Since I haven't been actively maintaining these boards for a long while,
keeping myself as their maintainer makes no sense.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
It includes:
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The nios-32 arch is obsolete and broken. So it is removed.
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0
GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot
References:
http://www.globalscaletechnologies.com/t-guruplugdetails.aspx
http://plugcomputer.org
This patch is for GuruPlug Plus, but it supports Standard version
as well.
Signed-off-by: Siddarth Gore <gores@marvell.com>
This patch adds support for the magnesium board from
projectiondesign. This board uses i.MX27 SoC and has
8MB NOR flash, 128MB NAND flash, FEC ethernet controller
integrated into i.MX27. As this port is based on
the imx27lite port, common config options are collected
in include/configs/imx27lite-common.h
This patch adds support for the Mosaix Technologies, Inc. ICON board,
based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM
(512MB standard) and 64MByte of NOR FLASH.
Support for the onboard SM502 will be added later.
This is a generic approach to port u-boot for nios2 boards.
You may find the usage of this approach on the nioswiki,
http://nioswiki.com/DasUBoot
A fpga parameter file, which contains base address information
and drivers declaration, is generated from Altera's hardware system
description sopc file using tools.
The example fpga parameter file is compatible with EP1C20, EP1S10
and EP1S40 boards. So these boards can be removed after this commit.
Though epcs controller is removed to cut the dependency of altera_spi
driver.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh.
Signed-off-by: Michael Weiss <michael.weiss@ifm.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
A low cost 4 port IP-PBX board.
Signed-off-by: Brent Kandetzki <BrentK@teleco.com>
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
We do not support a processor that never reached a real customer.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Added support for the following EDB93xx boards:
EDB9301
EDB9302
EDB9302A
EDB9307
EDB9307A
EDB93012
EDB9315
EDB9315A
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
The EXBITGEN board has not been maintained for a long time; it has
build problems, but no hardware is available any more for testing.
Drop support for this board.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
The new board revision has a different LCD.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru>
The caddy2 is a variant of the already supported vme8349. So we just
add the differences to this board port. To better support those two
boards we switched from fixed SDRAM configuration to usage of
spd_sdram(). This is done by providing a board specific SPD EEPROM
routine with different values for both boards.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
changed to use mkconfig -t option instead, plus misc codingstyle fixes.
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
This patch adds support for A320 evaluation board from Faraday. This board
uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM.
FA526 is an ARMv4 processor and uses the ARM920T source in this patch.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Integrate DA830 EVM support into U-Boot.
Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum
Digital EVM board. See http://www.spectrumdigital.com/
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
This patch adds support for the board IPEK01 based on the MPC5200.
The Futjitsu Lime graphics controller is configured in 16 bpp mode.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Start of support of
Texas Instruments Software Development Platform(SDP)
for OMAP3430 - SDP3430
Highlights of this platform are:
Flash Memory devices:
Sibley NOR, Micron 8bit NAND and OneNAND
Connectivity:
3 UARTs and expanded 4 UART ports + IrDA
Ethernet, USB
Other peripherals:
TWL5030 PMIC+Audio+Keypad
VGA display
Expansion ports:
Memory devices plugin boards (PISMO)
Connectivity board for GPS,WLAN etc.
Completely configurable boot sequence and device mapping
etc.
Support default jumpering and:
- UART1/ttyS0 console(legacy sdp3430 u-boot)
- UART3/ttyS2 console (matching other boards,
and SDP HW docs)
- Ethernet
- mmc0
- NOR boot
Currently the UART1 is enabled by default. for
compatibility with other OMAP3 u-boot platforms,
enable the #define of CONSOLE_J9.
Makefile
Fixed the conflict with smdkc100_config by moving omap_sdp3430_config
to it is alphabetically sorted location above zoom1.
Signed-off-by: David Brownell <david-b@pacbell.net>
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Adding entries to the MAINTAINERS directory for the
DM355 and DM365 EVM.
This patch adds support for the leopard board which is
based on the DM355 SOC.
This patch adds the initial support for DM6467 EVM.
Other features like NET and NAND support will be added as follow up patches.
Adds new board SMDKC100 that uses s5pc100 SoC
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
