path: root/MAINTAINERS
2008-03-18Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
2008-03-15Blackfin: update MAINTAINERS listMike Frysinger
Add maintainer information for the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (3/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add 405GPr based MCU25 board. Global filesNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-22IDS8247: update MAINTAINER entry.Heiko Schocher
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ixpWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-18Merge branch 'master' of git://www.denx.de/git/u-bootShinya Kuribayashi
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-18Add AcTux board supportMichael Schwingen
Hi, The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the files that contain changes for multiple boards, the board-specific files follow as separate patches. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-17ColdFire: MCF547x_8x - Add M5475EVB and M5485EVB supportTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
2008-01-17Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-01-17ppc4xx: Complete DU440 board supportMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-01-16Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-01-16Add support for the MPC837xERDBKim Phillips
MPC837xERDB board support includes: * DDR2 330MHz hardcoded (soldered on the board) * Local Bus NOR Flash * I2C, UART and RTC * eTSEC RGMII (TSEC0 - RTL8211B with MII; * TSEC1 - VSC7385 local bus, hardcoded, requires seperate firmware * load) Signed-off-by: Kevin Lam <kevin.lam@freescale.com> Signed-off-by: Joe D'Abbraccio <joe.d'abbraccio@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add the support for MPC8315ERDB boardDave Liu
The features list: - Boot from NOR Flash - DDR2 266MHz hardcoded configuration - Local bus NOR Flash R/W operation - I2C, UART, MII and RTC - eTSEC0/1 support - PCI host Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-15sh: Add maintainer of MS7720SE to the MAINTAINER fileNobuhiro Iwamatsu
2008-01-12Add MAINTAINERS entries for ids8247, jupiter, municse, sc3 and uc101Wolfgang Denk
boards. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-12Update CHANGELOG and MAINTAINERS files.Wolfgang Denk
2008-01-10mpc83xx: add support for the MPC8360E-RDKAnton Vorontsov
This is MPC8360E based board with: - 256MB fixed SDRAM; - 8MB Intel Strata NOR flash; - StMICRO 64MiB NAND flash; - two 10/100/1000 ethernet ports connected via Broadcom BCM5481 PHYs; - two 10/100 ethernet ports connected via National DP83848 PHYs; - one PCI and one miniPCI slots; - four serial ports (two NS16550-compatible, two UCCs); - four USB ports working through MPC8360E "FHCI" USB controller; - Fujitsu MB86277 graphics controller; - Analog to Digital Converter/Touchscreen controller, AD7843 connected to SPI. Features not supported in this patch are: - StMICRO 64MiB NAND flash (patch sent); - MINT framebuffer initialization (patch is pending); - Fetching production information from the EEPROM via I2C; - FHCI USB; - Two slow UCCs used as RS-485 UARTs. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-09mpc85xx: Add support for ATUM8548 (updated)robert lazarski
Add support for Instituto Atlantico's ATUM8548 board Signed-off-by: robert lazarski <robertlazarski@gmail.com>
2008-01-09mpc85xx: Add support for SBC8548 (updated)Joe Hamman
Add support for Wind River's SBC8548 reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signed-off by: Andy Fleming <afleming@freescale.com>
2008-01-08mpc83xx: update the CREDITS and MAINTAINERSDave Liu
update the CREDITS and MAINTAINERS. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: add MAINTAINER and MAKEALL entries for the mpc837xemdsDave Liu
Add the MAINTAINER and MAKEALL entries for mpc837xemds Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-12-28ppc4xx: Complete PMC440 board supportMatthias Fuchs
This patch brings the PMC440 board configuration file. Finally it enables the PMC440 board support. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-12-27Merge branch 'master' of /home/stefan/git/u-boot/u-boot into for-1.3.2-ver2Stefan Roese
2007-12-27Remove CPCI440 boardMatthias Fuchs
This board never left prototyping state and it became a millstone round my neck. So remove it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-12-27Add support for Korat PPC440EPx boardLarry Johnson
These patches add support for the PPC440EPx-based "Korat" board to U-Boot. They are based primarily on support for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-12-27Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
Conflicts: MAINTAINERS Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-12-17Add ATSTK100[234] to MAINTAINERSHaavard Skinnemoen
Add all the ATSTK1000 daughterboards to MAINTAINERS along with their "mother". Also update the entry for ATSTK1000 to be not only about the AP7000 CPU; it's intended to handle all CPUs in the AT32AP family. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-11-29sh: Add SuperH boards maintainer to MAINTAINERS fileNobuhiro Iwamatsu
Add MS7750SE and MS7722SE's board maintainer to MAINTAINERS file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-10-31ppc4xx: Add initial AMCC Haleakala PPC405EXr eval board supportStefan Roese
The Haleakala is nearly identical with the Kilauea eval board. The only difference is that the 405EXr only supports one EMAC and one PCIe interface. This patch adds support for the Haleakala board by using the identical image for Kilauea and Haleakala. The distinction is done by comparing the PVR. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Makalu 405EX supportStefan Roese
2007-10-31ppc4xx: Add initial AMCC Kilauea 405EX supportStefan Roese
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-coldfireWolfgang Denk
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
2007-08-16Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-16Minor Coding Style fix; Update CHANGELOG file.Wolfgang Denk
2007-08-16Add missing rainier (PPC440GRx) target to MAKEALL and MAINTAINERs filesStefan Roese
2007-08-15mpc83xx: add MAINTAINER and MAKEALL entries for the mpc8323erdbKim Phillips
and reorder the existing 83xx maintainers alpha. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
