Patch by Reinhard Arlt, 22 Aug 2005
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
Second serial port on 440GX now defined as a system device.
Add 'Short Etch' code for Cicada PHY within 440gx_enet.c
Patch by Travis B. Sawyer, 12 Jul 2005
Check return value of malloc in 440gx_enet.c
Patch by Travis B. Sawyer, 18 Jul 2005
Patch by Yuli Barcohen, 12 Dec 2004
Minor code cleanup.
Patch by Josef Wagner, 03 Aug 2005
Patch by Stefan Roese, 01 Aug 2005
Add Xianghua Xiao and Lunsheng Wang's support for the
GDA MPC8540 EVAL board.
Add support for the Freescale MPC8349ADS board.
Implemented support for MPC8548CDS board.
Added DDR II support based on SPD values for MPC85xx boards.
This roll-up patch also includes bugfies for the previously
published patches:
DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
* Add MPC8220 boards to MAKEALL script
* Add EEPROM and RTC support for HMI1001 board
* Patch by Detlev Zundel, 20 Jun 2005:
Fix initialization of low active GPIO pins on inka4x0 board
- update the pxa-regs.h file for PXA27x chips
- add PXA27x based ADSVIX board
- add support for MMC on PXA27x processors
* Patch by Andrew E. Mileski, 28 Nov 2004:
Fix PPC4xx SPD SDRAM detection bug
* Patch by Hiroshi Ito, 26 Nov 2004:
Fix logic of "test -z" and "test -n" commands
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
add support for the AMD db1550 board
* Patch by Travis Sawyer, 15 Sep 2004:
Add CONFIG_SERIAL_MULTI support for ppc4xx,
update README.serial_multi
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
- Improve platform.S code for omap1510inn that detects whether code
is running from SDRAM or not. Patch allows SDRAM to be configured
if code is running out of SRAM at 0x20000000.
* Patch by Frederick Klatt, 30 Aug 2004:
Add support for the Wind River SBC8540/SBC8560 boards
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
Add support for MKS Instruments "Quantum" board
* Fix build problem with Cogent boards;
avoid using <asm/byteorder.h> when using the host compiler
Add support for xaeniax board
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
Added support for Total5100 and Total5200 (Rev.1 and Rev.2)
MGT5100 and MPC5200 based Freescale platforms.
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
- add empty include/asm-microblaze/processor.h
- add to CREDITS and MAINTAINERS
- add gd initialization
- add MicroBlaze and SUZAKU board to MAKEALL script
- add reset support for SUZAKU
- add flush_cache() for MicroBlaze
- add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed
size flash memory on SUZAKU
Add support for the PXA250 based Intrinsyc Cerf board.
* Patch by Yasushi Shoji, 27 Jun 2004:
fix comment in include/common.h
* Patch by Daniel Poirot, 24 Jun 2004:
Add support for Wind River's sbc8240 board
* Patches by Yasushi Shoji, 26 Jun 2004:
- drivers/serial_xuartlite.c: fix "return 0" in void function
- add microblaze support to mkimage tool
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Remove obsolete AdderII port which was superseded by unified
AdderII/Adder87x port
* Patch by Ladislav Michl, 16 Jun 2004:
Fix gcc-3.3.3 warnings for smc91111.c
* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- Add support for RPXlite_DW board
- Update FLASH driver for 4*AM29DL323DB90VI
- Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
Add support for Exys XSEngine board
Some code cleanup.
