path: root/MAINTAINERS
2019-02-18efi_loader: Swap roles with HeinrichAlexander Graf
Heinrich is going to take over maintainership of the efi_loader tree going forward. To ensure that I will still receive review mails at least, add me as reviewer with a stable email address. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-18rpi: Make Matthias maintainerAlexander Graf
Matthias Brugger agreed to take over maintainership from me for the Raspberry Pi tree. Add him to the MAINTAINERS file instead. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-09defconfigs: Add config for AM57xx High Security EVM with USB/UART Boot supportAndrew F. Davis
Add a new defconfig file for the AM57xx High Security EVM. This config is specific for the case of USB/UART booting. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-09defconfigs: Add config for DRA7xx High Security EVM with USB Boot supportAndrew F. Davis
Add a new defconfig file for the DRA7xx High Security EVM. This config is specific for the case of USB booting. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-07Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- SPI-NOR support
2019-02-07MAINTAINERS: Add an entry for SPI NORVignesh R
Add myself as co-maintainer for U-Boot SPI NOR subsystem. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> [jagan: drop mtd/spi file from SPI entry] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-02-05MAINTAINERS: update u-boot-atmel treeEugen Hristev
Update Atmel AT91 maintainership Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
2019-02-05MAINTAINERS: Change fsl-qoriq, mpc85xx, mpc86xx maintainersYork Sun
Change maintainers to Prabhakar Kushwaha for fsl-qoriq, mpc85xx and mpc86xx. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-01net: mscc: Move ocelot_switch to mscc_eswitch folderHoratiu Vultur
Move file ocelot_switch to mscc_eswitch to prepare to add new net drivers for other MSCC SoCs. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-30MAINTAINERS: Add Amlogic entryNeil Armstrong
Add entry for Amlogic SoC maintained files and the freshly created mailing-list. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-01-30Merge tag 'u-boot-imx-20190129' of git://git.denx.de/u-boot-imxTom Rini
For 2019.04
2019-01-28MAINTAINERS: imx: Change Fabio's email addressFabio Estevam
I prefer to use my personal email address for U-Boot related work. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-01-26MAINTAINERS: update stm32mp1 path for archPatrick Delaunay
Handle correctly directory arch/arm/mach-stm32mp/ : Add a trailing slash to include all files and subdirectory files. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-24arm64: zynqmp: Move SoC sources to mach-zynqmpMichal Simek
Similar changes was done for Zynq in past and this patch just follow this pattern to separate cpu code from SoC code. Move arch/arm/cpu/armv8/zynqmp/* -> arch/arm/mach-zynqmp/* And also fix references to these files. Based on "ARM: zynq: move SoC sources to mach-zynq" (sha1: 0107f2403669f764ab726d0d404e35bb9447bbcc) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-23net: add MSCC Ocelot switch supportGregory CLEMENT
This patch adds support for the Microsemi Ethernet switch present on Ocelot SoCs. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-21MAINTAINERS: Add entry for CZ.NIC's Turris projectMarek Behún
Add myself as the maintainer of CZ.NIC's Turris Omnia and Turris Mox projects. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-17Merge tag 'mips-pull-2019-11-16' of git://git.denx.de/u-boot-mipsTom Rini
- MIPS: mscc: various enhancements for Luton and Ocelot platforms - MIPS: mscc: added support for Jaguar2 platform - MIPS: optimised SPL linker script - MIPS: bcm6368: fix restart flow issues - MIPS: fixed CONFIG_OF_EMBED warnings for all MIPS boards - MIPS: mt7688: small fixes and enhancements - mmc: compile-out write support if disabled
2019-01-16MSCC: add device tree for Serval2 boardHoratiu Vultur
Add device tree based on evaluation board pcb112. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16MSCC: Add device tree for Jaguar2 boardHoratiu Vultur
Add device tree based on evaluation board pcb110. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16pinctrl: mscc: Add gpio and pinctrl for Jaguar2 SOC familyHoratiu Vultur
The Jaguar2 SOC family has 63 gpio pins therefore I extended mscc-common to support new numbe of pins and remove any platform dependency from mscc-common. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16mips: spi: mscc: Add fast bitbang SPI driverLars Povlsen
This patch add a new SPI driver for MSCC SOCs that does not sport the designware SPI hardware controller. Performance gain: 7.664 seconds vs. 17.633 for 1 Mbyte write. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-16mips: mscc_sgpio: Add the MSCC serial GPIO device (SIO)Lars Povlsen
This add support for the the MSCC serial GPIO driver in MSCC VCoreIII-based SOCs. By using a serial interface, the SIO controller significantly extends the number of available GPIOs with a minimum number of additional pins on the device. The primary purpose of the SIO controller is to connect control signals from SFP modules and to act as an LED controller. This adds the base driver. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2019-01-14MAINTAINERS: ARM MEDIATEK: update file entriesWeijie Gao
This patch adds new file entries for MediaTek SoCs Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-01-09MAINTAINERS: update NXP i.MX mail list addressPeng Fan
Update NXP i.MX mail list address Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-19mips: jz47xx: Add JZ4780 SoC supportPaul Burton
Add initial support for the Ingenic JZ47xx MIPS SoC. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Marek Vasut <marex@denx.de>
2018-12-19MSCC: add board support for the Luton based evaluation boardGregory CLEMENT
Adding the support for the Luton boards PCB91 which share common code with the Ocelots boards, including board code, device tree and configuration. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-19MSCC: add board support for the Ocelots based evaluation boardsGregory CLEMENT
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123 Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-19MSCC: add support for Ocelot SoCsGregory CLEMENT
