path: root/MAKEALL
2009-03-26Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2009-03-25ARM: Add the imx31_phycore_eet board to MAKEALLGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20Add support for the digsy MTC board.Grzegorz Bernacki
This is the InterControl custom device based on the MPC5200B chip. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2009-03-188xx: add support for new keymile kmsupx4 board.Heiko Schocher
This patch adds support for the kmsupx4 board from Keymile, based on a Freescale MPC852T CPU - serial console on SMC1 - 32 MB SDRAM - 32 MB NOR Flash - Ethernet over SCC3 - I2C Bitbang Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_AG moduleWolfgang Grandegger
The TQM8548_AG is a variant of the TQM8548 module with 1 GiB memory, CAN and without PCI/PCI-X and RTC. U-Boot can be built for this module with "$ make TQM8548_AG_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_BE moduleWolfgang Grandegger
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN interface. With NAND support, the image is significantly larger and TEXT_BASE is adjusted accordingly. U-Boot can be built for this module with "$ make TQM8548_BE_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-10qong: support for Dave/DENX QongEVB-LITE boardIlya Yanok
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-01Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-01-28OMAP3: Add Zoom1 board supportDirk Behme
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here: http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Pandora supportDirk Behme
Add Pandora support. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add EVM boardDirk Behme
Add EVM board support. Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Overo boardDirk Behme
Add Overo board support. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add common power code, README, and BeagleBoardDirk Behme
Add BeagleBoard support, common power code and README. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-01-27Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2009-01-27MIPS: Add VCT board series support (Part 3/3)Stefan Roese
2009-01-26ppc4xx: Add GDsys PowerPC 440 ETX board support.Dirk Eibach
Board support for the Guntermann & Drunck PowerPC 440 ETX module. Based on the AMCC Yosemite board support by Stefan Roese. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-24Initial support for Nomadik 8815 development boardAlessandro Rubini
The NMDK8815 board is distributed by ST Microelectornics. Other (proprietary) code must be run to unlock the CPU before U-Boot runs. doc/README.nmdk8815 outlines the boot sequence. This is the initial port, with basic infrastructure and a working serial port. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-01-24Added initial eNET board supportGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-23Merge branch 'next'Kim Phillips
2009-01-24powerpc: 83xx: add support for the kmeter1 boardHeiko Schocher
This patch adds support for the kmeter1 board from Keymile, based on a Freescale MPC8360 CPU. - serial console on UART 1 - 256 MB DDR2 RAM - 64 MB NOR Flash - Ethernet RMII Mode over UCC4 - PHY SMSC LAN8700 Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-2385xx: Add a 36-bit physical configuration for MPC8572DSKumar Gala
We move all IO addressed (CCSR, localbus, PCI) above the 4G boundary to allow for larger memory sizes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-23mpc83xx: New board support for SIMPC8313Ron Madrid
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This board boots from NAND devices and is configureable for either large or small page devices. The board supports non-soldered DDR2, one ethernet port, a Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected to the eLBC providing glue logic to a TMS320C67xx DSP. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-01-23microblaze: Rename ml401 to microblaze-genericMichal Simek
2009-01-21Merge branch 'master' into nextKim Phillips
2008-12-19XPedite5200 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5200 - a MPC8548-based PMC single board computer. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19XPedite5370 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5370 - a MPC8572-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-10microblaze: Remove XUPV2P boardMichal Simek
--- Microblaze platforms use generic settings and to have many platforms is confusing that's why I decided to remove this platform from U-BOOT. ml401 tree is sufficient for covering all Microblaze platforms. This change will go through microblaze custodian tree.
