path: root/MAINTAINERS
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-12-07MAINTAINERS: Add a pointer to the custodians page.Robert P. J. Day
Since there's no obvious mention, add a brief reference to the custodians page at www.denx.de Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2012-12-05mpc5200: Add a3m071 board supportStefan Roese
This patch adds support for the a3m071 board based on the MPC5200. Signed-off-by: Stefan Roese <sr@denx.de>
2012-11-10Merge git://git.denx.de/u-bootStefano Babic
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-10-30eco5pk: Add new board and default configRaphael Assenat
Signed-off-by: Raphael Assenat <raph@8d.com> [trini: Squash boards.cfg / MAINTAINERS change into main patch] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
2012-10-29tegra: add Colibri T20 board supportLucas Stach
This adds board support for the Toradex Colibri T20 module. Working functions: - SD card boot - USB boot - Network - NAND environment Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-26MX35: add support for woodburn boardStefano Babic
The woodburn board is based on the MX35 SOC. Support for both external (NOR) and internal (SD Card) boot mode are added. It uses the generic SPL framework to implement the internal boot mode. The following peripherals are supported: - Ethernet (FEC) - SD Card - NAND (512 MB) - NOR Flash In the internal boot mode, a simple imximage header is generated to set the address in internal RAM where the SOC must copy the SPL code. The initial setup is then demanded to the SPL itself. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-19Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: drivers/serial/serial_lh7a40x.c Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17powerpc: delete Wind River SBC8560/8540 supportPaul Gortmaker
The sbc8548/60 (both similar, just variations in UART hardware) support has been removed from the linux kernel as of v3.6-rc1~132 so lets also now remove it from the u-boot tree as well. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-10-16h2200: Add support for iPAQ h2200 palmtopŁukasz Dałek
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with Windows CE 4.2 operating system. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-10-15mx6q: Add basic support for mx6qsabreautoFabio Estevam
mx6qsabreauto is a board based on mx6q SoC with the following features: - 2GB of DDR3 - 2 USB ports - 1 HDMI output port - SPI NOR - 2 LVDS LCD ports - Gigabit Ethernet - Camera - eMMC and SD card slot - Multichannel Audio - CAN - SATA - NAND - PCIE - Video Input Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6: Add basic support for mx6qsabresd board.Fabio Estevam
mx6qsabresd is a board based on mx6q SoC with the following features: - 1GB of DDR3 - 1 USB OTG port - 1 HDMI output port - SPI NOR - LVDS panel - Gigabit Ethernet - Camera Connector - eMMC and SD card slot - Audio Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15tegra: Rename Medcom to Medcom-WideThierry Reding
Medcom is the marketing name for an older, PXA-based version of the same device. In order to avoid confusion, rename the Tegra-based version to the new marketing name. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15ppc4xx: Remove ML2 board supportStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Marek Vasut <marex@denx.de>
2012-10-15ppc4xx: Remove IOP480 supportStefan Roese
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2 boards that are not actively maintained, lets remove support for it completely. This way the ppc4xx code will get a bit cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marex@denx.de>
2012-10-15MAINTAINERS: Move dbau1x00 to orphaned.Tom Rini
The former maintainer is no longer interested, move to orphaned. Patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-05MAINTAINERS: Add Tetsuyuki Kobayshi for kzm9gTetsuyuki Kobayashi
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-04Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-10-03Merge remote-tracking branch 'u-boot-marvell/master'Albert ARIBAUD
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
2012-10-03ARM : Add support for MINI2440 (s3c2440).Gabriel Huau
Support of the MINI2440 board from FriendlyARM from an old version of u-boot : http://repo.or.cz/r/u-boot-openmoko/mini2440.git Currently, supporting only boot from NOR. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add supoprt for KMC KZM-A9-GT boardNobuhiro Iwamatsu
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-02TNETV107X: Change tnetv107x_evm maintainerChan-Taek Park
2012-10-02MAINTAINERS: New maintainer for Samsung's Trats development board.Łukasz Majewski
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2012-09-13avr32: add atngw100mkii boardAndreas Bießmann
This patch is derived from an older patch provided by atmel in its buildroot-avr32-v3.0.0.tar.bz2 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2012-09-01Take over the maintainer for sam9g10 and sam9m10g45Bo Shen
As the maintainer for at91sam9g10ek and at91sam9m10g45ek can not reach any more. So I wish to take over the maintainer for sam9g10 and sam9m10g45 Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01efikamx: update MAINTAINERS for Genesi Efika MX systemsMatt Sealey
Update maintainer for "efikamx" and "efikasb" to myself. Signed-off-by: Matt Sealey <matt@genesi-usa.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01ARM: add Raspberry Pi model B board, using BCM2835 SoCStephen Warren
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM, contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors. For more details, see http://www.raspberrypi.org/. Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack relocation to top of RAM) extracted from work by: Oleksandr Tymoshenko <gonzo@bluezbox.com>. GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Tom Rini <trini@ti.com>
2012-09-01snowball: Add support for ux500 based snowball boardMathieu J. Poirier
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Tom Rini <trini@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Conflicts: drivers/gpio/Makefile
2012-09-01MX28: Add SchulerControl SC_SPS_1 platformMarek Vasut
This i.MX28 platform supports the following: * 2x FEC ethernet * USB on USBH0 * I2C EEPROM * SPI NVRAM * LEDs Signed-off-by: Marek Vasut <marex@denx.de>
2012-09-01Add support for Bluegiga APX4 Development KitVeli-Pekka Peltola
This adds support for Bluegiga APX4 Development Kit. It is built around Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC, RTC and USB. APX4 has only one ethernet port. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01at91: Add support for taskit AT91SAM9G20 boards.Markus Hubig
This adds support for the AT91SAM9G20 boards by taskit GmbH. Both boards, Stamp9G20 and PortuxG20, are integrated in one file. PortuxG20 is basically a SBC built around the Stamp9G20. Signed-off-by: Markus Hubig <mhubig@imko.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
2012-09-01MAINTAINERS: fix Andreas Bießmann AVR32 entryAndreas Bießmann
The grasshopper board is a avr32 based device and belongs therefore to the avr32 section. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01MAINTAINERS: fix entry of Ilko IlievAndreas Bießmann
These boards have ARM cores, move to the ARM section. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