This family of SoCs are found in the Microsemi Switches solution and have already a support in the linux kernel. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-15tools: add a generic config for native tools buildingOtavio Salvador
The motivation for this is to allow distributions to distribute all possible tools in a generic way, avoiding the need of specific tools building for each machine. Especially on OpenEmbedded / Yocto Project ecosystem, it is very common each BSP to end providing their specific tools when they need to generate images for some SoC (e.g MX23 / MX28 in meta-freescale case). Using this, we can package the tools doing: $: make tools-only_defconfig $: make tools-only Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> [trini: Add MAINTAINERS entry for myself, add to .travis.yml, make U-Boot itself buildable to not trip up other frameworks] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-05binman: Add myself as maintainerSimon Glass
Add an entry for my maintainership of this tool. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-02MAINTAINERS: add EFI PAYLOAD reviewerHeinrich Schuchardt
Alex suggested to add me as a reviewer for the EFI subsystem. The patch also adds a description for R: entries. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-28MAINTAINERS: add an entry for MediaTekRyder Lee
This patch adds an entry for MediaTek. Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-09MAINTAINERS: Update stm32mp entryPatrick Delaunay
Add mailing list for stm32mp architecture and board. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-06MAINTAINERS: add NXP linux team maillist as i.MX reviewerPeng Fan
Add NXP linux team upstream maillist as reviewer Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-10-16Merge git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.11-rc2-v2 FPGA: - Fix SPL fpga loading from FIT ARM64: - Fix gic accesses in EL2/EL1 Xilinx: - Add dlc20 board support - Add Versal board support - Sync defconfigs - Enable MP via Kconfig - Add missing efuse node - Enable CDC for zcu100 cmd: - Fix kgdb Kconfig dependency
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-12i2c: fix: Add support for the Arm's Versatile Express I2C controllerHeiko Schocher
accidentially while fixing merge errors for patch: https://lists.denx.de/pipermail/u-boot/2018-September/342278.html missed to add files: MAINTAINERS drivers/i2c/Kconfig drivers/i2c/Makefile add them with this patch. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com>
2018-10-07tee: optee: support AVB trusted applicationJens Wiklander
Adds configuration option OPTEE_TA_AVB and a header file describing the interface to the Android Verified Boot 2.0 (AVB) trusted application provided by OP-TEE. Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Reviewed-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-07Add UCLASS_TEE for Trusted Execution EnvironmentJens Wiklander
Adds a uclass to interface with a TEE (Trusted Execution Environment). A TEE driver is a driver that interfaces with a trusted OS running in some secure environment, for example, TrustZone on ARM cpus, or a separate secure co-processor etc. The TEE subsystem can serve a TEE driver for a Global Platform compliant TEE, but it's not limited to only Global Platform TEEs. The over all design is based on the TEE subsystem in the Linux kernel, tailored for U-Boot. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-06misc: Add support for the Arm Versatile Express config busLiviu Dudau
Add support for the Arm Versatile Express config bus that is being used for exposing various subsystems via a generic configuration bus. This driver adds support for generating transactions on this configuration bus and can be used by other drivers to abstract the communication with the actual function providers. Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-30phy: db410c: Add MSM USB PHY driverRamon Fried
Add a PHY driver for the Qualcomm dragonboard 410c which allows switching on/off and resetting the phy connected to the EHCI controllers and USBHS controller. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-09-28video: Add support for Arm's Mali Display ProcessorsLiviu Dudau
Add support for Arm Mali Display Processors DP500, DP550 and DP650. Only one layer is being used to display the console or boot logo, even if more layers are supported in the hardware. Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com>
2018-09-28video: Add support for NXP's TDA19988 HDMI encoderLiviu Dudau
Add support for the NXP TDA19988 HDMI encoder as used on the Juno development board from Arm. Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com>
2018-09-28MAINTAINERS: assign include/video*.hHeinrich Schuchardt
The include/video*.h files are part of the drivers in drivers/video. So it makes sense to assign them to the same maintainer. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-23efi_loader: EFI_UNICODE_COLLATION_PROTOCOLHeinrich Schuchardt
The patch implements the EFI_UNICODE_COLLATION_PROTOCOL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23efi_loader: capitalization tableHeinrich Schuchardt
This patch provides a define to initialize a table that maps lower to capital letters for Unicode code point 0x0000 - 0xffff. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test: unit tests for Unicode functionsHeinrich Schuchardt
Provide unit tests for Unicode functions. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-20mtd: move NAND files into a raw/ subdirectoryMiquel Raynal
NAND flavors, like serial and parallel, have a lot in common and would benefit to share code. Let's move raw (parallel) NAND specific code in a raw/ subdirectory, to ease the addition of a core file in nand/ and the introduction of a spi/ subdirectory specific to SPI NANDs. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-09-19Merge git://git.denx.de/u-boot-marvellTom Rini
- Multiples updates to the turris boards / platform - Changes / enhancements to the Marvell PHY drivers, mainly to support the turris platform - Many fixes and enhancements to the pxa3xx NAND driver - Fixes for the UART boot mode in kwboot - Misc minor changes to other 32bit and 64bit boards
