path: root/MAKEALL
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-74xx-7xxWolfgang Denk
2007-04-04Merge with /home/wd/git/u-boot/custodian/u-boot-microblazeWolfgang Denk
2007-03-26Support for XUPV2P boardMichal Simek
Reset support BSP autoconfig support
2007-03-22Code cleanup / re-insert previous Copyright entries.Wolfgang Denk
2007-03-22Merge with /home/wd/git/u-boot/custodian/u-boot-blackfinWolfgang Denk
2007-03-21Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-21[PATCH] Add AMCC Acadia (405EZ) eval board supportStefan Roese
This patch adds support for the new AMCC Acadia eval board. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-20[Blackfin][PATCH] Add BF561 EZKIT board supportAubrey Li
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
2007-03-11[Microblaze][PATCH] part 2Michal Simek
timer support interrupt controller support flash support ethernet support cache support board information support env support booting image support adding support for Xilinx ML401
2007-03-09[Blackfin][PATCH-2/2] Common files changed to support bf533 platformAubrey.Li
2007-03-08Minor cleanup.Wolfgang Denk
2007-03-02mpc83xx: Add support for the MPC8349E-mITX-GPTimur Tabi
Add support for the MPC8349E-mITX-GP, a stripped-down version of the MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in HRCW is 0) for the ITX and a README for the ITX and the ITX-GP. Signed-off-by: Timur Tabi <timur@freescale.com>
2007-03-02mpc83xx: add MPC832XEMDS and sbc8349 to MAKEALLKim Phillips
2007-02-28Merge branch 'master' into hpc2roy zang
Conflicts: drivers/Makefile Fix the merge conflict in file drivers/Makefile Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2007-02-20Merge with /home/stefan/git/u-boot/denx-merge-srStefan Roese
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
2007-02-16Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-02-12Merge branch 'master' into hpc2roy zang
2007-02-09[Motion-PRO] Preliminary support for the Motion-PRO board.Bartlomiej Sieka
2007-01-31[PATCH] Add support for esd mecp5200 boardStefan Roese
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2007-01-30Merge branch 'master' into hpc2roy zang
2007-01-24Add port for the lpc2292sodimm evaluation board from EmbeddedArtistsGary Jennejohn
2007-01-22Merge branch 'master' into hpc2roy zang
Conflicts: drivers/cfi_flash.c The patch by Heiko Schocher <hs@pollux.denx.de> on Jan, 19, 2007 fixes cfi_driver bug for mpc7448hpc2 board. The default cfi_driver can support mpc7448hpc2 board.
2007-01-18[PATCH] Add support for Prodrive SCPU (PDNB3 variant) boardStefan Roese
2007-01-18Merge with /home/stefan/git/u-boot/denx-merge-srStefan Roese
2007-01-18[PATCH] Add support for AMCC Taishan PPC440GX eval boardStefan Roese
2007-01-16Raname solidcard3 into sc3; add redundant env for sc3Wolfgang Denk
2007-01-04Merge branch 'master' into hpc2roy zang
2006-12-22Minor code cleanup; update CHANGELOG.Wolfgang Denk
2006-12-20Preliminary support for the iDMR board (ColdFire).Bartlomiej Sieka
2006-12-01Fix the confilcts when merging 'master' into hpc2.roy zang
The conflicts due to a new mpc7448 p3m7448 board is in the main tree. Merge branch 'master' into hpc2 Conflicts: MAKEALL cpu/74xx_7xx/cpu.c cpu/74xx_7xx/cpu_init.c cpu/74xx_7xx/speed.c
2006-11-30Merge with http://opensource.freescale.com/pub/scm/u-boot-83xx.gitWolfgang Denk
2006-11-29[PATCH] Add support for Prodrive P3M750 & P3M7448 (P3Mx) boardsStefan Roese
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460) and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are quite similar and share the same board directory "prodrive/p3mx" and the same config file "p3mx.h". Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-28Merge http://www.denx.de/git/u-bootKim Phillips
2006-11-29Solve the copyright conflicts when merging 'master' into hpc2.roy zang
Merge branch 'master' into hpc2 Conflicts: drivers/cfi_flash.c
2006-11-27Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-11-10Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-11-03mpc83xx: Add MPC8360EMDS basic board supportDave Liu
Add support for the Freescale MPC8360EMDS board. Includes DDR, DUART, Local Bus, PCI.
2006-11-03mpc83xx: Add support for the MPC8349E-mITXTimur Tabi
PREREQUISITE PATCHES: * This patch can only be applied after the following patches have been applied: 1) DNX#2006090742000024 "Add support for multiple I2C buses" 2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x" 3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c" 4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems" 5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems" CHANGELOG: * Add support for the Freescale MPC8349E-mITX reference design platform. The second TSEC (Vitesse 7385 switch) is not supported at this time. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-02General code modification for mpc7448hpc2 board support.roy zang
1. Add 7447A and 7448 processor support. 2. Add the following flags. CFG_CONFIG_BUS_CLK : If the 74xx bus frequency can be configured dynamically (such as by switch on board), this flag should be set. CFG_EXCEPTION_AFTER_RELOCATE: If an exception occurs after the u-boot relocates to RAM, this flag should be set. CFG_SERIAL_HANG_IN_EXCEPTION: If the print out function will cause the system hang in exception, this flag should be set. There is a design issue for tsi108/109 pci configure read. When pci scan the slots, if there is no pci card, the tsi108/9 will cause a machine check exception for mpc7448 processor. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-10-24Add ATSTK1000 and ATSTK1002 board supportWolfgang Denk
Patch by Haavard Skinnemoen, 06 Sep 2006 This patch adds support for the ATSTK1000 with the ATSTK1002 CPU daughterboard. ATSTK1000 is a full-featured development board for AT32AP CPUs. It has two ethernet ports, a high quality QVGA LCD panel, a loudspeaker, and connectors for USART, PS/2, VGA, USB, MMC/SD cards and CompactFlash cards. For more information, please see this page: http://www.atmel.com/dyn/products/tools.asp?family_id=682 The ATSTK1002 is a daughterboard for the ATSTK1000 supporting the AT32AP7000 chip. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-18Merge with /home/tur/proj/051_uboot_linux_v38b/u-bootWolfgang Denk
2006-10-13Preliminary patch adding support for the MarelV38B board.Bartlomiej Sieka
2006-10-09Add support for EP82xxM boardsWolfgang Denk
Patch by Aaron Sells, 20 Jun 2006
2006-09-18Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-09-09Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-07Fix build problem cpu/ppc4xx/ndfc.cStefan Roese
Patch by Stefan Roese, 07 Sep 2006
2006-09-07Fix LOG_DIR directory creation error.Marian Balakowicz
Add support for automatic creation of BUILD_DIR directory.
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
