For u-boot this board is similar to mgcoge3un. But some differences
are present. We have a different SDRAM on it and therefore a new
SDRAM config file. Additionaly this board has a direct MAC/MAC
connection from the kirkwood to a marvell simple switch without a
phy inbetween, this needs a new configuration for the mvgbe driver.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
This board is similar to portl2, but it has the u-boot environment
in a SPI NOR flash and not in an i2c eeprom like portl2 have.
Some other details:
- IVM EEPROM is at adress: pca9547:70:9
- PCI is enabled
- PIGGY4 is connected via MV88E6352 simple switch. There is no phy
between the simple switch and the kirkwood.
This patch adds support for both the Linkstation Live (LS-CHLv2) and
Linkstation Pro (LS-XHL) by Buffalo.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Heiko Schocher <hs@denx.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Whistler is a highly configurable Tegra evaluation and development board.
This change adds support for the following specific configuration:
E1120 motherboard
E1108 CPU board
E1116 PMU board
The motherboard configuration switches are set as follows:
SW1=0 SW2=0 SW3=5
S1/S2/S3/S4 all on, except S3 7/8 are off.
Other combinations of daugher boards may work to varying degrees, but will
likely require some SW adjustment.
cc: Kim Phillips <kim.phillips@freescale.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Heiko Schocher <hs@denx.de>
This board is a MPC8360 board. Two flashes are present
a NOR flash were u-boot and the u-boot environment is stored
and a NAND flash for the application code. This board has 512MB
SDRAM.
Additionaly we introduce a common km8360.h file and convert kmeter1 to
use this.
Signed-off-by: Christian Herzig <christian.herzig@keymile.com>
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB,
Ethernet, and more.
This patch supports the following functions:
- 64MB DDR2-SDRAM
- 16MB NOR Flash memory
- Serial console (SCIF)
- Ethernet (SH-Ether with Gigabit)
- I2C
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB,
Ethernet, and more.
- 128MB DDR2-SDRAM
- 32MB NOR Flash memory
- Ethernet (SH-Ether/SMSC)
Signed-off-by: R Sricharan <r.sricharan@ti.com>
CC: Aneesh V <aneesh@ti.com>
CC: Tom Rini <trini@ti.com>
Acked-by: Aneesh V <aneesh@ti.com>
This patch adds support for Cloud Engines Pogoplug E02
Information regarding the CE Pogoplug E02 board can be found at:
http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray
Signed-off-by: Dave Purdy <david.c.purdy@gmail.com>
Cc: prafulla@marvell.com
Cc: albert.u.boot@aribaud.net
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220.
NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports.
More information about the boards can be found here:
http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036
http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Signed-off-by: Gerald Kerma <dreagle@doukki.net>
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
This change adds a basic support for Embest/Timll DevKit3250 board,
NOR and UART are the only supported peripherals for a moment. The board
doesn't require low-level init, because the initial SDRAM and GPIO
configuration is performed during kickstart bootloader execution.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
board:
Add config file of board adp-ag102
Add adp-ag102 into boards.cfg
Add adp-ag102 into MAINTAINERS
doc:
add README of ag102
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
After removing omap1610inn for not building, move omap1510inn to
orphaned. Also update boards.cfg to note it's part of the 'omap' SoC to
make sure the board is built more often and future breakage noticed
quicker.
The CS_AUTOBOOT configurations have been broken for a long time.
Kshitij Gupta is no longer at TI making these broken and orphaned
boards, so remove.
Cc: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Dirk Behme<dirk.behme@gmail.com>
* 'master' of git://git.denx.de/u-boot-blackfin:
Blackfin: pata_bfin: fix printf warning
Blackfin: bfin_nand: mark local func static
linkage.h: move from blackfin to common includes
Blackfin: br4: new board port
Blackfin: add in/out le32 variants
post: add blackfin to the post_time_ms list
Blackfin: bf537-stamp: drop board reset workaround
Blackfin: pr1: new board port
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI
board based on Blackfin BF537 CPU.
Signed-off-by: Dimitar Penev <dpn@switchfin.org>
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX.
This board is Blackfin BF537 based. The schematics are not fully opened.
This patch adds support for the Calimain board from
OMICRON electronics GmbH. The board features a Texas Instruments AM1808
SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and
CS3.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch adds support for the HTKW mcx AM3517-based board.
Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both
NAND and MMC SPLs are supported.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
CC: Tom Rini <tom.rini@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
The mt_ventoux board is a custom board using
the Technexion TAM3517 module.
The patch fixes also the mtdparts variable in the
TAM3517 common configuration file.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Igor Grinberg <grinberg@compulab.co.il>
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support for Samsung TRATS board
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
This patch adds support for D-Link DNS-325 ShareCenter NAS.
Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net>
Tricorder is a board which is very similar to the Devkit8000. It
is designed as a base platform for further medical devices.
www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html
Signed-off-by: Thomas Weber <weber@corscience.de>
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook
derived from the NVIDIA Tegra Harmony reference board. It ships with
Android, but is often repurposed to run Linux. This patch adds just enough
support to get a U-Boot serial console, and the ability access built-in
eMMC and the external SD slot.
v2:
* Rebased on latest HEAD, incorporated changes made to other board files.
* Moved board files from board/nvidia to board/compal.
