https://source.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2022.10
cpu:
- Add driver for microblaze cpu
net:
- Add support for DM_ETH_PHY to AXI emac and emaclite
xilinx:
- Switch platforms to DM_ETH_PHY
- DT chagnes in ZynqMP and Zynq
- Enable support for SquashFS
zynqmp:
- Add support for KR260 boards
- Move BSS from address 0
- Move platform identification from board code to soc driver
- Improve zynqmp_psu_init_minimize
versal:
- Enable loading app at EL1
serial:
- Setup default address and clock rates for DEBUG uarts
pinctrl:
- Add support for tri state and output enable properties
relocate-rela:
- Clean relocate-rela implementation for ARM64
- Add support for Microblaze
microblaze:
- Add support for runtime relocation
- Rework cache handling (wiring, Kconfig) based on cpuinfo
- Remove interrupt support
timer:
- Extract axi timer driver from Microblaze to generic location
Move axi timer driver from Microblaze to generic location.
Origin implementation was irq based with counting down timer.
CONFIG_TIMER drivers are designed differently that timer is free running up
timer with automatic reload without any interrupt.
Information about clock rates are find out in timer_pre_probe() that's why
there is no need to get any additional information from DT in the driver
itself (only register offset).
Signed-off-by: Michal Simek <michal.simek@amd.com>
Tested-by: Ovidiu Panait <ovidiu.panait@windriver.com>
Link: https://lore.kernel.org/r/6c12fc86bbc1f17d05c25018862e7b7b03346b36.1654684731.git.michal.simek@amd.com
Adds random number generator driver using Arm SMCCC TRNG interface to
get entropy bytes from secure monitor. The driver registers as an
Arm SMCCC feature driver to allow PSCI driver to bind a device for
when secure monitor exposes RNG support from Arm SMCCC TRNG interface.
Cc: Sughosh Ganu <sughosh.ganu@linaro.org>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Create a section in MAINTAINERS for the GXP HPE architecture
Signed-off-by: Nick Hawkins <nick.hawkins@hpe.com>
https://source.denx.de/u-boot/custodians/u-boot-stm into next
- Add STM32MP13 SoCs support with associated board STM32M135F-DK
- Correct livetree support in stm32mp1 boards
- Activate livetree for stm32mp15 DHSOM boards
This adds a driver for the Security Fuse Processor (SFP) present on
LS1012A, LS1021A, LS1043A, and LS1046A processors. It holds the
Super-Root Key (SRK), One-Time-Programmable Master Key (OTPMK), and
other "security" related fuses. Similar devices (sharing the same name)
are present on other processors, but for the moment this just supports
the LS2 variants.
The mirror registers are loaded during power-on reset. All mirror
registers must be programmed or read at once. Because of this, `fuse
prog` will program all fuses, even though only one might be specified.
To prevent accidentally burning through all your fuse programming cycles
with something like `fuse prog 0 0 A B C D`, we limit ourselves to one
programming cycle per reset. Fuses are numbered based on their address.
The fuse at 0x1e80200 is 0, the fuse at 0x1e80204 is 1, etc.
The TA_PROG_SFP supply must be enabled when programming fuses, but must
be disabled when reading them. Typically this supply is enabled by
inserting a jumper or by setting a register in the board's FPGA. I've
also added support for using a regulator. This could be helpful for
automatically issuing the FPGA write, or for toggling a GPIO controlling
the supply.
I suggest using the following procedure for programming:
1. Override the fuses you wish to program
=> fuse override 0 2 A B C D
2. Inspect the values and ensure that they are what you expect
=> fuse sense 0 2 4
3. Enable TA_PROG_SFP
4. Issue a program command using OSPR0 as a dummy. Since it contains the
write-protect bit you will usually want to write it last anyway.
