path: root/MAKEALL
2008-12-19XPedite5200 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5200 - a MPC8548-based PMC single board computer. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19XPedite5370 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5370 - a MPC8572-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-10microblaze: Remove XUPV2P boardMichal Simek
--- Microblaze platforms use generic settings and to have many platforms is confusing that's why I decided to remove this platform from U-BOOT. ml401 tree is sufficient for covering all Microblaze platforms. This change will go through microblaze custodian tree.
2008-12-09MAKEALL: Automatically use parallel buildsWolfgang Denk
Add logic to the MAKEALL script to determine the number of CPU cores on the system, and run a parallel build if there is more than one. Usually this significantrly accelerates builds. Allow to manually adjust the number of parallel make jobs by using the "BUILD_NCPUS" environment variable. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-11-04Custom AFEB9260 board supportSergey Lapin
This patch provides support for AFEB9260 board, a product of OpenSource hardware and software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-11-03ColdFire: Add MCF5301x CPU and M53017EVB supportTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-24ppc4xx: New board avnet fx12 minimodulGeorg Schardt
This patch adds support for the avnet fx12 minimodul. It needs the "ppc4xx: Generic architecture for xilinx ppc405" patch from Ricardo. Signed-off-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add GDSys neo 405EP board supportDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-05ppc44x: Unification of virtex5 pp440 boardsRicardo Ribalda Delgado
This patch provides an unificated way of handling xilinx v5 ppc440 boards. It unificates 3 different things: 1) Source code A new board called ppc440-generic has been created. This board includes a generic tlb initialization (Maps the whole memory into virtual) and defines board_pre_init, checkboard, initdram and get_sys_info weakly, so, they can be replaced by specific functions. If a new board needs to redefine any of the previous functions (specific initialization) it can create a new directory with the specific initializations needed. (see the example ml507 board). 2) Configuration file Common configurations are located under configs/xilinx-ppc440.h, this header file interpretes the xparameters file generated by EDK and configurates u-boot in correspondence. Example: if there is a Temac, allows CMD_CONFIG_NET Specific configuration are located under specific configuration file. (see the example ml507 board) 3) Makefile Some work has been done in order to not duplicate work in the Main Makefile. Please see the attached code. In order to support new boards they can be implemented in the next way: a) Simple Generic Board (90% of the time) Using EDK generates a new xparameters.h file, replace ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config && make b) Simple Boards with special u-boot parameters (9 % of the time) Create a new file under configs for it (use ml507.h as example) and change your paramaters. Create a new Makefile paragraph and compile c) Complex boards (1% of the time) Create a new folder for the board, like the ml507 Finally, it adds support for the Avnet FX30T Evaluation board, following the new generic structure: Cheap board by Avnet for evaluating the Virtex5 FX technology. This patch adds support for: - UartLite - 16MB Flash - 64MB RAM Prior using U-boot in this board, read carefully the ERRATA by Avnet to solve some memory initialization issues. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03mpc83xx: fix mpc8313 in-tree building with NANDNick Spence
and add mpc8313 NAND build to MAKEALL Signed-off-by: Nick Spence <nick.spence@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-01Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-31sh: Add support sh2 to MAKEALLNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas Solutions AP325RXA board supportNobuhiro Iwamatsu
AP325RXA is SH7723's reference board. This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other. In this patch, support SCIF, NOR Flash, and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas RSK+ 7203 board supportNobuhiro Iwamatsu
This adds initial support for the RTE RSK+ SH7203 board. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas R0P7785LC0011RL board supportNobuhiro Iwamatsu
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash, Graphic, Ethernet, USB, SD, RTC, and I2C controller. This patch supports the following functions: - 128MB DDR2-SDRAM (29-bit address mode only) - NOR Flash - USB host - Ethernet Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31ARM: Add support for S3C6400 based SMDK6400 boardGuennadi Liakhovetski
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl driver for it too. The board can also boot from the NOR flash, but due to hardware limitations it can only address 64KiB on it, which is not enough for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-27mpc85xx: Add support for the MPC8536DS reference boardKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-27mpc85xx: Add support for the MPC8572DS reference boardKumar Gala
2008-08-26remove MVS1 boardAndre Schwarz
