relocate ichache_State to ram
u-boot can run from internal flash
Add EB+MCF-EV123 board support.
Add m68k Boards to MAKEALL
Patch from Jens Scharsig, 08 Aug 2005
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
Patch by Yuli Barcohen, 13 Jul 2005
Code cleanup.
Rewrite of NAND code based on what is in 2.6.12 Linux kernel
Patch by Ladislav Michl, 29 Jun 2005
[Merge with /home/tur/nand/u-boot]
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and
BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for
NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is
implemented for these boards.
zylonite). Minor pxa-regs.h update.
done so far:
* created zylonite board dir (based on lubbock)
* extended some - but not all pxa sources and headers for Intel
Monahans support (CONFIG_CPU_MONAHANS)
* created Makefile zylonite target + MAKEALL entry
* added some debug nonsense, remove later, grep for mk@tbd
Status: compiles (eldk-4.0), and can be started with BDI, but runs forever
and doesn't halt at breakpoints. Hmmm...
- Support for TQM8541/8555 boards added.
- Complete rework of TQM8540/8560 support.
- Common TQM85xx code now supports all current TQM85xx platforms
(TQM8540/8541/8555/8560).
- DDR SDRAM size detection added.
- CAS latency default values can be overwritten by setting "serial#"
to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used.
If problems are detected with this non default CAS latency,
the defualt values will be used instead.
- FLASH size detection added.
- Moved FCC ethernet driver initialization behind TSEC driver init
-> TSEC is first device.
Patch by Stefan Roese, 30 Nov 2005
Patch by John Otken, 23 Nov 2005
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c
- CFG_FLASH_QUIET_TEST added to use the common CFI driver
for bank autodetection
Patch by Stefan Roese, 22 Nov 2005
Added CONFIG_NET_MULTI for VOM405 board.
Added reset_phy() for VOM405 board.
Patch by Matthias Fuchs, 09 Nov 2005
Patch by Stefan Roese, 20 Oct 2005
Patch by James MacAulay, 07 Oct 2005
Use lowlevel_init() instead of platformsetup() [rename].
Patch by Peter Pearse, 06 Oct 2005
Patch by Anders Larsen, 29 Apr 2005
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005
Patch by Eric Benard, 07 Apr 2005
Patch by Rowel Atienza, 06 Apr 2005
Patch by Marc Leeman, 04 Mar 2005
Patch by Cliff Brake, 04 Feb 2005
Patch by Peter Pearse, 2 Feb 2005
Patch by Matthias Fuchs, 22 Sep 2005
Removed CFG_CMD_DISPLAY from default commands.
Fixed compiler warning in net.c.
Patch by Stefan Roese, 31 Aug 2005
Patch by Reinhard Arlt, 22 Aug 2005
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
Second serial port on 440GX now defined as a system device.
Add 'Short Etch' code for Cicada PHY within 440gx_enet.c
Patch by Travis B. Sawyer, 12 Jul 2005
Check return value of malloc in 440gx_enet.c
Patch by Travis B. Sawyer, 18 Jul 2005
Patch by Yuli Barcohen, 12 Dec 2004
Minor code cleanup.
Patch by Josef Wagner, 03 Aug 2005
Patch by Stefan Roese, 01 Aug 2005
Add Xianghua Xiao and Lunsheng Wang's support for the
GDA MPC8540 EVAL board.
Add support for the Freescale MPC8349ADS board.
Implemented support for MPC8548CDS board.
Added DDR II support based on SPD values for MPC85xx boards.
This roll-up patch also includes bugfies for the previously
published patches:
DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
* Add MPC8220 boards to MAKEALL script
* Add EEPROM and RTC support for HMI1001 board
* Patch by Detlev Zundel, 20 Jun 2005:
Fix initialization of low active GPIO pins on inka4x0 board
- update the pxa-regs.h file for PXA27x chips
- add PXA27x based ADSVIX board
- add support for MMC on PXA27x processors
* Patch by Andrew E. Mileski, 28 Nov 2004:
Fix PPC4xx SPD SDRAM detection bug
* Patch by Hiroshi Ito, 26 Nov 2004:
Fix logic of "test -z" and "test -n" commands
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
