path: root/MAINTAINERS
2013-06-12arm: pxa: Add support for ICP DAS LP-8x4xSergey Yanovich
LP-8x4x is a programmable automation controller by ICP DAS. It is shipped with outdated U-Boot v1.3.0 This patch adds enough supports to boot the board: - 128M of 128M SDRAM - 32M of 48M NOR Flash memory - 1 of 4 Serial consoles (PXA FFUART) - 2 of 2 Ethernet controllers (DM9000) Signed-off-by: Sergey Yanovich <ynvich@gmail.com> Series-to: u-boot Series-cc: marex
2013-06-10ARM: DRA7: Add MaintainerLokesh Vutla
Adding Maintainer for DRA7xx. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10arm: Remove OMAP2420H4 and all omap24xx supportTom Rini
The omap2420H4 was the only mainline omap24xx board. Prior to being fixed by Jon Hunter in time for v2013.04 it had been functionally broken for a very long time. Remove this board as there's not been interest in it in U-Boot for quite a long time. Signed-off-by: Tom Rini <trini@ti.com>
2013-06-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/Makefile
2013-06-04Add support for Congatec Conga-QEVAl boardSARTRE Leo
Add minimal support (only boot from mmc device) for the Congatec Conga-QEVAl Evaluation Carrier Board with conga-Qmx6q (i.MX6 Quad processor) module. Signed-off-by: Leo Sartre <lsartre@adeneo-embedded.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-03arm: vf610: Add basic support for Vybrid VF610TWR boardAlison Wang
VF610TWR is a board based on Vybrid VF610 SoC. This patch adds basic support for Vybrid VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-23ARM: Add Seagate GoFlex Home supportSuriyan Ramasami
Add Seagate GoFlex Home support Start with dockstar configuration define support for RTC, DATE, SATA and EXT4FS Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
2013-05-23ARM: vexpress: create A5 specific board configRyan Harkin
This patch creates a new config for the A5 dual core tile that includes the generic config for the Versatile Express platform. The generic config has been modified to provide support for the Extended Memory Map, as used on the A5 core tile. A5 does not support the legacy memory map. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-23ARM: vexpress: refactoring of Versatile Express CA9x4 supportRyan Harkin
The current ca9x4_ct_vxp platform contains support for a Versatile Express motherboard with a quad core A9 core tile. This patch separates the Versatile Express motherboard code and the A9 specific code, to ease supporting more core tiles in the next patches. Andre: merged the first two of Ryan's original patches and did some checkpatch fixes. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-21ARM: atmel: add sama5d3xek supportBo Shen
Add sama5d3xek support with following feature - boot from NAND flash, PMECC support, 4bit ECC @ 512 bytes sector - boot from SPI flash support - boot from SD card support - LCD support - EMAC support - USB OHCI support Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-17Update MAINTAINERS file for sandboxSimon Glass
This currently has no maintainer listed. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-17Update MAINTAINERS file for x86Simon Glass
This still shows the previous maintainer. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-12arm: at91: add at91sam9n12ek board supportWu, Josh
Add support for following features: - nand boot, with PMECC 2bit ECC for 512 bytes sector - SPI flash boot - SD card boot - LCD support Signed-off-by: Josh Wu <josh.wu@atmel.com> [fix -Wimplicit-function-declaration for at91_lcd_hw_init()] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-11Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-10MAINTAINERS: fix the cm-t35 board nameIgor Grinberg
"cm-t35" in U-Boot source code is called "cm_t35". Make the change "cm-t35" -> "cm_t35" for better greppability. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-05-10ARM: Add support for IGEP COM AQUILA/CYGNUSEnric Balletbo i Serra
The IGEP COM AQUILA and CYGNUS are industrial processors modules with following highlights: o AM3352/AM3354 Texas Instruments processor o Cortex-A8 ARM CPU o 3.3 volts Inputs / Outputs use industrial o 256 MB DDR3 SDRAM / 128 Megabytes FLASH o MicroSD card reader on-board o Ethernet controller on-board o JTAG debug connector available o Designed for industrial range purposes Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-05-05arm: mx5: Add support for DENX M53EVKMarek Vasut