=> fuse prog 0 0 0
5. Disable TA_PROG_SFP
6. Read back the fuses and ensure they are correct
=> fuse read 0 2 4
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
Add a directory in drivers/clk to regroup the clock drivers for all
STM32 Soc with CONFIG_ARCH_STM32 (MCUs with cortex M) or
CONFIG_ARCH_STM32MP (MPUs with cortex A).
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Grzegorz Szymaszek <gszymaszek@short.pl>
Acked-by: Sean Anderson <seanga2@gmail.com>
Change-Id: I955af307963f732167396f0157a30cf2fc91f150
This is the initial support for Broadcom's ARM-based 47622 SOC.
In this change, our first SOC is an armv7 platform called 47622. The
initial support includes a bare-bone implementation and dts with ARM
PL011 uart.
The SOC-specific code resides in arch/arm/mach-bcmbca/<soc> and board
related code is in board/broadcom/bcmba.
The u-boot image can be loaded from flash or network to the entry
point address in the memory and boot from there.
Signed-off-by: William Zhang <william.zhang@broadcom.com>
Signed-off-by: Kursad Oney <kursad.oney@broadcom.com>
Signed-off-by: Anand Gore <anand.gore@broadcom.com>
Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
This adds support for "nvmem cells" as seen in Linux. The nvmem device
class in Linux is used for various assorted ROMs and EEPROMs. In this
sense, it is similar to UCLASS_MISC, but also includes
UCLASS_I2C_EEPROM, UCLASS_RTC, and UCLASS_MTD. New drivers corresponding
to a Linux-style nvmem device should be implemented as one of the
previously-mentioned uclasses. The nvmem API acts as a compatibility
layer to adapt the (slightly different) APIs of these uclasses. It also
handles the lookup of nvmem cells.
While nvmem devices can be accessed directly, they are most often used
by reading/writing contiguous values called "cells". Cells typically
hold information like calibration, versions, or configuration (such as
mac addresses).
nvmem devices can specify "cells" in their device tree:
qfprom: eeprom@700000 {
#address-cells = <1>;
#size-cells = <1>;
reg = <0x00700000 0x100000>;
tsens_calibration: calib@404 {
reg = <0x404 0x10>;
which can then be referenced like:
tsens {
nvmem-cells = <&tsens_calibration>;
nvmem-cell-names = "calibration";
The tsens driver could then read the calibration value like:
struct nvmem_cell cal_cell;
u8 cal[16];
nvmem_cell_get_by_name(dev, "calibration", &cal_cell);
nvmem_cell_read(&cal_cell, cal, sizeof(cal));
Because nvmem devices are not all of the same uclass, supported uclasses
must register a nvmem_interface struct. This allows CONFIG_NVMEM to be
enabled without depending on specific uclasses. At the moment,
nvmem_interface is very bare-bones, and assumes that no initialization
is necessary. However, this could be amended in the future.
Although I2C_EEPROM and MISC are quite similar (and could likely be
unified), they present different read/write function signatures. To
abstract over this, NVMEM uses the same read/write signature as Linux.
In particular, short read/writes are not allowed, which is allowed by
MISC.
The functionality implemented by nvmem cells is very similar to that
provided by i2c_eeprom_partition. "fixed-partition"s for eeproms does
not seem to have made its way into Linux or into any device tree other
than sandbox. It is possible that with the introduction of this API it
would be possible to remove it.
Add the rest of the ASPEED drivers that are in tree. Most are obvious,
except for ftgmac100 which matches the register layout used in the
ASPEED SoC.
I am the Linux maintainer for the ASPEED kernel port, and help maintain
the fork of u-boot used for OpenBMC, so add myself as a reviewer so I
can stay informed about u-boot changes.
Signed-off-by: Joel Stanley <joel@jms.id.au>
Reviewed-by: Chia-Wei Wang <chiawei_wang@aspeedtech.com>
As removal of nds32 has been ack'd for the Linux kernel, remove support
here as well.
