Add support for the PXA250 based Intrinsyc Cerf board.
* Patch by Yasushi Shoji, 27 Jun 2004:
fix comment in include/common.h
* Patch by Daniel Poirot, 24 Jun 2004:
Add support for Wind River's sbc8240 board
* Patches by Yasushi Shoji, 26 Jun 2004:
- drivers/serial_xuartlite.c: fix "return 0" in void function
- add microblaze support to mkimage tool
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Remove obsolete AdderII port which was superseded by unified
AdderII/Adder87x port
* Patch by Ladislav Michl, 16 Jun 2004:
Fix gcc-3.3.3 warnings for smc91111.c
* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- Add support for RPXlite_DW board
- Update FLASH driver for 4*AM29DL323DB90VI
- Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
Add support for Exys XSEngine board
Some code cleanup.
Add support for Interphase iSPAN boards.
- Add support for the Logic Zoom LH7A40x based SDK board(s),
specifically the LPD7A400.
* Patches by Robert Schwebel, 15 May 2004:
- call MAC address reading code also for SMSC91C111;
- make SMSC91C111 timeout configurable, remove duplicate code
- fix get_timer() for PXA
- update doc/README.JFFS2
- use "bootfile" env variable also for jffs2
Add support for Cogent CSB472 board (8MB Flash Rev)
- Intracom board update.
- Add Codec POST.
Add support for OMAP730 Perseus2 Development board
* Patch by Alan J. Luse, 29 Apr 2004:
Fix flash chip-select (OR0) option register setting on FADS boards.
Report MII network speed and duplex setting properly when
auto-negotiate is not enabled.
* Patch by Jarrett Redd, 29 Apr 2004:
Fix hang on reset on Ocotea board due to flash in wrong mode.
- Rename DUET_ADS to MPC885ADS
- Rename CONFIG_DUET to CONFIG_MPC885_FAMILY
- Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY
- Clean up FADS family port to use the new defines
"miivals.h" is missing
* Patches by Mark Jonas, 13 Apr 2004:
- Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S
- Add sync instructions to IceCube SDRAM init code
- Move SDRAM chip constants into seperate include files
- Unify DDR and SDR initialization code
- Unify all IceCube (Lite5xxx) target names
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
add support for Intel Assabet board
Add support for Picture Elements JSE board
* Patch by Christian Pell, 01 Apr 2004:
Add CompactFlash support for PXA systems.
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
Add support for KUP4X Board
attempting to switch on USB on SX1 board.
* Patch by Josef Wagner, 18 Mar 2004:
- Add support for MicroSys XM250 board (PXA255)
- Add support for MicroSys PM828 board (MPC8280)
- Add support for 32 MB Flash on PM825/826
- new SDRAM refresh rate for PM825/PM826
- added support for MicroSys PM520 (MPC5200)
- replaced Query by Identify command in CPU86/flash.c
to support 28F160F3B
* Fix wrap around problem with udelay() on ARM920T
* Add support for Macronix flash on TRAB board
- Fix Gigabit Ethernet support for 440GX
- Add Gigabit Ethernet Support to MII PHY utilities
* Patch by Brad Kemp, 12 Mar 2004:
Fixes for drivers/cfi_flash.c:
- Better support for x8/x16 implementations
- Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE
- Added defines for AMD command and address constants
* Patch by Leon Kukovec, 12 Mar 2004:
Fix get_dentfromdir() to correctly handle deleted dentries
* Patch by George G. Davis, 11 Mar 2004:
Remove hard coded network settings in TI OMAP1610 H2
default board config
add support for ADS GraphicsClient+ board.
- Add support for the SSV ADNP/ESC1 (Nios Softcore)
* Patch by George G. Davis, 9 Mar 2004:
fix recent build failure for SA1100 target
* Patch by Travis Sawyer, 09 Mar 2004:
Support native interrupt mode for the IBM440GX.
Previously it was running in 440GP compatibility mode.
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference
Platform support.
* Patch by Masami Komiya, 08 Mar 2004:
Don't overwrite server IP address or boot file name
when the boot server does not return values
* Patch by listmember@orkun.us, 5 Mar 2004:
Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
Ocotea:
- Add IBM PPC440GX Ref Platform support (Ocotea)
Original code by Paul Reynolds <PaulReynolds@lhsolutions.com>
Adapted to U-Boot and 440GX port
440gx_enet.c:
- Add gracious handling of all Ethernet Pin Selections for 440GX
- Add RGMII selection for Cicada CIS8201 Gigabit PHY
ppc440.h:
- Add needed bit definitions
- Fix formatting
* Patch by Carl Riechers, 1 Mar 2004:
Add PPC440GX prbdv0 divider to fix memory clock calculation.
* Patch by Stephan Linz, 27 Feb 2004
- avoid problems for targets without NFS download support
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
Add support for S3C44B0 processor and DAVE B2 board
* Patch by Steven Scholz, 20 Feb 2004:
- Add support for MII commands on AT91RM9200 boards
- some cleanup in AT91RM9200 ethernet code
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Fix buffer overflow in common/usb.c
* Patch by Tolunay Orkun, 10 Feb 2004:
Add support for Cogent CSB272 board
* Code cleanup
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
Add support for SNMC's QS850/QS823/QS860T boards
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards
* Patch by Pavel Bartusek, 21 Nov 2003:
set ZMII bridge speed on 440
* Patch by Anders Larsen, 17 Nov 2003:
Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
- board/mpl/common/common_util.c
* implement support for BZIP2 compressed images
* various cleanups (printf -> puts, ...)
- board/mpl/common/flash.c
* report correct errors to upper layers
* check the erase fail and VPP low bits in status reg
- board/mpl/vcma9/cmd_vcma9.c
- board/mpl/vcma9/flash.c
- common/cmd_usb.c
* fix typo in comment
- cpu/arm920t/usb_ohci.c
* support for S3C2410 is missing in #if line
- drivers/cs8900.c
* reinit some registers in case of error (cable missing, ...)
- fs/fat/fat.c
* support for USB/MMC devices is missing in #if line
- include/configs/MIP405.h
- include/configs/PIP405.h
* enable BZIP2 support
* enlarge malloc space to 1MiB because of BZIP2 support
- include/configs/VCMA9.h
* enable USB support
- lib_arm/armlinux.c
* change calling convention of ARM Linux kernel as
described on http://www.arm.linux.org.uk/developer/booting.php
* Patch by Thomas Lange, 14 Nov 2003:
Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to
support all these AMD boards.
Workaround for mips au1x00 physical memory accesses (the au1x00
uses a 36 bit bus internally and cannot access physical memory
directly. Use the uncached SDRAM address instead of the physical
one.)
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
- fix cmd_ide.c for non ppc boards (read/write functions did not
add ATA base address)
- fix for shannon board
- #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code
* Patch by Sangmoon Kim, 07 Oct 2003:
add support for debris board
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
add support for Adder II MPC852T module
fix TI Innovator/OMAP1510 pin configs
* Patches by Kshitij, 18 Aug 2003
- add support for arm926ejs cpu core
- add support for TI OMAP 1610 Innovator Board
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
