path: root/MAINTAINERS
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-05MAINTAINERS: Add Tetsuyuki Kobayshi for kzm9gTetsuyuki Kobayashi
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-04Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-10-03Merge remote-tracking branch 'u-boot-marvell/master'Albert ARIBAUD
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
2012-10-03ARM : Add support for MINI2440 (s3c2440).Gabriel Huau
Support of the MINI2440 board from FriendlyARM from an old version of u-boot : http://repo.or.cz/r/u-boot-openmoko/mini2440.git Currently, supporting only boot from NOR. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add supoprt for KMC KZM-A9-GT boardNobuhiro Iwamatsu
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-02TNETV107X: Change tnetv107x_evm maintainerChan-Taek Park
2012-10-02MAINTAINERS: New maintainer for Samsung's Trats development board.Łukasz Majewski
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2012-09-13avr32: add atngw100mkii boardAndreas Bießmann
This patch is derived from an older patch provided by atmel in its buildroot-avr32-v3.0.0.tar.bz2 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2012-09-01Take over the maintainer for sam9g10 and sam9m10g45Bo Shen
As the maintainer for at91sam9g10ek and at91sam9m10g45ek can not reach any more. So I wish to take over the maintainer for sam9g10 and sam9m10g45 Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01efikamx: update MAINTAINERS for Genesi Efika MX systemsMatt Sealey
Update maintainer for "efikamx" and "efikasb" to myself. Signed-off-by: Matt Sealey <matt@genesi-usa.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01ARM: add Raspberry Pi model B board, using BCM2835 SoCStephen Warren
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM, contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors. For more details, see http://www.raspberrypi.org/. Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack relocation to top of RAM) extracted from work by: Oleksandr Tymoshenko <gonzo@bluezbox.com>. GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Tom Rini <trini@ti.com>
2012-09-01snowball: Add support for ux500 based snowball boardMathieu J. Poirier
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Tom Rini <trini@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Conflicts: drivers/gpio/Makefile
2012-09-01MX28: Add SchulerControl SC_SPS_1 platformMarek Vasut
This i.MX28 platform supports the following: * 2x FEC ethernet * USB on USBH0 * I2C EEPROM * SPI NVRAM * LEDs Signed-off-by: Marek Vasut <marex@denx.de>
2012-09-01Add support for Bluegiga APX4 Development KitVeli-Pekka Peltola
This adds support for Bluegiga APX4 Development Kit. It is built around Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC, RTC and USB. APX4 has only one ethernet port. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01at91: Add support for taskit AT91SAM9G20 boards.Markus Hubig
This adds support for the AT91SAM9G20 boards by taskit GmbH. Both boards, Stamp9G20 and PortuxG20, are integrated in one file. PortuxG20 is basically a SBC built around the Stamp9G20. Signed-off-by: Markus Hubig <mhubig@imko.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
2012-09-01MAINTAINERS: fix Andreas Bießmann AVR32 entryAndreas Bießmann
The grasshopper board is a avr32 based device and belongs therefore to the avr32 section. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01MAINTAINERS: fix entry of Ilko IlievAndreas Bießmann
These boards have ARM cores, move to the ARM section. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01mpc52xx: add common o2dnt and o2dnt2 support and configurationsAnatolij Gustschin
Add common code for o2dnt and o2dnt2 based boards and add different board configuration files for O2D, O2I, O2DNT2, O2D300, O2MNT and O3DNT boards. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-08-09rename EB+MCF-EV123 to its current marketing name EB+CPU5282Jens Scharsig
* rename board directory to eb_cpu5282 * rename EB+MCF-EV123_.*config to eb_cpu5282_.*config * add Maintainer for EB+CPU5282 board * rename prompt Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-08-07MAINTAINERS: cleanup for km ppc boardsHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> Acked-by: Heiko Schocher <hs@denx.de>
2012-07-31SMDK6400: Add MAINTAINERS entryZhong Hongbo
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
2012-07-09tegra: Add Tamonten Evaluation Carrier supportThierry Reding