Cc: Rick Chen <rick@andestech.com>
Reviewed-by: Rick Chen <rick@andestech.com>
To quote the author:
The bootflow feature provide a built-in way for U-Boot to automatically
boot an Operating System without custom scripting and other customisation.
This is called 'standard boot' since it provides a standard way for
U-Boot to boot a distro, without scripting.
It introduces the following concepts:
- bootdev - a device which can hold a distro
- bootmeth - a method to scan a bootdev to find bootflows (owned by
U-Boot)
- bootflow - a description of how to boot (owned by the distro)
This series provides an implementation of these, enabled to scan for
bootflows from MMC, USB and Ethernet. It supports the existing distro
boot as well as the EFI loader flow (bootefi/bootmgr). It works
similiarly to the existing script-based approach, but is native to
U-Boot.
With this we can boot on a Raspberry Pi 3 with just one command:
bootflow scan -lb
which means to scan, listing (-l) each bootflow and trying to boot each
one (-b). The final patch shows this.
With a standard way to identify boot devices, booting become easier. It
also should be possible to support U-Boot scripts, for backwards
compatibility only.
The design is described in these two documents:
https://drive.google.com/file/d/1ggW0KJpUOR__vBkj3l61L2dav4ZkNC12/view?usp=sharing
https://drive.google.com/file/d/1kTrflO9vvGlKp-ZH_jlgb9TY3WYG6FF9/view?usp=sharing
I ended up learning most of binman internals while trying to add a few
features to it, and I recently started reviewing binman series that
would not affect me personally. I'll keep working on it and try to do
more reviews.
Add myself as a maintainer for binman.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Acked-by: Tom Rini <trini@konsulko.com>
Add documentation for this feature, including the commands and full
devicetree bindings.
Add a set of combined tests for the bootdev, bootflow and bootmeth
commands, along with associated functionality.
Expand the sandbox console-recording limit so that these can work.
These tests rely on a filesystem script which is not yet added to the
Python tests. It is included here as a shell script.
Add a bootdev driver for Ethernet. It can use the PXE boot mechanism to
locate a file, added later.
Add a bootdev driver for MMC. It mostly just calls the bootdev helper
function.
Add a function to obtain the block device for an MMC controller.
Fix up the comment for mmc_get_blk_desc() while we are here.
Add a bootmeth driver which handles distro boot from a disk, so we can
boot a bootflow using this commonly used mechanism.
In effect, this provides the same functionality as the 'sysboot' command
and shares the same code. But the interface into it is via a bootmeth.
For now this requires the 'pxe' command be enabled. Future work may tidy
this up so that it can be used without CONFIG_CMDLINE being enabled.
Add a 'bootdev' command to handle listing and selection of bootdevs.
Disable standard boot for a few boards which otherwise run out of space.
Add support for bootflows, including maintaining a list of them and
iterating to find them.
A bootmeth is a method of locating an operating system. For now, just
add the uclass itself. Drivers for particular bootmeths are added later.
If no bootmeths devices are included in the devicetree, create them
automatically. This avoids the need for boilerplate in the devicetree
files.
A 'bootdev' is a device which can be used to boot an operating system.
It is a child of the media device (e.g. MMC) which handles reading files
from that device, such as a bootflow file.
Add a uclass for bootdev and the various helpers needed to make it
work. Also add a binding file, empty for now.
The 'bootstd' device provides the central information about U-Boot
standard boot.
Add a uclass for bootstd and the various helpers needed to make it
work. Also add a binding file.
A bootflow encapsulates the process used to boot an operating system.
It typically has a control file (such as extlinux.conf) and information
about which 'bootdev' it came from.
Add the header file for this first, since it is needed by all other
files.
Xilinx has been acquired by AMD that's why emails should be also updated.
The patch is updating .mailmap file and also MAINTAINERS files as was done
by commit 5cd1ecb99490 ("ppc: qemu: Update MAINTAINERS for correct email
address").
