01ppc4xx: Add T3COPR board support (PPC460GT based)Stefan Roese
This patch adds support for the T3CORP board, based on the AppliedMicro (APM) PPC460GT. Signed-off-by: Stefan Roese <sr@denx.de>
2010-06-29MAKEALL: Add missing powerpc 36-bit targetsBecky Bruce
We were missing 8641HPCN_36BIT and MPC8536DS_36BIT. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
Conflicts: CONFLICT (rename/add): Rename board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b. board/ti/tnetv107xevm/Makefile added in HEAD But files were identical, so no problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-06-14s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
This patch adds support for the Samsung Goni board (S5PC110 SoC) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-06-10TI: DaVinci: Add board specific code for da850 EVMSudhakar Rajashekhara
Provides initial support for TI OMAP-L138/DA850 SoC devices on a Logic PD EVM board. Provides: Initial boot and configuration. Support for i2c. UART support (console). Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for AM3517EVMVaibhav Hiremath
This patch adds basic support for the AM3517EVM. It includes: - Board files (.c and .h) - Default configuration file - Updates for Makefile Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08TI: TNETV107X EVM initial supportCyril Chemparathy
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch adds support for the TNETV107X EVM board. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-07AM35x: Add support for AM3517EVMVaibhav Hiremath