* Switched to correct odmdata value. This required add the previous patch
to fix U-Boot's interpretation of the odmdata RAM size field.
* Removed nvmem= from default Linux kernel command-line; no drivers use the
reserved memory yet, so there's no point reserving it.
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo
reference boards. It assumes U-boot is loaded to SDRAM with the
help of another small bootloader (x-load) running from SRAM.
Signed-off-by: Peter Barada <peter.barada@logicpd.com>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Add the initial support for Freescale i.MX6Q Sabre Lite board
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
CC: Eric Nelson <eric.nelson@boundarydevices.com>
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through
the FEC interface.
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
This board is similar to our tuxx1 target. But on this board there
is only one application specific chip select configured.
Acked-by: Heiko Schocher <hs@denx.de>
These boards are from a u-boot point of view identical. So collect
the two headerfiles to one, to decrease maintenance.
The Medcom is a 16:9 15" terminal that is used for patient infotainment
in hospitals.
Changes in v3:
* Remove unused implementation of gpio_config_uart().
* Implement MMC/SD card detection.
* Drop board_mmc_getcd() which is now implemented by common Tegra2
code.
* Add MAINTAINERS entry.
Changes in v2:
* No longer override the default CONFIG_SYS_TEXT_BASE setting.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The Plutux is a set-top box device based on the Tamonten processor
module. It can be connected to a display via an HDMI output.
Changes in v3:
code.
Changes in v2:
The twister board is a development board using
the TAM3517 SOM.
Support for NAND, 2 Ethernet (EMAC and SMC911),
USB (EHCI_OMAP).
CC: Tapani Utrianen <tapani@technexion.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
* 'master' of git://git.denx.de/u-boot-arm:
M28: Cleanup memsize.o OOT build
i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28
M28: Fix typo
M28: Document that units has to be set to sectors on SD bootcard
i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board
i.mx: mxc_gpio: add the i.mx6q support
i.mx: add the initial support for freescale i.MX6Q processor
i.mx: introduce the armv7/imx-common folder
S5PC2XX: Rename S5pc2XX to exynos
tegra2: Don't use board pointer before it is set up
tegra2: Remove unneeded 'dynamic ram size' message
tegra2: Remove unused low-level Tegra2 UART code
tegra2: Remove unneeded config option
tegra2: Remove unneeded boot code
tegra2: Enable instruction cache
arm: Move CP15 init out of cpu_init_crit()
tegra2: Simplify tegra_start() boot path
tegra2: Add arch_cpu_init() to fire up Cortex-A9
tegra2: Use new GPIO APIs in gpio_config_uart()
tegra2: Add support for Ventana
tegra2: Modify MMC driver to handle power and cd GPIOs
tegra2: Move board_mmc_init into board files
Add the initial support for Freescale i.MX6Q Armadillo2 board
Support: MMC boot from slot 0/1, debug UART(UART4), usdhc.
There is two MMC slots on the boards:
mmc dev 0 -> connect USDHC3 -> the lower slot on the board,
mmc dev 1 -> connect USDHC4 -> the upper slot on the board,
Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15
based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15
based SoC's will be sub-classified as Exynos4 and Exynos5 respectively.
In order to better adapt and reuse code across various upcoming Samsung Exynos
based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in
this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix
are renamed as exynos4/EXYNOS4.
Ventana is a board which is very similar to Seaboard. Support it by
re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals.
v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets.
v6: Make gpio_config_uart_seaboard() static.
v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so
he asked me to add myself for this board.
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis
with 3 independent TEMPEST zones. Two independent P2020 computers may
be found inside each zone. Complete hardware support is included.
High-level hardware overview:
* DO-160 certified for passenger aircraft (noncritical)
* TEMPEST ceritified for RED/BLACK separation
* 3 zones per chassis, 2 computers per zone (total of 6)
* Dual-core 1.066GHz P2020 per computer
* One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB)
* Removable 80GB or 160GB Intel X18-M SSD per computer
* Front-accessible dual-port E1000E per computer
* Front-accessible serial console per computer
* Front-accessible USB port per computer
* Internal Gigabit crossover within each TEMPEST zone
* Internal unidirectional fiber links across TEMPEST zones
* Battery-backed DS1339 I2C RTC on each CPU.
Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz,
12 front-accessible Gigabit Ethernet ports and 960GB of solid-state
storage with a total power consumption of ~200W.
Additional notes:
* SPD detection is only known to work with the DO-160-certified DIMMs
* CPU reset is a little quirky due to hardware misfeature. Proper
support for the hardware reset mechanism has been left for a later
patch series to address.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Cc: Andy Fleming <afleming@gmail.com>
The "rmu" board has long been unmaintained, and is broken.
Remove it.
The BAB7xx boards are almost deceased. They cause build warnings, an
it's not worth the effort to fix these. Remove the dead body.
Cc: Frank Gottschling <fgottschling@eltec.de>
- booting from NOR Flash with direct boot method
- POST support
- LOGBUF support
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
The board is unmaintained and maintainer doesn't respond.
Add support for the Ethernut 5 open hardware design, based
on Atmel's AT91SAM9XE512 SoC.
V4
- Fix several coding style issues.
- Move machine type to config file.
- Remove use of CONFIG_ATMEL_LEGACY.
Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
