path: root/MAINTAINERS
2017-07-08MAINTAINERS: drop bcm283x/rpi maintainershipStephen Warren
It's been a while since I've touched U-Boot on the Raspberry Pi and other things have been taking my time. Drop my maintainership for this port. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-04efi_loader: Add efi-next git tree to MAINTAINERS fileAlexander Graf
The efi-next tree lives on github, not the usual denx git. Reflect this in the MAINTAINERS file so that people can find it. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-06-23MAINTAINERS, git-mailrc: update the maintainer for rockchipPhilipp Tomsich
Adding myself to MAINTAINERS and git-mailrc for the rockchip sub-architecture. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-21MAINTAINERS: Add myself as i.MX co-maintainerFabio Estevam
I would like to help Stefano Babic as a co-maintainer of U-Boot i.MX. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12MAINTAINERS: mpc83xx: Add new custodianmario.six@gdsys.cc
Add myself as mpc83xx custodian.
2017-06-07MAINTAINERS: rockchip: add board/rockchip as maintained entryKever Yang
Directory board/rockchip/ are all boards for Rockchip SoCs, so add it to maintained entry. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-27MAINTAINERS: Update for Keystone2 secure devicesLokesh Vutla
Update Keystone2 secure device configs under "TI SYSTEM SECURITY". Without this buildman keeps complaining about the status of these boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Andrew F. Davis <afd@ti.com>
2017-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-12MAINTAINERS: Fix ARM FREESCALE IMX filesJagan Teki
- Remove arch/arm/cpu/arm926ejs/imx/ which is not available - arch/arm/cpu/imx-common/ => arch/arm/imx-common/ Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-04-07sunxi: Add boards/sunxi and arch/arm/mach-sunxi to sunxi MAINTAINERS entryChen-Yu Tsai
Recently some sunxi related code was moved to arch/arm/mach-sunxi, but the MAINTAINERS entry was not updated to reflect this. Add this, and the board level boards/sunxi directory to our entry. While at it, also update its status, to reflect the current active maintainership. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05OpenRISC: RemoveTom Rini
The OpenRISC architecture is currently unmaintained, remove. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-14arm: Add support for STMicroelectronics STiH410 socPatrice Chotard
The STiH410 is an advanced multi-HD AVC processor with 3D graphics acceleration and 1.5-GHz ARM Cortex-A9 SMP CPU part of the STiH407 family. It has wide connectivity including USB 3.0, PCI-e, SATA and gigabit ethernet. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-01-28defconfig: Add a config for AM335x High Security EVMAndrew F. Davis
Add a new defconfig file for the AM335x High Security EVM. This config is specific for the case of memory device booting. Memory device booting is handled separatly from peripheral booting on HS devices as the load address changes. This defconfig is the same as for the non-secure part, except for: CONFIG_TI_SECURE_DEVICE option set to 'y' CONFIG_ISW_ENTRY_ADDR updated for secure images. CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_USE_TINY_PRINTF option set to 'y' to reduce SPL size CONFIG_SPL_SYS_MALLOC_SIMPLE set to 'y' to reduce SPL size Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-20MAINTAINERS: DFU: Change e-mail address of DFU maintanierLukasz Majewski
Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-01-14MAINTAINERS: Add maintainer for TI security related filesAndrew F. Davis
Changes involving High-Security boards should be CC'd for additional assessment of the security implications. Signed-off-by: Andrew F. Davis <afd@ti.com>
2016-12-27MAINTAINERS, git-mailrc: update the Power maintainerJaehoon Chung
Przemyslaw didn't maintain the PMIC anymore. Update the pmic maintainer from Przeymyslaw to me. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-12MAINTAINERS: DFU: Change e-mail address for DFU maintainerLukasz Majewski
Despite I leave Samsung by the end of the year, I'm going to maintain DFU in u-boot. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2016-12-12MAINTAINERS: ONENAND: MTD: Mark Samsung's OneNAND as orphanedLukasz Majewski
Since I leave Samsung by the end of the year, I will not have access to OneNAND devices anymore. Hence the custodian position has been marked as "Orphaned". Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2016-12-06MAINTAINERS: Fix ALTERA SOCFPGA FilesJagan Teki
Replace arch/arm/cpu/armv7/socfpga/ path with arch/arm/mach-socfpga/ and removed board file path since board/altera has different boards with relevant board maintainers. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Jagan Teki <jagan@openedev.com>
