path: root/MAKEALL
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-12-16some new esd boards addedstroese
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-10-10* Patch by Jon Loeliger, 24 Aug 2004:wdenk
- Fix PCI window on MPC85xx; remove unneeded PCI initialization from board_early_init_f() - Provide SW workaround for PCI initialization on 85xx CDS - Convert MPC85xxADS to use common CFI flash driver * Cleanup: avoid compiler warnings * Add CMC PU2 board to MAKEALL script
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11Patch by Mark Jonas, 01 Jul 2004:wdenk
Added support for Total5100 and Total5200 (Rev.1 and Rev.2) MGT5100 and MPC5200 based Freescale platforms.
2004-07-11* Patch by Martin Krause, 30 Jun 2004:wdenk
Add support for TQM5200 board * Patch by Martin Krause, 29 Jun 2004: Add loopw command: infinite write loop on address range
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-10* Patch by Prakash Kumar, 27 Jun 2004:wdenk
Add support for the PXA250 based Intrinsyc Cerf board. * Patch by Yasushi Shoji, 27 Jun 2004: fix comment in include/common.h
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-07-09* Patch by Yuli Barcohen, 16 Jun 2004:wdenk
Remove obsolete AdderII port which was superseded by unified AdderII/Adder87x port * Patch by Ladislav Michl, 16 Jun 2004: Fix gcc-3.3.3 warnings for smc91111.c
2004-07-01* Code cleanup (ARM mostly)wdenk
* Patch by Curt Brune, 17 May 2004: - Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC) - Add support for ESPD-Inc. EVB4510 Board
2004-06-09* Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for Analogue&Micro Adder87x and the older AdderII board. * Patch by Ming-Len Wu, 09 Jun 2004: Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
2004-06-09Patch by Sam Song, 09 Jun 2004:wdenk
- Add support for RPXlite_DW board - Update FLASH driver for 4*AM29DL323DB90VI - Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
2004-06-09Patch by Yuli Barcohen, 20 May 2004:wdenk
Add support for Interphase iSPAN boards.
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-09Patch by Tolunay Orkun, 14 May 2004:wdenk
Add support for Cogent CSB472 board (8MB Flash Rev)
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-06-06Patch by Yuli Barcohen, 19 Apr 2004:wdenk
- Rename DUET_ADS to MPC885ADS - Rename CONFIG_DUET to CONFIG_MPC885_FAMILY - Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY - Clean up FADS family port to use the new defines
2004-04-18* Temporarily disabled John Kerl's extended MII command code becausewdenk
"miivals.h" is missing * Patches by Mark Jonas, 13 Apr 2004: - Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S - Add sync instructions to IceCube SDRAM init code - Move SDRAM chip constants into seperate include files - Unify DDR and SDR initialization code - Unify all IceCube (Lite5xxx) target names
2004-04-18* Patch by Dan Malek, 07 Apr 2004:wdenk
- Add support for RPC/STx GP3, Motorola 8560 board - Update 85xx TSEC driver so it searches MII for first available PHY and uses that one. - Add functions to support console MII commands. * Patch by Tolunay Orkun, 07 Apr 2004: Move initialization of bi_iic_fast[] from board_init_f() to board_init_r() * Patch by Yasushi Shoji, 07 Apr 2004: Cleanup microblaze port * Patch by Sangmoon Kim, 07 Apr 2004: Add auto SDRAM module detection for Debris board
2004-04-15* Patch by George G. Davis, 02 Apr 2004:wdenk
add support for Intel Assabet board
2004-04-15* Patch by Stephen Williams, 01 Apr 2004:wdenk
Add support for Picture Elements JSE board * Patch by Christian Pell, 01 Apr 2004: Add CompactFlash support for PXA systems.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
2004-03-14* Patches by Travis Sawyer, 12 Mar 2004:wdenk
- Fix Gigabit Ethernet support for 440GX - Add Gigabit Ethernet Support to MII PHY utilities * Patch by Brad Kemp, 12 Mar 2004: Fixes for drivers/cfi_flash.c: - Better support for x8/x16 implementations - Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE - Added defines for AMD command and address constants * Patch by Leon Kukovec, 12 Mar 2004: Fix get_dentfromdir() to correctly handle deleted dentries * Patch by George G. Davis, 11 Mar 2004: Remove hard coded network settings in TI OMAP1610 H2 default board config * Patch by George G. Davis, 11 Mar 2004: add support for ADS GraphicsClient+ board.
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
2004-02-09Patches by Stephan Linz, 30 Jan 2004:wdenk
1: - board/altera/common/flash.c:flash_erase(): o allow interrupts befor get_timer() call o check-up each erased sector and avoid unexpected timeouts - board/altera/dk1c20/dk1s10.c:board_early_init_f(): o enclose sevenseg_set() in cpp condition - remove the ASMI configuration for DK1S10_standard_32 (never present) - fix some typed in mistakes in the NIOS documentation 2: - split DK1C20 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1C20.h 3: - split DK1S10 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1S10.h 4: - Add support for the Microtronix Linux Development Kit NIOS CPU configuration at the Altera Nios Development Kit, Stratix Edition (DK-1S10) 5: - Add documentation for the Altera Nios Development Kit, Stratix Edition (DK-1S10) 6: - Add support for the Nios Serial Peripharel Interface (SPI) (master only) 7: - Add support for the common U-Boot SPI framework at RTC driver DS1306
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
