path: root/MAKEALL
2010-06-07TI: TNETV107X EVM initial supportCyril Chemparathy
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch adds support for the TNETV107X EVM board. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-06add new board pm9g45Asen Dimov
Add the new board PM9G45 from Ronetix GmbH. * AT91SAM9G45 MCU at 400Mhz. * 128MB DDR2 SDRAM * 256MB NAND * 10/100 MBits Ethernet DP83848 * Serial number chip DS2401 The board is made as SODIMM200 module. For more info www.ronatix.at or info@ronetix.at. Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-04-30Marvell GuruPlug Board SupportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com>
2010-04-30arm, i.mx27: add support for magnesium board from projectiondesignHeiko Schocher
This patch adds support for the magnesium board from projectiondesign. This board uses i.MX27 SoC and has 8MB NOR flash, 128MB NAND flash, FEC ethernet controller integrated into i.MX27. As this port is based on the imx27lite port, common config options are collected in include/configs/imx27lite-common.h Signed-off-by: Heiko Schocher <hs@denx.de>
2010-04-29ppc4xx: Add support for ICON board (PPC440SPe)Stefan Roese
This patch adds support for the Mosaix Technologies, Inc. ICON board, based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM (512MB standard) and 64MByte of NOR FLASH. Support for the onboard SM502 will be added later. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-29ppc4xx: Add missing APC405 to MAKEALLStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-04-27Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2010-04-24nios2: add nios2-generic boardThomas Chou
This is a generic approach to port u-boot for nios2 boards. You may find the usage of this approach on the nioswiki, http://nioswiki.com/DasUBoot A fpga parameter file, which contains base address information and drivers declaration, is generated from Altera's hardware system description sopc file using tools. The example fpga parameter file is compatible with EP1C20, EP1S10 and EP1S40 boards. So these boards can be removed after this commit. Though epcs controller is removed to cut the dependency of altera_spi driver. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24mpc5121: add support for PDM360NG boardAnatolij Gustschin
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh. Signed-off-by: Michael Weiss <michael.weiss@ifm.com> Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-10Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-04-10Add initial support for Matrix Vision mvSMR board based on MPC5200B.Andre Schwarz
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-04-07Blackfin: IP04: new board portBrent Kandetzki
A low cost 4 port IP-PBX board. Signed-off-by: Brent Kandetzki <BrentK@teleco.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-29Merge remote branch 'origin/master' into nextWolfgang Denk
2010-03-28ml300: remove support for broken, orphaned boardWolfgang Denk
The ml300 board has a number of issues, but nobody cares about this long-orphaned board any more. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Michal Simek <monstr@monstr.eu>
2010-03-24add ASTRO MCF5373L boardWolfgang Wegner
This patch adds support for ASTRO board(s) based on MCF5373L. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2010-03-12mpc82xx: Remove SL8245 board and the now orpahned sk98lin network driver.Detlev Zundel
This code has compile problems and the company does not even exist any more. So we take the liberty to drop support for it. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Wolfgang Denk <wd@denx.de> CC: Ben Warren <biggerbadderben@gmail.com>
2010-03-07arm: add support for the suen3 board from keymileHeiko Schocher
Add support for the ARM part of the mgcoge2, named suen3. This board is based on the Marvell Kirkwood (88F6281) SoC. As there come more board variants, common config options are collected in include/configs/km_arm.h. Also, this board use common code for all keymile boards, which is stored in board/keymile/common/common.c Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Heiko Schocher <hs@denx.de>
2010-03-07Add initial support for Freescale mx51evk boardStefano Babic
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fred Fan <fanyefeng@gmail.com>
2010-03-07DaVinci: Adding entry to MAKEALL for DM365 EVMSandeep Paulraj
The patch adds an entry for the DM365 EVM to MAKEALL Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12new board (eb_cpux9k2)Jens Scharsig
* new board (eb_cpux9k2) * support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG * select via make eb_cpux9k2_config * this also demonstrates, how to use boards with AT91RM9200 cpu in at91 arch tree Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12Add support for EDB93xx boardsMatthias Kaehlcke
Added support for the following EDB93xx boards: EDB9301 EDB9302 EDB9302A EDB9307 EDB9307A EDB93012 EDB9315 EDB9315A Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2010-02-12at91: Add esd gmbh OTC570 board supportDaniel Gorsulowski
This patch adds support for esd gmbh OTC570 board. The OTC570 is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2010-02-03EXBITGEN: drop support for unmaintained boardWolfgang Denk
The EXBITGEN board has not been maintained for a long time; it has build problems, but no hardware is available any more for testing. Drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-01-27Nand boot: Add nand boot support for MPC8569mds boardLiu Yu
This patch add nand boot support for MPC8569mds board. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2010-01-25ppc/85xx: Add ATM config for MPC8569MDSLiu Yu