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten processor board. More information is available here: http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (212 commits) ARM: cache: Move the cp15 CR register read before flushing the cache. ARM: introduce arch_early_init_r() PXA: Enable CONFIG_PREBOOT on zipitz2 ARM: mx28: Remove CONFIG_ARCH_CPU_INIT No need to define CONFIG_ARCH_CPU_INIT. add new board vl_ma2sc MTD: SPEAr SMI: Add write support for length < 4 bytes i2c: designware_i2c.c: Add support for the "i2c probe" command rtc/m41t62: Add support for M41T82 with HT (Halt Update) SPL: ARM: spear: Add SPL support for SPEAr600 platform Makefile: Add u-boot.spr build target (SPEAr) SPL: ARM: spear: Remove some objects from SPL build SPL: lib/Makefile: Add crc32.c to SPL build SPL: common/Makefile: Add image.c to SPL build arm: Don't use printf() in SPL builds GPIO: Add SPEAr GPIO driver net: Multiple updates/enhancements to designware.c cleanup/SPEAr: Define configuration flags more elegantly cleanup/SPEAr: Remove unnecessary parenthesis SPEAr: Correct SoC ID offset in misc configuration space SPEAr: explicitly select clk src for UART SPEAr: Remove CONFIG_MTD_NAND_VERIFY_WRITE to speed up NAND access SPEAr: Enable ONFI nand flash detection for spear3xx and 6xx and evb SPEAr: Enable CONFIG_SYS_FLASH_EMPTY_INFO macro SPEAr: Correct the definition of CONFIG_SYS_MONITOR_BASE SPEAr: Enable CONFIG_SYS_FLASH_PROTECTION SPEAr: Enable dcache for fast file transfer SPEAr: Enable autoneg for ethernet SPEAr: Enable udc and usb-console support only for usbtty configuration SPEAr: Enable usb device high speed support SPEAr: Initialize SNOR in early_board_init_f SPEAr: Change the default environment variables SPEAr: Remove unused flag (CONFIG_SYS_HZ_CLOCK) SPEAr: Add configuration options for spear3xx and spear6xx boards SPEAr: Add basic arch related support for SPEAr SoCs SPEAr: Add interface information in initialization SPEAr: Add macb driver support for spear310 and spear320 SPEAr: Configure network support for spear SoCs SPEAr: Place ethaddr write and read within CONFIG_CMD_NET SPEAr: Eliminate dependency on Xloader table SPEAr: Fix ARM relocation support st_smi: Fixed page size for Winbond W25Q128FV flash st_smi: Change timeout loop implementation st_smi: Fix bug in flash_print_info() st_smi: Change the flash probing method st_smi: Removed no needed dependency on ST_M25Pxx_ID st_smi: Fix smi read status st_smi: Move status register read before modifying ctrl register st_smi: Read status until timeout happens st_smi: Enhance the error handling st_smi: Change SMI timeout values st_smi: Return error in case TFF is not set st_smi: Add support for SPEAr SMI driver mtd/NAND: Remove obsolete SPEAr specific NAND drivers SPEAr: Configure FSMC driver for NAND interface mtd/NAND: Add FSMC driver support arm/km: remove calls to kw_gpio_* in board_early_init_f arm/km: add implementation for read_dip_switch arm/km: support the 2 PCIe fpga resets arm/km: skip FPGA config when already configured arm/km: redefine piggy 4 reg names to avoid conflicts arm/km: cleanup km_kirkwood boards arm/km: enable BOCO2 FPGA download support arm/km: remove portl2.h and use km_kirkwood instead arm/km: convert mgcoge3un target to km_kirkwood arm/km: add kmcoge5un board support arm/km: add kmnusa board support arm: bugfix: save_boot_params_default accesses uninitalized stack when -O0 cm-t35: fix incorrect NAND_ECC layout selection ARM: OMAP4/5: Do not configure non essential pads, clocks, dplls. ARM: OMAP4/5: Move USB pads to essential list. ARM: OMAP4/5: Move USB clocks to essential group. ARM: OMAP4/5: Move gpmc clocks to essential group. ARM: OMAP4+: Move external phy initialisations to arch specific place. omap4: Use a smaller M,N couple for IVA DPLL da850/omap-l138: Enable auto negotiation in RMII mode omap: am33xx: accomodate input clocks other than 24 Mhz omap: emif: fix bug in manufacturer code test omap: emif: deal with rams that return duplicate mr data on all byte lanes OMAP4+: Force DDR in self-refresh after warm reset OMAP4+: Handle sdram init after warm reset ARM: OMAP3+: Detect reset type arm: bugfix: Move vector table before jumping relocated code Kirkwood: Add support for Ka-Ro TK71 arm/km: use spi claim bus to switch between SPI and NAND arm/kirkwood: protect the ENV_SPI #defines ARM: don't probe PHY address for LaCie boards lacie_kw: fix CONFIG_SYS_KWD_CONFIG for inetspace_v2 lacie_kw: fix SDRAM banks number for net2big_v2 Kirkwood: add lschlv2 and lsxhl board support net: add helper to generate random mac address net: use common rand()/srand() functions lib: add rand() function kwboot: boot kirkwood SoCs over a serial link kw_spi: add weak functions board_spi_claim/release_bus kw_spi: support spi_claim/release_bus functions kw_spi: backup and reset the MPP of the chosen CS pin kirkwood: fix calls to kirkwood_mpp_conf kirkwood: add save functionality kirkwood_mpp_conf function km_arm: use filesize for erase in update command arm/km: enable mii cmd arm/km: remove CONFIG_RESET_PHY_R arm/km: change maintainer for mgcoge3un arm/km: fix wrong comment in SDRAM config for mgcoge3un arm/km: use ARRAY_SIZE macro arm/km: rename CONFIG option CONFIG_KM_DEF_ENV_UPDATE arm/km: add piggy mac adress offset for mgcoge3un arm/km: add board type to boards.cfg AT91SAM9*: Change kernel address in dataflash to match u-boot's size ATMEL/PIO: Enable new feature of PIO on Atmel device ehci-atmel: fix compiler warning AT91: at91sam9m10g45ek : Enable EHCI instead OHCI Atmel : usb : add EHCI driver for Atmel SoC Fix: AT91SAM9263 nor flash usage Fix: broken boot message at serial line on AT91SAM9263-EK board i.MX6 USDHC: Use the ESDHC clock mx28evk: Fix boot by adjusting HW_DRAM_CTL29 register i.MX28: Add function to adjust memory parameters mx28evk: Fix PSWITCH key position mx53smd: Remove CONFIG_SYS_I2C_SLAVE definition mx53loco: Remove CONFIG_SYS_I2C_SLAVE definition mx53evk: Remove CONFIG_SYS_I2C_SLAVE definition mx53ard: Remove CONFIG_SYS_I2C_SLAVE definition mx35pdk: Remove CONFIG_SYS_I2C_SLAVE definition imx31_phycore: Remove CONFIG_SYS_I2C_SLAVE definition mx53ard: Remove unused CONFIG_MII_GASKET mx6: Avoid writing to read-only bits in imximage.cfg m28evk: use same notation to alloc the 128kB stack ... Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-07-07add new board vl_ma2scesw@bus-elektronik.de