2008-12-09MAKEALL: Automatically use parallel buildsWolfgang Denk
Add logic to the MAKEALL script to determine the number of CPU cores on the system, and run a parallel build if there is more than one. Usually this significantrly accelerates builds. Allow to manually adjust the number of parallel make jobs by using the "BUILD_NCPUS" environment variable. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-20powerpc: 83xx: add support for the kmeter1 boardHeiko Schocher
This patch adds support for the kmeter1 board from Keymile, based on a Freescale MPC8360 CPU. - serial console on UART 1 - 256 MB DDR2 RAM - 64 MB NOR Flash - Ethernet RMII Mode over UCC4 - PHY SMSC LAN8700 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-11-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-11-04Custom AFEB9260 board supportSergey Lapin
This patch provides support for AFEB9260 board, a product of OpenSource hardware and software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-11-03ColdFire: Add MCF5301x CPU and M53017EVB supportTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-24ppc4xx: New board avnet fx12 minimodulGeorg Schardt
This patch adds support for the avnet fx12 minimodul. It needs the "ppc4xx: Generic architecture for xilinx ppc405" patch from Ricardo. Signed-off-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add GDSys neo 405EP board supportDirk Eibach
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-05ppc44x: Unification of virtex5 pp440 boardsRicardo Ribalda Delgado
This patch provides an unificated way of handling xilinx v5 ppc440 boards. It unificates 3 different things: 1) Source code A new board called ppc440-generic has been created. This board includes a generic tlb initialization (Maps the whole memory into virtual) and defines board_pre_init, checkboard, initdram and get_sys_info weakly, so, they can be replaced by specific functions. If a new board needs to redefine any of the previous functions (specific initialization) it can create a new directory with the specific initializations needed. (see the example ml507 board). 2) Configuration file Common configurations are located under configs/xilinx-ppc440.h, this header file interpretes the xparameters file generated by EDK and configurates u-boot in correspondence. Example: if there is a Temac, allows CMD_CONFIG_NET Specific configuration are located under specific configuration file. (see the example ml507 board) 3) Makefile Some work has been done in order to not duplicate work in the Main Makefile. Please see the attached code. In order to support new boards they can be implemented in the next way: a) Simple Generic Board (90% of the time) Using EDK generates a new xparameters.h file, replace ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config && make b) Simple Boards with special u-boot parameters (9 % of the time) Create a new file under configs for it (use ml507.h as example) and change your paramaters. Create a new Makefile paragraph and compile c) Complex boards (1% of the time) Create a new folder for the board, like the ml507 Finally, it adds support for the Avnet FX30T Evaluation board, following the new generic structure: Cheap board by Avnet for evaluating the Virtex5 FX technology. This patch adds support for: - UartLite - 16MB Flash - 64MB RAM Prior using U-boot in this board, read carefully the ERRATA by Avnet to solve some memory initialization issues. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03mpc83xx: fix mpc8313 in-tree building with NANDNick Spence
and add mpc8313 NAND build to MAKEALL Signed-off-by: Nick Spence <nick.spence@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-01Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-31sh: Add support sh2 to MAKEALLNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas Solutions AP325RXA board supportNobuhiro Iwamatsu
AP325RXA is SH7723's reference board. This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other. In this patch, support SCIF, NOR Flash, and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas RSK+ 7203 board supportNobuhiro Iwamatsu
This adds initial support for the RTE RSK+ SH7203 board. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas R0P7785LC0011RL board supportNobuhiro Iwamatsu
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash, Graphic, Ethernet, USB, SD, RTC, and I2C controller. This patch supports the following functions: - 128MB DDR2-SDRAM (29-bit address mode only) - NOR Flash - USB host - Ethernet Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31ARM: Add support for S3C6400 based SMDK6400 boardGuennadi Liakhovetski
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl driver for it too. The board can also boot from the NOR flash, but due to hardware limitations it can only address 64KiB on it, which is not enough for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-27mpc85xx: Add support for the MPC8536DS reference boardKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-27mpc85xx: Add support for the MPC8572DS reference boardKumar Gala
2008-08-26remove MVS1 boardAndre Schwarz
MVS1 board has reached end-of-life and can be removed completely. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