Add basic support for the DENX M53EVK board. Currently supported is: MMC (incl. booting) NAND (incl. booting) Ethernet, I2C, USB, SATA, RTC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de>
2013-04-22imx: Add titanium board support (i.MX6 based)Stefan Roese
Titanium is a i.MX6 based board from ProjectionDesign / Barco. This patch adds support for this board with the newly introduced NAND support for i.MX6. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-22mx6sl: Add initial support for mx6slevk boardFabio Estevam
mx6slevk board is a development board from Freescale based on the mx6 solo-lite processor. For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&parentCode=i.MX6SL&fpsp=1 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-04Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-28Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/spi/tegra20_sflash.c include/fdtdec.h lib/fdtdec.c
2013-03-27apx4devkit: change maintainerVeli-Pekka Peltola
As I am no longer working for Bluegiga I will pass apx4devkit maintenance to Lauri. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@iki.fi> Acked-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-24ti814x_evm: add ti814x evm board supportMatt Porter
Add TI814X EVM board directory, config file, and MAINTAINERS entry. Enable build. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> [trini: Adapt to recent omap_hsmmc requirements, Matt re-tested] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-15Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-14Tegra: Add twarren as maintainer for Tegra30 and Tegra114 SoCsTom Warren
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-03-12EXYNOS5: Snow: Add a configuration fileRajeshwari Shinde
This patch adds the configuration file for Snow Board and defines the same in boards.cfg. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-09mpc512x: add ifm ac14xx boardAnatolij Gustschin
Add new mpc5121e based ac14xx board and a new pinmux config function for setting individual pinmux bit groups. This function is used in ac14xx board code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-09mpc5200: Add a4m2k board portStefan Roese
This patch adds the a4m2k MPC5200B board port. Its a derivate of the a3m071 board with only minor changes. Additionally this patch includes some clean-up changes: - Remove I2C support from a3m071 as its unused - Fix/enhance default env variables - Fix some comments - Add newly introduced CONFIG_SPL_TARGET to automatically build "u-boot-img.bin" - Fix dtb patching in READ desciption for SPL Linux booting: "fdt chosen" needs to get called to patch/create the chosen node. - Add missing call to spl_board_init(): Define CONFIG_SPL_BOARD_INIT so that spl_board_init() will get called in the SPL version. Signed-off-by: Stefan Roese <sr@denx.de>
2013-03-04blackfin: bf60x: add board and headers files to support bf609Sonic Zhang
Board and config header files for bf609-ezkit support. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-02-18OMAP3: igep00x0: Add new IGEP COM PROTON.Enric Balletbo i Serra
The IGEP COM PROTON is a new ultra compact module design with an on-board ethernet controller. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2013-01-30powerpc/85xx: Add BSC9132QDS supportPrabhakar Kushwaha
BSC9132QDS is a Freescale reference design board for BSC9132 SoC. BSC9132 SOC is an integrated device that targets the evolving Microcell, Picocell, and Enterprise-Femto base station market subsegments. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. BSC9132QDS Overview -------------------- 2Gbyte DDR3 (on board DDR), Dual Ranki 32Mbyte 16bit NOR flash 128Mbyte 2K page size NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory SD slot USB-ULPI eTSEC1: Connected to SGMII PHY eTSEC2: Connected to SGMII PHY PCIe CPRI SerDes I2C RTC DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-28mx23evk: Add initial board supportOtavio Salvador
The following features are supported: * 128 MB DDR1 SDRAM * DUART * SD/MMC Card Socket Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-21mxs: Add MX23 olinuxino board supportMarek Vasut
This patch adds support for MX23-based Olinuxino board. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-12-07MAINTAINERS: Add a pointer to the custodians page.Robert P. J. Day
Since there's no obvious mention, add a brief reference to the custodians page at www.denx.de Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
