path: root/MAKEALL
2010-09-19MAKEALL: cut down on duplication of targetsMike Frysinger
Merge the other significant source of board name duplication with the new boards.cfg file. I cleaned up most targets, but the ARM and MIPS trees are such a mess than I didn't bother. If those maintainers care, they can take are of it. While we're at it, we can be a bit more clever in the LIST_xxx handling and avoid duplicating the list names too. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-09-13x86: Remove Unmaintained BoardsGraeme Russ
The SC520 CDP boards originally implemented by Daniel Engström are now very broken. Attempts to contact Daniel via the email address on the copyright notice have failed. Remove these boards from mainline
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-01powerpc/p4080: Add support for the P4080DS boardKumar Gala
Add support for the P4080DS board, with the following features: * 36-bit only * Boots from NOR flash * FMAN drivers NOT supported * SPD DDR initialization Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Ashish Kalra <Ashish.Kalra@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-17Drop support for GTH boardWolfgang Denk
The board maintainer states: The GTH board is obsolete and has not been manufactured for several years. To my knowledge, no recent U-Boot build has been tested on that card. So drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Acked-by: Thomas Lange<thomas@corelatus.se>
2010-07-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-07-16powerpc: add support for the Freescale P1022DS reference boardTimur Tabi
Specifics: 1) 36-bit only 2) Booting from NOR flash only 3) Environment stored in NOR flash only 4) No SPI support 5) No DIU support Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-15Merge branch 'master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-14PXA: ZipitZ2 supportMarek Vasut
This patch adds support for Aeronix Zipit Z2 handheld. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-07-14PXA: Toradex Colibri PXA270 supportMarek Vasut
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
2010-07-14Merge branch 'next' of git://git.denx.de/u-boot-niosWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2010-07-13Blackfin: bf527-ad7160-eval: new board supportMichael Hennerich
Support the new AD7160 eval board. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-0983xx: add support for ve8313 boardHeiko Schocher
This patch add support for the ve8313 board based on Freescale MPC8313 CPU. - serial console on UART 1 - 128 MB DDR RAM - 32 MB NOR Flash - 16 MB NAND Flash - Ethernet MII Mode over on TSEC0 - micrel ksz804 phy - Hardware WDT MAX824 changes since v1 - Environment size = sector size - use red. environment - add comments from Kim Phillips - add MAKEALL, MAINTAINERS entry - Codingstyle issues fixed - inserted original Copyrights - PCI subsys vendor ID changed from 0x1057 (Motorola) to 0x1957 (Freescale) changes since v2 - add comments from Wolfgang Denk - fix Codingstyle and some comments - reworked WDT reset (just toggling the WD_TRIG pin) - Environment size now 16KiB - fixed RAMBOOT version - fixed CONFIG_SYS_LOAD_ADDR - renamed CONFIG_TSEC1_NAME to TSEC1 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-09MPC8308RDB: minimal support for devboard from FreescaleIlya Yanok
This patch provides support for MPC8308RDB development board from Freescale with a minimal set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported The following features are enabled in configuration but not fully tested: I2C (used to get the board revision) I2C-connected RTC VSC7385 switch There is one (hopefully) minor issue: on soft reset the board sometimes resets twice. I've not managed to find the fix for this problem yet. As a workaround instruction cache can be disabled. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-05ARMV7: Add support for TI OMAP4 PandaSteve Sakoman
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4430 SDPSteve Sakoman
OMAP4430 SDP is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-01ppc4xx: Add T3COPR board support (PPC460GT based)Stefan Roese
This patch adds support for the T3CORP board, based on the AppliedMicro (APM) PPC460GT. Signed-off-by: Stefan Roese <sr@denx.de>
2010-06-29MAKEALL: Add missing powerpc 36-bit targetsBecky Bruce
We were missing 8641HPCN_36BIT and MPC8536DS_36BIT. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
Conflicts: CONFLICT (rename/add): Rename board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b. board/ti/tnetv107xevm/Makefile added in HEAD But files were identical, so no problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-06-14s5pc1xx: Add support for Samsung Goni boardMinkyu Kang
This patch adds support for the Samsung Goni board (S5PC110 SoC) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-06-10TI: DaVinci: Add board specific code for da850 EVMSudhakar Rajashekhara
Provides initial support for TI OMAP-L138/DA850 SoC devices on a Logic PD EVM board. Provides: Initial boot and configuration. Support for i2c. UART support (console). Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for AM3517EVMVaibhav Hiremath
This patch adds basic support for the AM3517EVM. It includes: - Board files (.c and .h) - Default configuration file - Updates for Makefile Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08TI: TNETV107X EVM initial supportCyril Chemparathy
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch adds support for the TNETV107X EVM board. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-07AM35x: Add support for AM3517EVMVaibhav Hiremath
2010-06-07TI: TNETV107X EVM initial supportCyril Chemparathy
2010-06-06add new board pm9g45Asen Dimov
Add the new board PM9G45 from Ronetix GmbH. * AT91SAM9G45 MCU at 400Mhz. * 128MB DDR2 SDRAM * 256MB NAND * 10/100 MBits Ethernet DP83848 * Serial number chip DS2401 The board is made as SODIMM200 module. For more info www.ronatix.at or info@ronetix.at. Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-04-30Marvell GuruPlug Board SupportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com>
2010-04-30arm, i.mx27: add support for magnesium board from projectiondesignHeiko Schocher
This patch adds support for the magnesium board from projectiondesign. This board uses i.MX27 SoC and has 8MB NOR flash, 128MB NAND flash, FEC ethernet controller integrated into i.MX27. As this port is based on the imx27lite port, common config options are collected in include/configs/imx27lite-common.h Signed-off-by: Heiko Schocher <hs@denx.de>
2010-04-29ppc4xx: Add support for ICON board (PPC440SPe)Stefan Roese
This patch adds support for the Mosaix Technologies, Inc. ICON board, based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM (512MB standard) and 64MByte of NOR FLASH. Support for the onboard SM502 will be added later. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-29ppc4xx: Add missing APC405 to MAKEALLStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-04-27Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2010-04-24nios2: add nios2-generic boardThomas Chou
This is a generic approach to port u-boot for nios2 boards. You may find the usage of this approach on the nioswiki, http://nioswiki.com/DasUBoot A fpga parameter file, which contains base address information and drivers declaration, is generated from Altera's hardware system description sopc file using tools. The example fpga parameter file is compatible with EP1C20, EP1S10 and EP1S40 boards. So these boards can be removed after this commit. Though epcs controller is removed to cut the dependency of altera_spi driver. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24mpc5121: add support for PDM360NG boardAnatolij Gustschin
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh. Signed-off-by: Michael Weiss <michael.weiss@ifm.com> Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-10Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-04-10Add initial support for Matrix Vision mvSMR board based on MPC5200B.Andre Schwarz
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-04-07Blackfin: IP04: new board portBrent Kandetzki
A low cost 4 port IP-PBX board. Signed-off-by: Brent Kandetzki <BrentK@teleco.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-29Merge remote branch 'origin/master' into nextWolfgang Denk
2010-03-28ml300: remove support for broken, orphaned boardWolfgang Denk
The ml300 board has a number of issues, but nobody cares about this long-orphaned board any more. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Michal Simek <monstr@monstr.eu>
2010-03-24add ASTRO MCF5373L boardWolfgang Wegner
This patch adds support for ASTRO board(s) based on MCF5373L. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