The rest of my emails are not going to change.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20220413
i.MX patches for 2022.07
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/11710
Add a driver for the Gateworks System Controller used on Gateworks boards
which provides a boot watchdog, power control, temperature monitor,
and voltage ADCs.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
updated CAAM driver files maintainer.
Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com>
Add a driver which allows to use of LEDs connected
to PWM (Linux compatible).
MAINTAINERS: add i.vozvakhov as a maintainer of leds-pwm
C(required during new functionality adding).
Signed-off-by: Ivan Vozvakhov <i.vozvakhov@corp.mail.ru>
Add driver for OP-TEE based Random Number Generator on ARM SoCs
where hardware entropy sources are not accessible to normal world
and the RNG service is provided by a HWRNG Trusted Application (TA).
This driver is based on the linux driver: char/hw_random/optee-rng.c
Xilinx changes for v2022.07-rc1 v2
xilinx:
- Allow booting bigger kernels till 100MB
zynqmp:
- DT updates (reset IDs)
- Remove unneeded low level uart initialization from psu_init*
- Enable PWM features
- Add support for 1EG device
serial_zynq:
- Change fifo behavior in DEBUG mode
zynq_sdhci:
- Fix BASECLK setting calculation
clk_zynqmp:
- Add support for showing video clock
gpio:
- Update slg driver to handle DT flags
net:
- Update ethernet_id code to support also DM_ETH_PHY
- Add support for DM_ETH_PHY in gem driver
- Enable dynamic mode for SGMII config in gem driver
pwm:
- Add driver for cadence PWM
versal:
- Add support for reserved memory
firmware:
- Handle PD enabling for SPL
- Add support for IOUSLCR SGMII configurations
include:
- Sync phy.h with Linux
- Update xilinx power domain dt binding headers
A big part is the DM pinctrl driver, which allows us to get rid of quite
some custom pinmux code and make the whole port much more robust. Many
thanks to Samuel for that nice contribution! There are some more or less
cosmetic warnings about missing clocks right now, I will send the trivial
fixes for that later.
Another big chunk is the mkimage upgrade, which adds RISC-V and TOC0
(secure images) support. Both features are unused at the moment, but I
have an always-secure board that will use that once the DT lands in the
kernel.
On top of those big things we have some smaller fixes, improving the
I2C DM support, fixing some H6/H616 early clock setup and improving the
eMMC boot partition support.
The gitlab CI completed successfully, including the build test for all
161 sunxi boards. I also boot tested on a A64, A20, H3, H6, and F1C100
board. USB, SD card, eMMC, and Ethernet all work there (where applicable).
Most Allwinner sunxi SoCs have separate boot ROMs in non-secure and
secure mode. The "non-secure" or "normal" boot ROM (NBROM) uses the
existing sunxi_egon image type. The secure boot ROM (SBROM) uses a
completely different image type, known as TOC0.
A TOC0 image is composed of a header and two or more items. One item
is the firmware binary. The others form a chain linking the firmware
signature to the root-of-trust public key (ROTPK), which has its hash
burned in the SoC's eFuses. Signatures are made using RSA-2048 + SHA256.
The pseudo-ASN.1 structure is manually assembled; this is done to work
around bugs/quirks in the boot ROM, which vary between SoCs. This TOC0
implementation has been verified to work with the A50, A64, H5, H6,
and H616 SBROMs, and it may work with other SoCs.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Acked-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Create a do-nothing driver for each sunxi pin controller variant.
Since only one driver can automatically bind to a DT node, since the
GPIO driver already requires a manual binding process, and since the
pinctrl driver needs access to some of the same information, refactor
the GPIO driver to be bound by the pinctrl driver. This commit should
cause no functional change.
https://source.denx.de/u-boot/custodians/u-boot-at91 into next
First set of u-boot-at91 features for the 2022.07 cycle:
This feature set includes the new driver for the Atmel TCB timer,
alignment in DT for sama7g5 and sama7g5ek board, one Kconfig conversion
for external reset, and the usage of Galois tables from ROM for sama5d2
device.