2016-11-25MAINTAINERS: Fix syntax and update filename for FDTAndreas Färber
Let get_maintainers.pl pick up the new cmd/fdt.c. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Andreas Färber <afaerber@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-22MAINTAINERS: SUNXI: Update maintainershipJagan Teki
Add Jagan and Maxime as Maintainers for SUNXI Signed-off-by: Jagan Teki <jagan@openedev.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-11-14MAINTAINERS: mark sunxi status as OrphanHans de Goede
Ian has not had any time for sunxi for some time now and I'm in the same situation now, so I'm stepping down as sunxi custodian and marking the sunxi support as Orphan. Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-10-29MAINTAINERS: Update Jagan's emailJagan Teki
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17MAINTAINERS: Add maintainer entry of RMOBILENobuhiro Iwamatsu
Add MAINTAINERS entry. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-02MAINTAINERS, git-mailrc: Update the mmc maintainerJaehoon Chung
Update the mmc maintainer from Pantelis to me. Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-28MAINTAINERS: i.MX: Add board/freescale/*mx* pathFabio Estevam
Pass the board/freescale/*mx*/ path as files maintained by Stefano Babic. While this is not ideal and does not cover all the i.MX board cases, it gives at least a better hint for the /scripts/get_maintainer.pl tool. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-04-25MAINTAINERS: Add myself as maintainer for hikeyPeter Griffin
This patch adds myself as maintainer for the hikey U-Boot port. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11rpi: remove redundant board filesStephen Warren
Now that rpi_*defconfig and Kconfig (rather than the config header file) provide the identity of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header. The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway. While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too. Partially-suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01MAINTAINERS: Update Scott Wood's email addressScott Wood
Freescale is now NXP. I still work there, but I won't be using their mail system for U-Boot development. Signed-off-by: Scott Wood <oss@buserror.net>
2016-04-01Add myself as Snapdragon and SPMI maintainerMateusz Kulikowski
- Update MAINTAINERS - Update git-mailrc Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add MAINTAINERS entryAlexander Graf
Now that everything's in place, let's add myself as the maintainer for the efi payload support. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-24MAINTAINERS: Update no longer valid maintainers' statusBin Meng
The following maintainers' email addresses are no longer valid. vipin.kumar@st.com martin.krause@tq-systems.de kim.phillips@freescale.com fgretief@spaceteq.co.za Update status of the components they used to maintain to be: S: Orphaned (Since 2016-02) Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-15MAINTAINERS: add entry for RockchipMasahiro Yamada
Rockchip has its own git repository maintained by Simon. Document this. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-14MAINTAINERS: Update Marvell custodianshipStefan Roese
Add myself as custodian for the Marvell git repository. Additionally, add the mach-mvebu directory to the list of files / directories. And add Armada XP & Armada 38x to the title (not only kirkwood). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Tom Rini <trini@konsulko.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <luka.perkov@sartura.hr>
2016-01-08MAINTAINERS, .mailmap: Update my email addressYork Sun
Change from yorksun@freescale.com to york.sun@nxp.com. Signed-off-by: York Sun <york.sun@nxp.com>
2015-12-23ARM: uniphier: rename rest of defconfig filesMasahiro Yamada
Rename rest of defconfig files of UniPhier SoC family to have the prefix uniphier_. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfigMasahiro Yamada
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-30arm: s5pc1xx: move SoC to mach-s5pc1xxMinkyu Kang
move arm/arm/cpu/armv7/s5pc1xx to arch/arm/mach-s5pc1xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-13sparc: Update the maintainer for SPARC architectureFrancois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-05-16MAINTAINERS, git-mailrc: Update Jagan's name and e-mailJagan Teki
Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-08Remove non-working address from MAINTAINERPavel Machek
I checked with Detlev, and sadly removing that maintainers entry is right thing to do. Signed-off-by: Pavel Machek <pavel@denx.de>
2015-04-20Update MAINTAINERS and git-mailrc for netJoe Hershberger
Update to my corporate email and make the supported filter and aliases more accurate. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
