* Add support to the Makefile
* Add 8544 configuration support to the tsec driver
* Add 8544 SVR numbers to processor.h
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Reset support
BSP autoconfig support
This patch adds support for the new AMCC Acadia eval board.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
timer support
interrupt controller support
flash support
ethernet support
cache support
board information support
env support
booting image support
adding support for Xilinx ML401
Add support for the MPC8349E-mITX-GP, a stripped-down version of the
MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in
HRCW is 0) for the ITX and a README for the ITX and the ITX-GP.
drivers/Makefile
Fix the merge conflict in file drivers/Makefile
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
drivers/cfi_flash.c
The patch by Heiko Schocher <hs@pollux.denx.de> on Jan, 19, 2007
fixes cfi_driver bug for mpc7448hpc2 board. The default cfi_driver can support
mpc7448hpc2 board.
The conflicts due to a new mpc7448 p3m7448 board is in the main tree.
Merge branch 'master' into hpc2
MAKEALL
cpu/74xx_7xx/cpu.c
cpu/74xx_7xx/cpu_init.c
cpu/74xx_7xx/speed.c
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460)
and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are
quite similar and share the same board directory "prodrive/p3mx"
and the same config file "p3mx.h".
drivers/cfi_flash.c
Add support for the Freescale MPC8360EMDS board.
Includes DDR, DUART, Local Bus, PCI.
PREREQUISITE PATCHES:
* This patch can only be applied after the following patches have been applied:
1) DNX#2006090742000024 "Add support for multiple I2C buses"
2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x"
3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c"
4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems"
5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems"
CHANGELOG:
* Add support for the Freescale MPC8349E-mITX reference design platform.
The second TSEC (Vitesse 7385 switch) is not supported at this time.
1. Add 7447A and 7448 processor support.
2. Add the following flags.
CFG_CONFIG_BUS_CLK : If the 74xx bus frequency can be configured dynamically
(such as by switch on board), this flag should be set.
CFG_EXCEPTION_AFTER_RELOCATE: If an exception occurs after the u-boot
relocates to RAM, this flag should be set.
CFG_SERIAL_HANG_IN_EXCEPTION: If the print out function will cause the
system hang in exception, this flag should be set.
There is a design issue for tsi108/109 pci configure read. When pci scan
the slots, if there is no pci card, the tsi108/9 will cause a machine
check exception for mpc7448 processor.
Signed-off-by: Alexandre Bounine <alexandreb@tundra.com>
Patch by Haavard Skinnemoen, 06 Sep 2006
This patch adds support for the ATSTK1000 with the ATSTK1002 CPU
daughterboard.
ATSTK1000 is a full-featured development board for AT32AP CPUs. It
has two ethernet ports, a high quality QVGA LCD panel, a loudspeaker,
and connectors for USART, PS/2, VGA, USB, MMC/SD cards and
CompactFlash cards. For more information, please see this page:
http://www.atmel.com/dyn/products/tools.asp?family_id=682
The ATSTK1002 is a daughterboard for the ATSTK1000 supporting the
AT32AP7000 chip.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Patch by Aaron Sells, 20 Jun 2006
Patch by Stefan Roese, 07 Sep 2006