These files are spread all over the tree, so just use a regex. Orphaned
for now, since this is more of a "one-off" series. Though I'll be happy
to review patches.
Add a driver for the timer counter block that can be found on sama5d2.
This driver will be used when booting under OP-TEE since the pit timer
which is part of the SYSC is secured. Channel 1 & 2 are configured to
be chained together which allows to have a 64bits counter.
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Signed-off-by: Clément Léger <clement.leger@bootlin.com>
TTC has three modes of operations. Timer, PWM and input counters.
There is already driver for timer under CADENCE_TTC_TIMER which is used for
ZynqMP R5 configuration.
This driver is targeting PWM which is for example configuration which can
be used for fan control.
The driver has been tested on Xilinx Kria SOM platform where fan is
connected to one PL pin. When TTC output is connected via EMIO to PL pin
TTC pwm can be configured and tested for example like this:
pwm config 0 0 10000 1200
pwm enable 0 0
pwm config 0 0 10000 1400
pwm config 0 0 10000 1600
Reviewed-by: Sean Anderson <sean.anderson@seco.com>
Link: https://lore.kernel.org/r/915a662ddb88f7a958ca1f307e8fea59af9d7feb.1634303847.git.michal.simek@xilinx.com
Prepare v2022.04-rc5
The current files and directories with wildcard patterns for
Rockchip patches in MAINTAINERS is not always complete.
Add the regex for DT related files and a generic regex for
catching some other forgotten cases, so that the maintainers
receive all Rockchip related patches.
Signed-off-by: Johan Jonker <jbx6244@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
microblaze:
xilinx:
- Update FRU code with MAC reading
zynqmp:
- Remove double AMS setting
- DT updates (mostly for SOMs)
- Add support for zcu106 rev 1.0
zynq:
- Update nand binding
nand:
- Aligned zynq_nand to upstream DT binding
net:
- Add support for ethernet-phy-id
mmc:
- Workaround CD in zynq_sdhci driver also for ZynqMP
- Add support for dynamic/run-time SD config for SOMs
gpio:
- Add driver for slg7xl45106
firmware:
- Add support for dynamic SD config
power-domain:
- Update zynqmp driver with the latest firmware
video:
- Add skeleton driver for DP and DPDMA
i2c:
- Fix i2c to work with QEMU
pinctrl:
- Add driver for zynqmp pinctrl driver
Add Python scripts to test 'ls' and 'load' commands, as well as
test related filesystem functions.
Signed-off-by: Huang Jianan <jnhuang95@gmail.com>
Add 'ls' and 'load' commands.
This patch mainly deals with uncompressed files.
"kendryte" is the marketing name for the K210 RISC-V SoC produced by
Canaan Inc. Rather than "kendryte,k210", use the usual "canaan,k210"
vendor,SoC compatibility string format in the device tree files and
use the SoC name for file names.
With these changes, the device tree files are more in sync with the
Linux kernel DTS and drivers, making uboot device tree usable by the
kernel.
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
Signed-off-by: Niklas Cassel <niklas.cassel@wdc.com>
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Prepare v2022.04-rc4
Add pinctrl driver for Xilinx ZynqMP SOC. This driver is compatible with
linux device tree parameters for configuring pinmux and pinconf.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/2d7eefa83c8c0129f7243a25de56a289e948f6c6.1645626183.git.michal.simek@xilinx.com
For debugging and dicoverability it is useful to be able to see a list of
each event spy in a U-Boot ELF file. Add a script which shows this, along
with the event type and the source location. This makes events a little
easier to use than weak functions, for example.
Add a basic sandbox test as well. We could provide a test for other
boards, but for now, few use events.
Add a command to show the available events.
Add a test for event registration and activation.