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-23SPEAr : Support added for SPEAr320 boardVipin KUMAR
SPEAr320 SoC support contains basic spear320 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr310 boardVipin KUMAR
SPEAr310 SoC support contains basic spear310 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr300 boardVipin KUMAR
SPEAr300 SoC support contains basic spear300 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr600 boardVipin KUMAR
SPEAr600 SoC support contains basic spear600 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-17Blackfin: tcm-bf518: new board portHarald Krapfenbauer
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: add support for BF527-EZKIT v2.1Michael Hennerich
The new board revision has a different LCD. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf561-acvilon: new board portValentin Yakovenkov
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-07mpc83xx: Add support for MPC8349 esd caddy2Reinhard Arlt
The caddy2 is a variant of the already supported vme8349. So we just add the differences to this board port. To better support those two boards we switched from fixed SDRAM configuration to usage of spd_sdram(). This is done by providing a board specific SPD EEPROM routine with different values for both boards. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de> changed to use mkconfig -t option instead, plus misc codingstyle fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-07mpc83xx: Add NAND boot support for MPC8315E-RDB boardsAnton Vorontsov
The core support for NAND booting is there already, so this patch is pretty straightforward. There is one trick though: top level Makefile expects nand_spl to be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code from mpc8313erdb boards, and so to not duplicate the code we just symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> o silence make during ln echo o update documentation o and avoid: $ ./MAKEALL MPC8315ERDB_NAND Configuring for MPC8315ERDB board... sdram.o: In function `fixed_sdram': /home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay' by renaming udelay -> __udelay in the spirit of commit 3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog support". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-12-07Merge branch 'master' of ../work into nextWolfgang Denk
2009-12-07MAKEALL: Fix return valuePeter Tyser
Previously MAKEALL would always return a value of 0, even if 1 or more boards did not compile. This change causes MAKEALL to return 0 if all boards were able to build, otherwise 1. This change also requires changing the script interpreter from sh to bash to support bash's PIPESTATUS variable. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-27arm: A320: Add support for Faraday A320 evaluation boardPo-Yu Chuang
This patch adds support for A320 evaluation board from Faraday. This board uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM. FA526 is an ARMv4 processor and uses the ARM920T source in this patch. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2009-11-27TI DA8xx: Integrate DA830 EVM support into U-BootSekhar Nori
Integrate DA830 EVM support into U-Boot. Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum Digital EVM board. See http://www.spectrumdigital.com/ Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2009-10-31mpc52xx: add support for the IPEK01 boardWolfgang Grandegger
This patch adds support for the board IPEK01 based on the MPC5200. The Futjitsu Lime graphics controller is configured in 16 bpp mode. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-10-24Merge branch 'master-sync' of git://git.denx.de/u-boot-armWolfgang Denk
2009-10-24TI OMAP3 SDP3430: Initial SupportTom Rix
Start of support of Texas Instruments Software Development Platform(SDP) for OMAP3430 - SDP3430 Highlights of this platform are: Flash Memory devices: Sibley NOR, Micron 8bit NAND and OneNAND Connectivity: 3 UARTs and expanded 4 UART ports + IrDA Ethernet, USB Other peripherals: TWL5030 PMIC+Audio+Keypad VGA display Expansion ports: Memory devices plugin boards (PISMO) Connectivity board for GPS,WLAN etc. Completely configurable boot sequence and device mapping etc. Support default jumpering and: - UART1/ttyS0 console(legacy sdp3430 u-boot) - UART3/ttyS2 console (matching other boards, and SDP HW docs) - Ethernet - mmc0 - NOR boot Currently the UART1 is enabled by default. for compatibility with other OMAP3 u-boot platforms, enable the #define of CONSOLE_J9. Conflicts: Makefile Fixed the conflict with smdkc100_config by moving omap_sdp3430_config to it is alphabetically sorted location above zoom1. Signed-off-by: David Brownell <david-b@pacbell.net> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-18TI: DaVinci: DM355 Leopard board supportSandeep Paulraj
This patch adds support for the leopard board which is based on the DM355 SOC. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI DaVinci DM646x: Adding initial support for DM6467 EVMSandeep Paulraj
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-16ppc/P1_P2_RDB: On-chip BootROM supportDipen Dudhat
On Chip BootROM support for P1 and P2 series RDB platforms. This patch is derived from latest On Chip BootROM support on MPC8536DS Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16ppc/P1_P2_RDB: NAND Boot SupportDipen Dudhat
NAND Boot support for P1 and P2 series RDB platforms. This patch is derived from NAND Boot support on MPC8536DS. Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