MVS1 board has reached end-of-life and can be removed completely. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2008-08-20Merge branch 'next' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
Conflicts: MAINTAINERS
2008-08-20Merge branch 'mimc200' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
Conflicts: MAKEALL Makefile
2008-08-20avr32: Add MIMC200 boardMark Jackson
The MIMC200 board is based on Atmel's NGW100 dev kit, but with an extra 8MByte FLASH and 128KByte FRAM. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-14ColdFire: Add M54451EVB platform support for MCF5445xTsiChung Liew
2008-08-14ColdFire: Add M5253DEMO platform support for MCF5253TsiChung Liew
2008-08-06Merge branch 'favr-32' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
Conflicts: MAINTAINERS MAKEALL Makefile
2008-08-06avr32: add support for EarthLCD Favr-32 boardHans-Christian Egtvedt
This patch adds support for the Favr-32 board made by EarthLCD. This kit, which is also called ezLCD-101 when running with EarthLCD firmware, has a 10.4" touch screen LCD panel, 16 MB 32-bit SDRAM, 8 MB parallel flash, Ethernet, audio out, USB device, SD-card slot, USART and various other connectors for cennecting stuff to SPI, I2C, GPIO, etc. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-06Fix merge problemsStefan Roese
2008-07-30ppc4xx: ML507: U-Boot in flash and System ACERicardo Ribalda Delgado
This patch allows booting from FLASH the ML507 board by Xilinx. Previously, U-Boot needed to be loaded from JTAG or a Sytem ACE CF Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-30Add support for the hammerhead (AVR32) boardJulien May
The Hammerhead platform is built around a AVR32 32-bit microcontroller from Atmel. It offers versatile peripherals, such as ethernet, usb device, usb host etc. The board also incooperates a power supply and is a Power over Ethernet (PoE) Powered Device (PD). Additonally, a Cyclone III FPGA from Altera is integrated on the board. The FPGA is mapped into the 32-bit AVR memory bus. The FPGA offers two DDR2 SDRAM interfaces, which will cover even the most exceptional need of memory bandwidth. Together with the onboard video decoder the board is ready for video processing. For more information see: http:///www.miromico.com/hammerhead Signed-off-by: Julien May <mailinglist@miromico.ch> [haavard.skinnemoen@atmel.com: various small fixes and adaptions] Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-30Removed support for the adsvix board.Adrian Filipi
Support for the adsvix was originally provided by Applied Data Systems (ADS), inc., now EuroTech, Inc. The board never shipped aside from some sample boards. Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
2008-07-18ppc4xx: ML507 Board SupportRicardo Ribalda Delgado
The Xilinx ML507 Board is a Virtex 5 prototyping board that includes, among others: -Virtex 5 FX FPGA (With a ppc440x5 in it) -256MB of SDRAM2 -32MB of Flash -I2C Eeprom -System ACE chip -Serial ATA connectors -RS232 Level Conversors -Ethernet Transceiver This patch gives support to a standard design produced by EDK for this board: ppc440, uartlite, xilinx_int and flash - Includes Changes propossed by Stefan Roese and Michal Simek Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Stefan Roese <sr@denx.de>
2008-07-17Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-14Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-13Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2008-07-11ColdFire: Fix incorrect board name in MAKEALL for M5253EVBETsiChung Liew
2008-07-11ppc4xx: Initial framework of the AMCC PPC460SX redwood reference board.Feng Kan
Add AMCC Redwood reference board that uses the latest PPC 464 CPU processor combined with a rich mix of peripheral controllers. The board will support PCIe, mutiple Gig ethernet ports, advanced hardware RAID assistance and IEEE 1588. Signed-off-by: Feng Kan <fkan@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10MAKEALL: remove duplicated at91 from ARM9 list and add LIST_at91 to armJean-Christophe PLAGNIOL-VILLARD
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-06-28ARM: Add support for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
This patch adds support for the Lyrtech SFF-SDR board, based on the TI DaVinci architecture (ARM926EJS). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister <philip@balister.org> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxWolfgang Denk
Conflicts: include/asm-ppc/fsl_lbc.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-11TQM8548: Basic support for the TQM8548 modulesWolfgang Grandegger
This patch adds basic support for the TQM8548 module from TQ-Components (http://www.tqc.de/) including DDR2 SDRAM initialisation and support for eTSEC 3 and 4 Furthermore Flash buffer write has been enabled to speed up output to the Flash by approx. a factor of 10. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-10add MPC8343 based board mvBlueLYNX-M7 (board+make files)Andre Schwarz
Add MPC8343 based board mvBlueLYNX-M7. It's a single board stereo camera system. Please read doc/README.mvblm7 for details. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-09sh: Renesas Solutions SH7763RDP board supportNobuhiro Iwamatsu
SH7763RDP has SCIF, NOR Flash, Ethernet, USB host, LCDC and MMC. In this patch, support SCIF, NOR Flash, and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-06-03Merge remote branch 'u-boot-avr32/master'Wolfgang Denk
2008-06-02Merge remote branch 'u-boot-ppc4xx/master'Wolfgang Denk