* add support for board VL+MA2SC * adds vl_ma2sc_config for standard NOR boot configuration * adds vl_ma2sc_ram_config for RAM load configuration Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2012-07-07arm/km: add kmcoge5un board supportHolger Brunck
For u-boot this board is similar to mgcoge3un. But some differences are present. We have a different SDRAM on it and therefore a new SDRAM config file. Additionaly this board has a direct MAC/MAC connection from the kirkwood to a marvell simple switch without a phy inbetween, this needs a new configuration for the mvgbe driver. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: add kmnusa board supportHolger Brunck
This board is similar to portl2, but it has the u-boot environment in a SPI NOR flash and not in an i2c eeprom like portl2 have. Some other details: - IVM EEPROM is at adress: pca9547:70:9 - PCI is enabled - PIGGY4 is connected via MV88E6352 simple switch. There is no phy between the simple switch and the kirkwood. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07Kirkwood: add lschlv2 and lsxhl board supportMichael Walle
This patch adds support for both the Linkstation Live (LS-CHLv2) and Linkstation Pro (LS-XHL) by Buffalo. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: change maintainer for mgcoge3unHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-By: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com>
2012-07-07tegra: Compulab TrimSlice board supportStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: Whistler board supportStephen Warren
Whistler is a highly configurable Tegra evaluation and development board. This change adds support for the following specific configuration: E1120 motherboard E1108 CPU board E1116 PMU board The motherboard configuration switches are set as follows: SW1=0 SW2=0 SW3=5 S1/S2/S3/S4 all on, except S3 7/8 are off. Other combinations of daugher boards may work to varying degrees, but will likely require some SW adjustment. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-06powerpc/mpc85xx:Add BSC9131 RDB SupportPrabhakar Kushwaha
BSC9131RDB is a Freescale reference design board for BSC9131 SoC. BSC9131 SOC is an integrated device that targets Femto base station market. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements BSC9131RDB Overview ----------------- -1Gbyte DDR3 (on board DDR) -128Mbyte 2K page size NAND Flash -256 Kbit M24256 I2C EEPROM -128 Mbit SPI Flash memory -USB-ULPI -eTSEC1: Connected to RGMII PHY -eTSEC2: Connected to RGMII PHY -DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Akhil Goyal <Akhil.Goyal@freescale.com> Signed-off-by: Rajan Srivastava <rajan.srivastava@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2012-06-15MAINTAINERS: cleanup for keymile boardsHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-06-15powerpc/83xx: add kmcoge5ne board supportHolger Brunck
This board is a MPC8360 board. Two flashes are present a NOR flash were u-boot and the u-boot environment is stored and a NAND flash for the application code. This board has 512MB SDRAM. Additionaly we introduce a common km8360.h file and convert kmeter1 to use this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Christian Herzig <christian.herzig@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-05-28sh: Add support for AP-SH4A-4A boardNobuhiro Iwamatsu
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 64MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SH-Ether with Gigabit) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-05-28sh: Add support for r0p7734 boardNobuhiro Iwamatsu
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 128MB DDR2-SDRAM - 32MB NOR Flash memory - Serial console (SCIF) - Ethernet (SH-Ether/SMSC) Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-05-15OMAP4/5: Change omap4_sdp, omap4_panda, omap5_evm maintainerSRICHARAN R
Signed-off-by: R Sricharan <r.sricharan@ti.com> CC: Aneesh V <aneesh@ti.com> CC: Tom Rini <trini@ti.com> Acked-by: Aneesh V <aneesh@ti.com>
2012-05-15kirkwood: add support for Cloud Engines Pogoplug E02David Purdy
This patch adds support for Cloud Engines Pogoplug E02 Information regarding the CE Pogoplug E02 board can be found at: http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray Signed-off-by: Dave Purdy <david.c.purdy@gmail.com> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
2012-05-15kirkwood: add NAS62x0 board supportLuka Perkov
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220. NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports. More information about the boards can be found here: http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036 http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
